Plug in ariel, switch on , led goes from red to green, after approx 2 seconds the screen is blue for a split second with writing to top left hand of screen then goes blank, there is sound but no picture
The backlight led is burnt out, time to replace with new one. Most of the time it’s only 1-2 led are burnt. You need an electronic technician though. I may guide you if you want further assistance.
It is not with the problem to any capacitors. It is the problem with its main board itself. There should be shorted component/s at it. The short circuit protection function activates, and that why you're seeing a flash on the screen. Contact any service technician to troubleshoot. This is not a user repairable fault.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
I have a UA40EH5000M samsung led tv. Suddenly the screen went blank. only sound is there, no display. Which part may have the problem..please suggest..
your cable is split into two different connections for your tv... the red green and blue cables are for HD only. They are their own little set. the yellow cable is your video cable for normal tv's. the red and white cables are sound cables, also for normal tv's. I would unplug the red, green, and blue cables, and use the yellow, red (right sound), and white (left sound).
Most likely - the CCFL backlight is not getting the power it needs to come on. You can verify by shining a light on the front surface of the set - if you can just make out a dim image, then that is it. On some sets, the CCFL can be seen through the vents on the rear.
WHEN I TURN ON MY TV THE LED IS RED THEN GREEN AND GOES BACK TO RED AND NO IMAGE. WHAT COULD IT BE, i ALSO DID A HARD RESET BY REMOVING THE WIRES AS THE TECH HAD SAID AND NOTHING.
