Question about GE VG4270 VCR
I push play and after a few seconds it stops. Everything else works fine.
Is having trouble reading or tracking disc.I opened top and while playing disc the tracking mechanism goes out then back in and starts playing where it stopped?
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 22, 2015 | Audio Players & Recorders
Tempature gauge
Remove the serpentine belt, check to see if there is play in the water pump pulley. If there is no play in the pulley, then the water pump is fine. Remove the thermostat and lower radiator hose and flush both Radiator and the Engine with a hose for a few minutes, put everything back together, refill coolant. Test, let me know if it worked. Thanks
Feb 16, 2012 | 1996 Ford Explorer
Stuck vhs in vcr
check the tip in my profile
May 31, 2010 | Philips CCC130AT 13 in. TV/VCR Combo
Well when i put a song on it will play for few seconds then it will stop the music AND when i push play its at the bigening
check and make sure you dont have it set to a demo mode where it will play the first few seconds of a file then move on to the next one
Apr 14, 2010 | Nextar MA58820BL MP3 Player
Tascam model 112
The 112 unit uses a cam operated transport- it may need a new 6.5" belt and some head base lubrication as well as the feedback pot spray cleaned. I do them all the time.
Jul 26, 2017 | Tascam 122MKIII Single Dual Cassette Deck
10sec play
try reseting it. then resyncing your ipod. to reset it, simply push the middle button down, and the menu button at the same time. a few seconds later and the ipod should reset. then sync the song that had the problem onto the ipod and see if it works. (no point in syncing all your songs becuase if reseting it doesnt work you wasted alot of time syncing songs for nothing)
best of luck : )
Jan 22, 2008 | Apple iPod nano
Video out problem
I own a DMR-ES20 and had that problem. Panasonic Customer Service gave me a fix that works.
On the unit itself, press STOP and PLAY at the same time for about 10 seconds. This fixed my player.
Nov 23, 2007 | Panasonic DMR-E20 DVD Recorder
GE VG4270 VCR Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
