Question about Lexmark X4650 InkJet Printer
The printer says ink cartridges are 99% and 67% full but when I try to print a message comes up to order ink and the pictures of the cartridges have yellow question marks on them and nothing will print. I tried removing and replacing the cartridges, also turned power off and then on again. How can I fix this?
  • Lexmark Master
  • 3,267 Answers
First, make sure there are no print jobs stuck in the queue. On the computer, go to Control Panel > Administrative Tools > Services. Scroll down the items and make sure these services are "Started":
  • Print Spooler
  • lxdx
If status doesn't say Started, right click on the item and choose Properties. Choose Automatic for Startup type. Choose Started for Service status. Hit Apply then Ok to save the settings. Retry printing. If problem continues, contact Lexmark technical support. Thanks.
Posted on Nov 14, 2010
Printer won't print B&W even though black cartridge is full but 2 colours are empty.
Although you are only trying to print a B & W picture, the color print cartridge/cartridges must also contain ink in order for the printer to work. All print cartridges must contain ink for printing of any type to take place.
Load the color print cartridges and the B & W picture will print.
If you were trying to print a color picture and the B & W cartridge was empty, the printer also, would not print.
I hope this helps you out.
Good Luck
Jan 25, 2011 | Office Equipment & Supplies
When i finish printing it sounds like it is cleaning the print heads. this is n ew I ordered direct and I have only had it two weeks and it is low on ink and I have scarcely used it
Welcome to the world of ink cartridges and ink use.
You may not believe you used that much ink but you have.
Starter cartridges are not necessarily full cartridge loads. However, if you purchase new ink cartridges from your printer's manufacturer, they will be full.
I've done some pictures that were son intensely busy that they killed a cartridge on the first run. Use is determined by the document and not how long you used the cartridge.
Don
Jan 21, 2010 | Office Equipment & Supplies
Error message that color cartridge has low ink, so printer won't print. How do I override this? This message occurs when only one color is low and requires replacing the entire cartridge.
No way 2 override the message. Printer works on a combination of both black and color ink to print those perfect pictures and documents. If it is showing color ink needs replacement,you ve 2 change it in order to print even in black and white.
Jan 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
I have a Brother DCP350 and no yellow ink. But tonight I have to print a document. Will the printer work without Yellow? I have been trying for an hour now and cannot print anything.
Hi matt651, I had the same problem with the DCP-350. As soon as one of the colour cartidges was empty, which happened frequently due to the high ink loss during the cleaning process, the machine stopped working, even when I only wanted to print using black. This is how i worked around the problem using a piece of grey card stock: The tanks have a small clear window that lets you see the ink in the cartridge. This window also triggers a photocell which sits in a little black fork at the back of each of the printer's ink cartridge slots. When the ink levels are up, the cell is blocked, thereby indicating a full cartridge. When the ink level in the cartridge drops below the photocell, the cell switches over, indicating an empty cartridge. So in order to simulate a full ink catridge I removed the offending empty one and instead slipped a piece of cardboard into its slot, thereby fooling the photocell. And hey presto, when I switched the printer back on, all ink cartridges thus manipulated were shown as being "full" and I could continue printing.
Kind regards, Rog
Nov 27, 2008 | Brother DCP-350C InkJet Printer
Refilling Ink Cartrdige failer!
I have a Lexmark X5495 printer and I had it refilled a couple of weeks ago, suddenly i have a message that goes "Order new ink" or something and i check the cartridge but it is still full. I try restarting the printer and even the computer but the printer STILL won't let me print.
Oct 11, 2008 | Lexmark X5495 Printer
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
No ink coming from cartridges.
Sounds like maybe the nozzles are clogged up. Try using the printer maintenance utility to "Clean Nozzles". I think for most Lexmark printers it is call the "Lexmark Solution Center" in your Windows Start Menu. If that doesn't work, try maybe wiping the cartridge with a damp paper towel at the place where the ink comes out.
Apr 15, 2007 | Lexmark X2250 All-In-One InkJet Printer
Lexmark X4650 InkJet Printer Logo
135 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
