Question about Dell OptiPlex GX280 PC Desktop
Optiplex GX280 - loud fan at start up and amber power light - does not boot
  • Marlon Mendoza
    Marlon Mendoza Nov 14, 2010
    ill try replace it tnx
  • 162 Answers
Most likely you have a bad Power Supply, replace your power supply
Thanks
DiegoTech
Posted on Nov 14, 2010
  • Marlon Mendoza
    ill try to repalce my power supply.tnx
Dell opitiplex 280 is not giving display. first of all his fan speed to much high and then after 4 or 5 day its display disappeared. its just picking now power and fan also start with high noise and...
OK, I use GX280s as home servers and ran into a similar problem with one of them...
The problem may be serious and not worth fixing (motherboard).
Turn power on
Fan(s) come on full power, sounds like a jet engine, or eventually gets that loud.
See if you power light has gone amber.
You get nothing on the screen, no Dell splash screen/post, nothing.
This is what I posted a while back concerning the above. Obviously I cannot bee 100% certain as I do not have your box in front of me. This a known issue.
See if the power light goes amber after power up. I had (have - still siting in my basement) one that did same. Power up, fans go full blast . Power light goes and stays amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad. Bottom line this is usually a defective motherboard. Mine was a bad caps issue, you issue could be different, but it does sound like the motherboard.
You can google "gx280 solid amber light loud fan" and see the issues. Here is one link.
http://community.spiceworks.com/topic/111476-gx280-solid-amber-light-and-loud-fan
I just replaced one of my old 280s with a dual core Dell Precision 390 workstation for about $118, and that included shipping, off of ebay.
Sep 25, 2011 | Dell OptiPlex GX280 PC Desktop
Help me i have gx280 tower type 3.0 ghz 20 machines i bought these machines from used markete few machines are trouble in cpu fan abnormal noising i removed al types of hardware components but...
I obviously can not be 100% sure about this as the unit is not here.
You can google "gx280 solid amber light loud fan" and see the issues. Here is one such link.
http://en.community.dell.com/support-forums/desktop/f/3514/p/19253544/19414291.aspx
Aug 06, 2011 | Dell OptiPlex GX280 PC Desktop
We have around 30 units of DELL Optiplex GX280 having mother board failure. It was more then 3 years old already. Once the turbo fan become noisy then it will gone dead.
May be serious. See if the power light goes amber after power up. I had (have - still siting in my basement) one that did same. Power up, fans sound like 747 taking off. Power light goes and stays amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad.
Feb 16, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
I have dell optiplex GX280 when i press the power button i dont get any display and cpu fan reach to its max speed how can i fix this prob?
May be serious. See if the power light goes amber after power up. I had (have - still siting in my basement) one that did same. Power up, fans sound like 747 taking off. Power light goes amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad.
You can google this and see the issues. Here is one such link.
Feb 11, 2011 | Dell OptiPlex GX280 PC Desktop
Optiplex GX280 - loud fan at start up and amber power light - does not boot and no light at the back
Apply pressure on the heat sink fan right before you press the power button and continue applying pressure. Watch your screen if you see it boot this means its a problem with your processor clamp that applies pressure to the processor. Try to remove the top part of the clamp. Shouldn't be too hard with some needle nose pliers. Then just replace the heat sink and fan with out that clamp.
May 27, 2010 | Dell OptiPlex GX280 PC Desktop
Dell Optiplex GX280 - On power ON , no Fan movement no display
Confirm no leaking or bulging capacitors on your mothboard.
refer to here
http://en.wikipedia.org/wiki/Capacitor_plague
As this was a common problem with the GX280.
If found, you will need to replace the capacitors.
The other check is to make sure the heatsink is fitted correctly, perhaps reaply the thermal paste if you have any. I know that high temps would switch the GX280 off.
Jul 15, 2009 | Dell Optiplex GX280 (99301) Motherboard
Dell optiplex gx280 makes loud fan sound at startup and enters windows screen, but will not finish booting and freezes up.
You may have a problem with your power supply(the loud fan noise) and eventually it may get too hot and will cause problems like not fully booting.
Jun 12, 2009 | Dell OptiPlex GX280 PC Desktop
Dell OptiPlex GX280 PC Desktop Logo
275 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
