Question about Mitsubishi MS12TN Air Conditioner
I have a Mitsubishi split air conditioner; Model number: MSH-18NA. When I turn the air conditioner on with the remote control, sometimes it works normally, sometimes it doesn't. When it is not working properly, sometimes the fan turns continuously and sometimes it doesn't. No matter whether the fan is working or not, no cold air comes out. The green operation light is blinks and the indicator light is off. It looks like the outdoor unit is not working because the outdoor fan is not moving. What would be causing this problem? Is it possible to have someone fix it? And how much would it cost to get it fixed?
  • 3 Answers
SOURCE: Mitsubishi MSH 18NV no heating or cooling
You need an hvac tech to repair this unit. Good luck!
Posted on Feb 05, 2009
SOURCE: not working probly two flashs then pause
The two flashes are telling you what's wrong with the unit. Take the cover off of the unit inside(evaporator) and there should be a guide on the panel with the wiring diagram. On this diagram there should also be a solution to what each blink means. One blink means this, two blinks mean that, etc... Hope this is helpful.
Posted on Mar 14, 2009
  • 534 Answers
SOURCE: outside unit fan not turning no cold air inside.
Ok here we go. It is possible that the capacitor for that fan unit is out or the motor for that unit is out. Without the proper tools i.e. an electrical meter, there isn't really a way to test the unit. The remote should not have anything to do with the unit activating if the is a manual thermostat. I suggest checking to see if either the motor has gone bad or the capacitor has bit the dust. If you have the motor changed make sure to replace the capacitor
Good Luck on your repairs hope I helped you some\
Dave
Posted on Jan 08, 2010
Testimonial: "A very quick response with a helpful reply. "
heatman101
  • 43501 Answers
SOURCE: Mitsubishi Air Conditioner blinking Problem
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Posted on Aug 20, 2010
heatman101
  • 43501 Answers
SOURCE: Mitsubishi split-type air conditioner model
heatman101
I have an mitsubishi msh 17d and i have lost the remote control hoa i can start it without the remote control?
Have you tried looking up a app on a smart phone. I use my Note 4 to control my t.v., cable box and bose stereo.
Jun 21, 2016 | Mitsubishi Heating & Cooling
I have a Mitsubishi Split model MSH-09NV but not turn on, and the leds are off. The Split not work with bottom emergency neither.
Ensure power supply is correct and you have correct live and neutral and Earth at unit, test power across live and neutral to see voltage at outdoor unit terminals
Dec 04, 2015 | Mitsubishi Heating & Cooling
Mitsubishi split-type air conditioner model MSH-26SV. When the unit is switched on, the 2 green lights on the front panel light up normally but but the unit doesn't work at all and, after a few minutes,...
Hi I have Mitsubishi split unit which is 5 years old. when turn heat mode for 30 deg C on the remote condesing unit runs for about 6 minuts and stops. what would be the Technical problem ?Thanks an Apprentice.
May 23, 2010 | Mitsubishi MS09TW Air Conditioner
What is the refrigeramt capacity of the model
heatman101
May 18, 2010 | Mitsubishi MXZ30TN Air Conditioner
Air not cold...model MSH-18NV no operating manual for remote . Not sure how to set to cool air when remote reads "I feel..." choices are cool dry or warm but when set on cool 20degrees, luke-warm air blows...
Hi FixYa team. After about 2 hours on the internet I managed to find a PDF file of the operating manual for my air con.
Thankyou for your prompt response. I'll be using your services again!
Jan 11, 2010 | Mitsubishi Heating & Cooling
Outside unit fan not turning no cold air inside.
Dave
Jan 08, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Got mini split, lost, remote control, bought
Don't know a code for a universal remote, but you can order a new remote from an appliance parts supplier. If you have the model you posted under, the part number would be WJ26X10152 . (about $25) Make sure you have your exact model number from the model / serial number tag off the product to make sure you get the correct remote.
Jul 29, 2009 | GE AJCQ08ACB Air Conditioner
Hi my name is adriana and I was wondering if you have the mitsubishi daiya packaged air con. My problem is that our remote control is not working cos the remote melted on the canara, which the back of it...
Have you tried calling the manufacturer at 800-332-2119 to get a new remote yet? If they don't have one, then a supplier should and I can get a number or website for you but Mitsubishi should have one.
Benjamin
Mar 20, 2009 | Mitsubishi MS-A09WA Split System Air...
Not working probly two flashs then pause
Mar 14, 2009 | Mitsubishi Heating & Cooling
Remote Problems
do you have any CFL's in the room try turning these lights off as I have seen these effect some remote control systems
Feb 27, 2007 | LG LSC121PMA Split System Air Conditioner
Mitsubishi MS12TN Air Conditioner Logo
127 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
