Question about Refrigerators
My fridge/freezer is an Indesit and the fridge is not working and the freezer has defrosted. The light still works inside so l know there is power. The pump at the back is warm to touch. Any ideas whats wrong?
    Novelist:
    Champion:
  • 216 Answers
Greetings suepentony.
Generally when your fridge stops cooling and your freezer also is having diminished function, it is an indication either your compressor is going bad, or you need freon. I would suggest having a repair person come check out the unit as soon as possible to prevent further food loss.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Posted on Jun 18, 2008
Should fan run constant on indesit ban12fn fridge freezer?
It should shut off when it reaches the correct temperature. If you have the temp set to low it could cause it to continue to run or if there is an issue with the fridge that could also cause this issue. Keep in mind after a defrost it will take some time for everything to get back to the correct temp so it may run constant for a long time.
Jun 09, 2015 | Indesit Refrigerators
Fridge and freezer stopped working but fridge light still on should the orange switch by the light be on or off don't know if that is the defrost button
Sounds like a motherboard or defrost control board. Can you tell me the model number found inside the fresh food compartment or around fresh food section door frame, Without the model number it is hard to guess what the switch is that you are asking about, Thanks Sea Breeze
Dec 08, 2012 | Refrigerators
Fridge/Freezer
Probably be cheaper to get new one, it has probably had the compressor fail or a leak in the cooling system.
Sep 16, 2017 | Smeg FR148A Refrigerator
Fridge don't work after defrosting session
It depends on weather or not you damaged it during the defrost. Most fridges' are self defrosting. Look at the coils behind the back cover inside the freezer. They should be covered in a light frost if the compressor is working right. Or Is the fan in the freezer running. It has to blow the cold air around the freezer and to the fridge side. It may cut off when the door is open so hold the door switch in to check. The humming in the freezer could be the fan trying to run but can't because of a defective fan or being blocked by somthing.
Sep 02, 2009 | Candy CPCA270FFK Bottom Freezer...
Indesit fridge freezer clicking relay and lack of cold
Replace defrost snap disk............
Aug 18, 2009 | Refrigerators
Indesit fridge/freezer model ban 12nf the fridge has stopped getting cold but the freezer is cold and the compressor is working its frost free but suspect it might be frozen and stopping the air flow to...
numerous faults can cause this - faulty defrost timer or module, open circuit defrost heater, open circuit thermal cutout, internal wiring, faulty defrost sensor etc
Nov 28, 2008 | Refrigerators
Indesit BA139 fridge freezer with very thick frosting on back wall, but not very cold fridge section (despite changing the temp control to max) and normal very cold freezer section. When temp control...
One or more of your defrost components(defrost timer or board, defrost heater, defrost thermostat/ bi-metal) are bad. Unless you removed the inside back wall in freezer and completely thawed the evaporator, it will not cool properly.
Aug 25, 2017 | Refrigerators
Indesit Fridge Freezer
YOUR DEFROST TIMER OR A BURN OUT DEFROST ELEMENT
Oct 17, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge freezer not getting cold (2 years old)
I would first check to see if the evaporator in the freezer is all iced up. If it is thats whay you do not have any cooloing. And If that is the case you have a defrost problem and it is not short on gas. If you see only a few coils on the evaporator frosted up then you do have a leak in the system and my be covered under the manufactures warrenty.
Jul 14, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Refrigerators Logo
253 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
