Relays wont click on when plugging power to deflection board 1730c toshiba 46h84
  • georgegonz1 Jun 18, 2008
    changed relays-fuses good- checked rectifier output good-checked around brd for any open damaged componants-to no avail.
  • 8,617 Answers
Have you checked your fuse? Will the relay click when you press power? You may possibly have a bad relay or the bridge rectifier diodes could be open.
Posted on Jun 18, 2008
  • Sonny Berry
    Sonny Berry Jun 18, 2008
    have you checked the voltage regulators to see if your stand by voltages are present? If the stand by voltages arent being produced you have a dead regulator in that supply
Toshiba Projection Television TZ50V61, Red power light blinks, no picture, no sound
That sounds like the deflection board. You can get the replacement deflection board from www.tvrepairworld.com under Toshiba Circuit Boards catagory
Jun 14, 2011 | Toshiba TZ50V61 50" Rear Projection...
I have a 42 inch toshiba 720 dlp hdtv, and it wont turn on. i press power to turn it on, it tries to fire up, the lights under power and lamp start blinkin green, and then orange, but then just stops and...
Tv "LAMP" LED light indication is blinking or lite up?The tv projection lamp insisde this tv now like 1 1/2 or 2 years already?Tv on and used daily like 4 or 5 hours everydays?Yes.The tv projection lamp life are over.The tv require a new tv projection lamp.Still have problems after this the tv board that call the Ballast board it is dead too,must require changing too.The Ballast board only job are to help to fire up the tv projection lamp and keep it lit.
May 01, 2011 | Toshiba 46H84 46" Rear Projection...
WHY DOES MY TOSHIBA TZ61V61 loose picture but not sound. Unplug from power wait a few minutes plug it back in and it works
The vertical deflection has stopped which cuts off the picture tubes to prevent burn in. Check the vertical output or the deflection board may need replacement.
Aug 08, 2010 | Toshiba TZ61V61 61" Rear Projection...
Why is my toshiba 46h84 picture getting darker than before? Its becoming harder to see darker scenes in movies
It sounds like your lamp is getting close to the end of its lifespan.The lamp is what gives your screen its brightness.With time they start losing this brightness.If you were to wait to replace it till it goes out completely you would have a black screen.You can purchase a quality lamp at discount-merchant.com
Apr 16, 2010 | Toshiba 46H84 46" Rear Projection...
No picture but sound on Toshiba 46h84
If you feel comfortable enough, you can try replacing the pico fuses on the power supply board. Test them with a multi meter very carefully.. these sets have up to 5000 volts and care should be taken, even by a professional with the back panel removed.
Jun 13, 2009 | Toshiba 46H84 46" Rear Projection...
Toshiba 46h84 green crt
I would leave an email at the following link with your model number and what youre needing, as they have a large supply of hard to find CRTs and circuit boards. They will respond quickly to your request.
http://servicemanuals.vstore.ca/
Jun 08, 2008 | Toshiba 46H84 46" Rear Projection...
46h84 toshiba rear projection tv
possible yoke fault or deflection /ask for an estimate before the repiars are done.might cost you a service call.
Aug 05, 2007 | Toshiba 46H84 46" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
