Question about DeLonghi CF210 Portable Air Conditioner
Hi, my Delonghi pac w160b is 12 months old. When I filled it with water for the first time this season the water all leaked out onto the carpet. I would love to have a look inside as i am technical by my work, but i cannot get the darn thing open without the possibility of breaking tabs off. Any ideas would be much appreciated. Cheers. Regards Dave Evans.
jfpogie
  • 104 Answers
SOURCE: DeLonghi Pinguio Pac 45
1. Clean air filer every 2 weeks.
2. clean ACCU and FCU every 3 months.
3. check and re-tight all electrical connection every 6 months.
Posted on Jan 20, 2008
22yooper
  • 828 Answers
SOURCE: Delonghi Pac L90
Hoses for proper connection should have been included with your purchase. Without the hoses the set-up can not be done satisfactory. One is for fresh air supply and the other is the hot air exit hose. These are normally vented out a window. Check with the dealer where you perchased the unit from. If from a private individual contact them.
Posted on May 21, 2008
SOURCE: delonghi pac-02 a/c
I had similar problem .... on very humid days unit leaks ..... temp solution for me was to drain the unit .... inserted wire coat hanger into tube .... lots of watery gook came out.. - even tilted/tipped the unit inorder to get as much water out of it.......afterwards unit worked fine.
We are VERY SASTIFIED with the Delonghi Pinguino - bought it years ago when it first came out and it has provided years of troublefree service .... the water build up / leaking was only recently - in fact we never drained the thing until this year.
Posted on Sep 06, 2008
  • 10865 Answers
SOURCE: Exhaust Hose DeLonghi PAC-210U replacement
you can contact the company directly at
Contact Center
1-877-882-8604 Monday – Friday
8am – 8pm EST
good luck with this.
Posted on Feb 14, 2009
  • 134 Answers
Hi
You need to go here
://www.delonghi.co.uk/accessories.php
DeLonghi (W160B) Portable Air Conditioner "No Water" symbol is still on despite the water tank being full
Tank hols 14 litres water where you fill there is a indicator if that is clear the tank is not full has to be red to be full. The water fill symbol will then go out.
Dec 23, 2012 | Heating & Cooling
With code Ft at delonghi pac c100
Ft = normally means empty the internal tank, this is normally done at end of season cleaning storage. On some units there is a small ''bung'' low on the rear which will empty the tank - the unit should then reset when powered up. Hope this helps
Jan 24, 2011 | DeLonghi PAC C100 Air Conditioner
Hi
You need to go here
Feb 14, 2009 | DeLonghi Pinguino PAC-02 Air Conditioner
Delonghi pac-02 a/c
Aug 23, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
Pinguino pac-166 not cooling enough
CHECK AND CLEAN THE DUST FIELTER AND ALSO CHECK THE BLOWER THEN TRY IT
Jul 06, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
Error Message
It's actually "Ft", which means "Full Tank".  The instruction manual says to drain the internal safety tank through the drain hoses.
To drain the tank, open the cover on the rear of the appliance. Pull out the 2 drain hoses, take off the caps, and let all the residual water flow out.  When all the water has been drained, place the caps back on the hoses and put the hoses back inside.
It also says you need to clean the filters and let them dry thoroughly before putting them back.
This is also the procedure for "End of Season Operations."
Hope this helps!
Jun 05, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi PAc 60 it just stopped 12 months later with a warning light
Reset the GFIC if it has it.
Bypass it if you know how. they go bad often.
or open the unit and use an ac meter an make sure it is getting power at least , trace the ac cable to the board. and test.
Careful it may hurt bad.
Jan 25, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
Jan 10, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
DeLonghi CF210 Portable Air Conditioner Logo
210 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
