Question about KitchenAid Pro Line KWCU360JSS Kitchen Hood
Removing the fan
I have a bird that came down the vent and I am trying to get it out. How do I get past the fan to get to it? How do I remove the fan? Thanks
    Problem Solver:
  • 50 Answers
Most fans dont come out. but it is not hard to take the hood down. there are most likly four screws in the top going down into the hood. undo them, making sure the hood is proped up. them is should just lift out of the backing plate and there is your bird. to put it back up just put it back on the backing plate then put the bults back in and make sure the vent is on properly.
Posted on Jun 20, 2008
My cabrio dryer is overheating. I have replaced thermistor, thermostat, replaced control board but get f22 error code,
Dryers overheat because of reduced airflow. You need to fix that first. Remove the rear vent completely and check the hose for lint and birds nests. Check the flaps on the wall vent that they move freely. Then strip the machine down and clean all the ducting and the fan.
F22 Error Code
http://www.shopyourway.com/questions/1146749
Jan 24, 2017 | Dryers
Advent 5712 overheating and cutting out, why
Step 1:
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Laptop fans are designed to keep the system cool by removing heat from the hard drive, processor and other internal hardware components. The fan draws cool air in, then blows hot air out through vents in the laptop case. A faulty laptop fan can cause permanent damage to occur very quickly. If a laptop fan starts making loud noises or stops blowing hot air through the vents, replace it as soon as possible.
Turn the laptop off and unplug it. Unplug or disconnect any external drives or other devices. Move the main battery latch to the "Unlock" position and remove the battery pack. Push in on the optical drive release mechanism, then pull the CD/DVD drive out of the case. Remove the screw(s) that hold the hard drive sled in place, then pull the entire hard-drive assembly out of the case slot. Turn the laptop over. Remove the screws on the bottom that hold the keyboard assembly in place. Flip the laptop over then open it. Lift the front of the keyboard up about 1 to 2 inches. Unplug the flexible ribbon cable that connects the keyboard to the motherboard, then pull the keyboard assembly away from the bezel. Lay the keyboard aside. Unplug the laptop fan. Remove the screws that hold the heat sink/fan assembly in place, then remove the fan from the laptop. Check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat Thermal compound is a sticky paste that is placed directly onto the CPU. http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink. http://www.youtube.com/watch?v=Bwr3vxSErs0 How to fix an overheating laptop : Clean your fans and heatsync with this procedure http://www.youtube.com/watch?v=ZXd09C0p-Cc How to clean a laptop fan
Feb 04, 2013 | Computers & Internet
My computer shut off by itself even though the battery was charged and the battery light kept blinking even after my computer was off. computer seems hotter than usual on bottom as well
It is probably shutting down to prevent thermal damage dut to overheating. Check that the fan is working. Even if it is, if the vents are clogged with dust the machine will not be able to cool properly. The only real remedy is to open the case, clean all the vents and fan, remove the heatsink, clean off old thermal paste and apply new paste before replacing the heatsink and putting back together.
Mar 14, 2012 | Sony VAIO VGN-S580B (VGNS580B03) PC...
Dryer gets hot, but stays damp inside and clothes don't dry. I removed a birds nest from the outer end of the vent, and there is plenty of hot steamy air coming through, but still having this problem....
The vent is probably still stopped up. You are going to have to pull the dryer out and disconnect the 4" vent hose from the back and inspect the vent all the way through.
May 18, 2011 | Dryers
Its overheating and shutting down after maybe 15-20 minutes
Almost certainly a clogged cooling fan , vents or build up of dust on the cooling fins. You will need to gain access to the CPU fan and remove the heatsink assembly, blow all dust out of the cooler matrix, clean the fan blades and the cooling vents. Clean off any thermal paste on the cpu and regrease with new paste, refit and reasemble.
You CAN cut corners by cleaning it "in situ" but a thorough cleaning is advised.
Eventually if not cleaned, teh graphics chip will fail with overheating
Jan 29, 2011 | Computers & Internet
Runs way too hot, overheats and shuts down. Besides geneal external cleaning hints, any suggestions? Like how to run fans at max rpm always? Or how to open it up to thoroughly clean it?
Check that all of the air vents are left unblocked and that your fan is spinning and expelling warm/hot air. It is recommended you use your laptop on a hard flat surface to ensure some airflow under the laptop. You could try purchasing a can of compressed air and blowing it into the vents to loosen up any built up of dust and hair.
If you are skilled enough you could open the laptop up to completely clean the fans and heatsink. Whilst it is open you can remove the heatsink, clean the old thermal paste off of the CPU and GPU and apply a very thin, evenly spread layer of fresh thermal paste. Then put the machine back together.
As for the fans, download a free application called SpeedFan and read through it. It will monitor your core temperatures and it has some options for controlling fans if your hardware allows it.
Hope this helps,
www.PuterCare.com
Jul 13, 2010 | Toshiba Satellite U405D-S2852 Notebook
My Inspiron 8500 wont load completly it turns on and when it has finish loading halfway it shuts off. I tried presing F2 and F12 but it still shuts off. This started happening after i fell asleep on it...
It sounds like overheating. I would check the fans in the back to see if they are packed with lint. You will need new thermal paste, then take the keyboard bezel off then remove the screws that hold down the keyboard. Remove the four screws over the heatsink and then remove the fan. Blow these out, make sure there is nothing in the vents or heatsink. Use a credit card to scrape off old thermal paste on the processor, and the heatsink and put a small amount on the processor and put it back together.
Jul 11, 2010 | Dell Inspiron 8500 Notebook
Fan has a humming noise and locking up
a.if there were a dead bird inside, you'd know it from the smell! if the outside vent has the proper hood on it, it's doubtful a bird could get into it. possibly a roof-rat, but still- the smell!
b. have you 'de-greased' the filter lately? clogged filter can cause airflow problems, as well as allowing fan blades to become greased up and unbalanced, which could cause a noisy condition. if you can- remove the filter unit and check the fan blades for crud. use a gentle application of windex, rubbing alcohol, or some other gentle solvent to clean the blades. the leading edges usually pick up the most crud. you should be able to see this! carefully, using q-tips, or a small brush, clean off the crud! the fan's probably out of balance. WD40 works pretty well, too. also lubricates the shaft bushing that the blades are attached to. make sure the fan is turned off! duh!! good luck! also- soak the filter in hot water and a good de-greaser for a while, 'til you can see light through it. it's probably aluminum mesh- so use very hot water and a goodly amount of 'grease cutting' dish detergent. rinse well.
once again- good luck! the filter is probably held in place by clips. once removed, you will probably need a flashlight to work on the fan blades. put paper towels, or newspaper down to catch drips!
Sep 29, 2009 | GE ZV750SY Kitchen Hood
Laptop shutting down
A quick fix is to blow back into the vents to blow dust out.
May need to dismantle though and clean fan and maybe even remove heatsink and renew thermal paste.
Jan 06, 2008 | Computers & Internet
KitchenAid Pro Line KWCU360JSS Kitchen Hood Logo
189 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
