Back to:
Tags:
IBM ThinkPad T23 2647 PC Notebook
Dv 2000 screen problem
posted by hrivera112 on Jun 18, 2008
i changed the inverter and the screen and i still have the same problem with screen it looks off but its not. any suggestions
Comment by hrivera112, posted on Jun 18, 2008
i do see the desktop dimly. but it keeps telling me to run safe mode or some other options and i do just to see if i can reach my personal dektop and it keeps restarting and back to that option page for safe mode. and i changed the inverter twice. whats the power/socket to the inverter? and if its it that rare, is it possible to fix. i can really use the help. thank u.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
Coldcut
Rank:Wiz Wiz
Rating: 84%, 522 votes
so the screen is still dark.
see if the video card is putting out a signal. by connecting an external monitor and select function monitor to send signal to it.,
and take a bright light and hold at angle to view lcd screen do you see the desktop dimly.
you may have the rare case of the power/socket to the inverter is not working though I have never seen that in over a hundred laptop repairs.
be certain that the new inverter is not bad , seems more likely that it may be bad..
check that inverter has a gnd and 12volts ~ going to it .
here is a decent explanation of an inverter circuit troubleshooting
its a doc file.
http://support.advantech.com.tw/support/DownloadFile.aspx?File_Id=1-ZZLO
Comment by Coldcut, posted on Jun 18, 2008
if you have the desktop then the video card is working,
it is still likely that the inverter is bad or not getting voltage.
open the lcd to get to the inverter supply wiring .
connect a dc meter to ground.
and probe the input wiring you should see 12volts.
and as in the file link you will see in fig 1 that one pin will come back and be grounded to activate the inverter.
you can connect your ac meter on high voltage ac and try to get a reading on the high voltage connectors leading to lamps
but only do so for a second as it will peg the meter with 1500 volts ac High freq.
if you dont have a meter you can use a 12 volt bulb .
but meters cost 3.00 at harbor freight if you have one there.
Rating Locked! (?) hrivera112 has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on dv 2000 screen problem:
I don't want to Accept this solution
Can you Help with these PC Laptops problems?
PC Laptops
My laptop has Windows Vista Ultimate x64 as its operating...
PC Laptops
I don't really have any problem with the laptop now... I...
PC Laptops
Pls help me to find SATA drives to be integrated on XP...
What kind of sound driver does IBM ThinkPad T23 2647 PC...
Occasionally, on my T23 2647, Microsoft foto editor's...
Loading problems.
Repair Service
Find PC Laptop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
