Question about Pride New Jazzy 600 Power Wheelchair by Mobility
WHEN I PRESS THE POWER BUTTON THE BATTERY CHARGE LEVEL LIGHTS BEGIN FLASHING FROM RIGHT TO LEFT FOR ABOUT 10-15 SECONDS THEN BEEP ONCE AND SHUT DOWN. THE BATTERY IS ABOUT 76% CHARGED AT THIS POINT. I PUT IT ON CHARGE ABOUT AN HOUR AGO. WHILE CHARGING FOR 30 MINUTES I TRIED TO POWER UP WITH THE SAME RESULT. GOD BLESS FOR THE ANSWER.
  • 692 Answers
Biqiu Check out my tip on getting your chair out of lockout or sleep mode this should help with your problem Good Luck
Posted on Nov 16, 2010
Flashing LG logo
Hello My Dear Costmour:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 28, 2012 | Pantech Cell Phones
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    HTC Vivid won't turn on
    5.Wait 10 seconds.
    Step
    Thanks
    Aug 04, 2012 | HTC Vivid
    What is the pairing security code for xx3 plantronics
    The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
    1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
    2 - Then you need to place the headset in pairing mode so your phone will find it.
    Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
    The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
    For the Plantronics M3000/M3500 (discontinued):
    Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
    For the Plantronics 510 Voyager:
    Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
    Plantronics Explorer 320,330,340 & 350
    Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
    Plantronics 655, 665
    Plantronics Discovery 640, 645, 640e
    Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
    Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
    pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
    pulsar_260_128.jpgPlantronics Pulsar 260
    For the Plantronics Pulsar 260, Begin with pendant powered on.
    Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
    indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
    enter 0000.
    For the Plantronics M2500 (discontinued):
    Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
    For the Plantronics M1000 (discontinued):
    Hit and hold the volume/mute switch in until the indication light starts blinking.
    For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
    For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
    You can also use the Plantronics Bluetooth Pairing Guide
    Feb 05, 2011 | Cell Phones
    Where it shows the charge of the battery it keeps running across the screen and you can't use the wheelchair. It won't move. It does this every time after taking it off the charge.
    Spot does the lights scroll from left to right or right to left? If they move from right to left then shuts down completely then the chair is in lockout or sleep mode. To unlock - turn the chair on and immediately press the horn button twice ( beep beep) This should get it out of sleep mode. Now if the lights are scrolling left to right then the chair still thinks it is being charged and the inhibit function is bad. You can call your local provider to have a tech check it or you can call Repair Xpress at 1-877-581-3733 to check it they have atech in your area to check it. Hope this helps
    Aug 29, 2010 | Invacare Supply Group Invacare Pronto M51...
    What does it mean when the ac button lights are blinking the ac buttons-ac and circulating button lights blink continuously and you cannot shut them off at all this just began after the car wouldnt...
    it is needing to be calibrated because of dead battery.i cant remember for sure but i think you had to push rear wiper and recirc buttons at the same time and hold them down a couple of seconds. engine has to be running and at normal operating temp. lights will flash and vents will change heat to cold etc. if it fails any test the lights will just keep blinking untill repaired and recalibrated.
    Jun 24, 2010 | 1997 Dodge Grand Caravan
    My screen won´t turn on and the lights above the left caps button and the scroll button are flashing three times.
    Power drain would be a better solution in this case.
    1.first shut down the comp
    2.unplug the charger
    3. remove the battery
    and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
    Jun 10, 2010 | HP Pavilion dv6000z Notebook
    Lenovo Y530 T 3200 3GHZ 4G Laptop not charging battery when plugged into outlet;also does not work on battery alone even though it is charged to 85%
    Try to perfrom power drain. You must first turn off the computer. Take out the battery and unplug the power adapter. Press and hold the power button for 30 secs. Put the batter back in, plug in the power adapter and power ip the computer then observe.
    Let me know if same issue will happen.
    May 11, 2010 | Lenovo IdeaPad Y530-3231U Laptop Computer...
    My Kodak V1003 will not charge.
    1. Make sure the Ni-MH rechargeable battery is in the camera.
    2. Place your camera on the printer dock.
    3. Press and hold the Battery charging lights/Refresh button, until the Battery charging lights begin flashing green (approximately 5 seconds).
    Aug 05, 2008 | Kodak Cameras
    Pride New Jazzy 600 Power Wheelchair by Mobility Logo
    314 people viewed this question
    Top Pride Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Colin Taylor
    Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
