Question about Indesit Washing Machines
Indesit wax120 dial keeps turning and clicking when attempting a wash cycle. Does this on all cycles. Water enters the powder drawer then dial just starts to rotate and click on every setting.
    President:
  • 1,462 Answers
These machines are a pain for this. you can only check the obvious - check filter not blocked, power up pump independantly and check it works, check heater element. if all these ok then fault is probably in module - if so, not worth repair
Posted on Jun 19, 2008
Indesit wia 101 stuck on one part of cycle and won't move on
check pump for blockage remove plug for 15mins re try
Apr 19, 2015 | Indesit Washing Machines
Indesit 657w
CHECK TO SEE IF THE DRAIN HOSE IS RAISED ABOVE THE REQUIRED HEIGHT. IF THE WATER IS OVER FLOWING THE TUB THEN IT IS USUALLY THE A BLOCKAGE IN THE PRESSURE SWITCH HOSE, OR SOME INABILITY OF THE WATER LEVEL SWITCH TO MEASURE THE AMOUNT OF WATER IN THE TUB.
Dec 23, 2013 | Washing Machines
Leaking washing machine
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.
If helped, click.
Apr 14, 2013 | Indesit Washing Machines
Indesit Washing Machine WM12X... Were Should The Water Level Come 2 On A Wash Cycle..
The water level will never go above the lower part of the door bowl. Can you be a little more specific on your question?
Regards
Sussex Engineer
Oct 22, 2009 | Maytag MAH6500 Neptune Front Loading...
Indesit programmer has a mind of its own
I have LG Washing Machine WF-S6607 when I START after 5 Second it will be stop and alarm to come up on Rinse MODE. what I do?
Oct 17, 2009 | Washing Machines
Indesit washing Machine W93
Pump or hoses still blocked,Or pump has had it,Can supply new pump by post if req.
Sep 18, 2008 | Indesit W 123 Front Load Washer
Water leaking out through powder drawer
please take your drawer out and give a good clean also look inside when drawer is out and clean there as well good luck regards jason
Jun 13, 2008 | Indesit W 123 Front Load Washer
Indesit 1200 washer/dryer instructions
probable cause is just poor water flow from outside. switch water off. undo hoses and check not kinked. in each hose, there should be a gauze filter. clean this. look inside the valve spigot and check no dirt buid-up. put hoses in a bucket and check water flow is ok. remove drawer and check holes in top of box are clear
Jun 14, 2007 | Indesit WA 115 Front Load Washer
Water leaking and dial spinning
unconnected faults. does water come out of drawer when filling? if so fault is a blockage in hose down to tub from drawer or drawer may need cleaning if fault happenns on rinse. fault on knob is broken inner knob and poss cam as well
Mar 14, 2007 | Zanussi FLA1201W Front Load Washer
Washing Machines Logo
295 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
