Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Screen shows mono. how to get back to channel view. TV connectionn thorugh set top box.
  • 17 Answers
SOURCE: Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Posted on Dec 31, 2007
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Posted on May 30, 2008
SOURCE: Mono Vs Stereo
Here is what I found out. I had this same problem. I have cable TV and the signal coming into my house was not very strong. They 'boosted' the signal and this problem stopped. Along the way, they tested that the cable line had been passing through a splitter, so that to the house the signal was good, but by the time it passed all of the splitters, the signal was not strong enough. Now all is well and the problem does not happen anymore.
Posted on Aug 12, 2008
roety
  • 585 Answers
SOURCE: My Sharp Flat Panel Television LC19SB25U has Picture but No Audio
Sharp has had a few problems with their audio boards, not finding any bulletins on this model, but a few complaining about low audio on amazon reviews section. If using an antenna you will experience some channels with low audio. If using cable you should get good sound on all channels..
the 9.1 and 9.2 are digital channels and sharp does display them for at least a few seconds when you switch to that channel. Check all your setting in the audio to Stereo never SAP. To options for you are get a cable box, first check in the back and see if there is another coax in, if there are two try both rescanning after connecting.
GD lk
Eric
Posted on Aug 16, 2009
  • 1156 Answers
SOURCE: Hi i have a Toshiba
Hi,it's not a problem from your TV, you will need to contact network provider for freeview,but before doing that, make sure you check from your next door neighbors if theirs are working fine..
If theirs are working fine, that means you might need to troubleshoot your connections and cables..
that will do..
Take care,,
Posted on Jun 16, 2011
My samsung lcd tv stuck on bbc 1 on mono it wont go off screen
pl.see whether the other channels were locked inadvertently 2)if you have set top box remove the connection and connect the cable to antenna slot if you could change channels set top box is defective other wise tuner problem
Feb 18, 2015 | Samsung LN32A330 32 in. LCD TV
Unable to view TV programming on TV, able to utilize set for viewing DVD/VCR movies. Cable company says their Cable Card is 'OK' and the TV needs updates (assume software) in order to work correctly with...
U get a channel numder and menu screen do show up?Not the tv,it the incomming broadcasting signal cable plug in or the cable box itself have problems.Tries unplug,replug the tv and the cable box back in like about an hour later.The tv will reset itself to the factory setting and the cable box should upgraded it softwares.Should work now.If have the same problems,tell the cable company change the cable box or check the incomming broadcasting cable wire with another tv,see the incomming broadcasting signal cable wire,with a new cable box,see if it work.
Oct 21, 2010 | Toshiba 46HM95 46" HDTV
Audio keeps switching from mono to stereo
on every channel ? then av board is failing
on a single channel then it is their signal not you set
Nov 24, 2009 | Sharp LC-32SB21U 32 in. LCD TV
GD lk
Eric
Aug 16, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Cant get mono off tv screen ..
The TV set itself will probably have a button that is marked either "Video," "Input" "Source" or "TV/VCR" - I would need to have your exact television model # to be sure. Make sure the cable box is on. Press the Video/Input/Source/TV/VCR etc button and see if your cable picture reappears on one of the source channels. If your television is connected to the cable box with a standard coaxial cable, then Ch.3 or Ch. 4 would be the right choice. If you have a digital cable box, however, the cable is probably going to be on an auxillary channel. If you give me the exact model # of your TV, and the type of wires that run from your cable box to your TV, I can give you more precise instructions. Good luck!
-Tha Mp3 Doctor
Feb 11, 2009 | RCA M4204 MP3 Player
Can't view all my channels on LXI series TV
For anyone with a set with this problem that is older----IT DOES NOT HAVE THAT PART OF THE CABLE BAND BUILT INTO IT--only solution is either to put a cable box to it or buy a new set.
SD TECH
Nov 20, 2008 | Televison & Video
Stereo/Mono Fluctuation Screen Display Problem
I had the same problem.
All I did was unplug the standard cable wire from my tv and used RCA cables to connect my TV to my digital cable box the the Input 1 jack in the back. It also increased the video quality.
Aug 07, 2008 | Sharp LC-42D64U 42 in. LCD HDTV
May 29, 2008 | Televison & Video
Channel box appears on screen with "Mono" flashing. When this appears on screen remote will not operate tv. Also, if TV is turned off will automatically come back on in about 5 to 10 minutes
I have a similar problem with my LG LCD TV Model 42LC7D. Manufacturer has service bulletin on my problem, may have service bulletin for your problem also.
Jul 18, 2007 | LG M4200C 42 in. HDTV-Ready LCD Television
Mts:mono mode and just keeps scrolling through channels
take that tv to a tech you bought that set deffected .or take it back to where you buy it from.but my advice is that you take it back to where you buy it from.as you will pay double.repairs and what you have already paid for the set.good luck
May 02, 2007 | Apex Digital GT3215 32" TV
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
353 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
