Question about Motorola Mobility PEBL U6 Cellular Phone
Motorola pebl none of the buttons work on the keypad except the onoff button is it locked? do i have to push any other buttons to acctivate it
  • marsflower Aug 05, 2008
    I'm having the same problem starting yesterday. Only the on/off button works. I cannot make calls but I can receive calls. The Centennial Wireless rep I talked to today said she had never seen the keypad lock up before and had no idea what the problem is. If anyone has information on this problem, a response would be greatly appreciated. Thank you in advance!
I had the exact same problem. Take the phone apart and wipe down he keypad with an alcohol soaked (very mild) q-tip. Let it dry and re-assemble the phone. It all works now!
There are 4 tiny screws under the back cover, unscrew all 4 (home depot carries the little star attachment in most tool sets). Then lift the blue cover off the keypad, the board in the middle stays attached to the headset. There is a little black rubber piece by the USB port keep an eye on it. Also do not pull the board away from the headset, you'll break a tiny silver ribbon.
To re-assemble just tuck the board back in the blue case, tighten the top screws half way. Flip over and tuck the side button connections in, then slip the face plate in top first and press down. Tighten remaining screws and you're done.
Posted on Aug 26, 2008
All keys are not working.. only the red key is working.. but i can use the motorola phone tools
Normally it happens when one key is being pressed permanently (due to stuck keypad or water damage) the none of other keys will work except red one.
Please examine your phone physically if there any key is stuck.. especially volume or camera buttons.
If every things is ok then its worth paying a visit to nearest phone repairing shop, either full service or keypad or Keypad IC replacement will solve the problem
Thanks
Apr 02, 2011 | Motorola Mobility RAZR2 v9 Cell Phone
Only One Button Works On My Motorola Razar
fone may need flashing or keypad changed
Aug 31, 2009 | Motorola Mobility RAZR V3
Keypad of my motorola RZR2 V9 not working except for red button
clean pcb boar specially keypad board.. check vol. swicth and all switch located at side of fone if shorted...
Feb 19, 2009 | Motorola Mobility MOTORAZR2 V9 Cellular...
Phone turns on fine but nothing happens pushing buttons except power.
If your phone has a keypad lock option, make sure that the keypad is not locked. Refer to the user manual to know how to unlock the keypad.
It is also possible that the keypad is defective and needs to be replaced.
Jerry G.
Jul 12, 2008 | Motorola Mobility i560 Cellular Phone
Almost dead phone
YRAG - take the phone and have the flexcable replaced as well as fully service
inuyasha - the lcd needs replacing
psasho - no, replaced the battery as well as replacing the lcd
Jul 04, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Motorola pebl wont turn on
take it to a reapir store close to you to have it check....try using a new battery and see if it turns on if that does not work then have it check
May 11, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Keypad does not work
I had a common problem which none of my keys worked except the "off" key. I baked my phone in the oven on the lowest setting for 20-30 minutes and it works now. It is a humidity issue.
Mar 16, 2008 | Motorola Mobility RAZR V3
Frozen buttons except red end call button
it seems you have the common v3 keypad flex problem - normal issue - it costs $25-40 to replace depending where you do it.
we charge $25 + shipping
http://horizonwirelessonline.com
Dec 25, 2007 | Motorola Mobility Razor Behind-the-Head...
Motorola Razr Keypad
It is a humidity issue. I had the same problem with my phone. I baked it in the oven on the lowest setting for 20-30 minutes and it works fine now :)
Sep 06, 2007 | Cell Phones
Motorola Mobility PEBL U6 Cellular Phone Logo
94 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
