Available software PC-Designer for Windows v 2.2 available worked OK with Windows XP [32 bit] but with new computer using OS Windows 7, it will not work. Is there an update or new driver available from ANYWHERE? Pfaff themselves have not as yet addressed the problem themselves for older embroidery machines.
    Brigadier General:
  • 4,044 Answers
I wasn't able to locate any updates for PC-Designer however this is a common problem. Windows is always changing something that interferes with some programs. Until Pfaff comes out with an update your choice is limited to attempting to use the program in compatibility mode. If your Windows 7 is 64 bit, and it most likely is, that is probably the largest part of the problem. Windows is notorious for having problems running 32 bit programs on 64 bit systems. They just aren't very forgiving. You can set this for compatibility mode by right clicking the program start icon, selecting Properties then clicking the Compatibility tab. When you check the box to run in compatibility mode you can choose which previous OS to emulate for the program. This should resolve the issue. You may need to select to run as administrator to do this or be logged in as administrator to complete the change.
Posted on Nov 14, 2010
Voyetra midi orchestrator
The only Voyetra Midi Orchestra Plus software I can know was written for Windows 3.1 and Windows 95. Thus there are several reasons for it to be incompatible with Windows 8. First, it was a 16-bit software; the most common Windows 8 installs use a 64-bit OS. This means that the OS has undergone a number of major changes. The installers are completely different (format/way of talking to the OS). The DLLs that communicate between the software and the OS have also changed. The drivers for MIDI devices will be totally different in the modern OS.
The documentation for Voyetra Midi Orchestra is available here: http://www.turtlebeach.com/support/files/241/ . It is a discontinued product and no one at the company that owns it will be writing a new version of the code for Windows 8. I'm not sure this software will work in Windows 7 32-bit. You might be able to use the software in a compatibility mode from a virtual version of XP. For Windows 7 Pro, Virtual PC and the XP mode package are available as free downloads and can be used if your hardware allows. Windows 8 Pro has Hyper-V but requires a licensed version of any Windows OS that you want to use. For non-pro versions of Windows software, you would need to buy a Pro upgrade. The alternative is to obtain another Virtual machine software (VMWare, for example) and a licensed copy of XP or an older version of Windows. (OEM Windows 7 Pro licenses are still available from many computer hardware vendors.)
I hope this helps.
(Many 32-bit device drivers don't work under Windows 8; older software that didn't run under Windows 7 have similar problems.)
Nov 29, 2013 | Yamaha Music
Fp3 player driver for windows 8
Unfortunately, your laptop probably has Windows 8 x64. Fisher Price never made drivers for any Windows 64 bit OS. If you had a 32-bit version of Windows, I'd suggest the Fisher Price Windows Vista and 7 software. It's available here: http://service.mattel.com/us/technicalproductdetail.aspx?prodno=K3420&siteid=27&catid=516 .
You could try upgrading to Win8 Pro and using Hyper-V to install a legal copy of XP 32-bit (if you can find one), then use the virtual copy of XP to connect to the FP3. (Windows 7 Pro and Ultimate offered Virtual PC with XP mode to get a copy of XP 32-bit without the expense of a licensed copy.) Otherwise, you need a computer with an older and 32-bit OS. However, 32-bit OS's are limited to a maximum of 3GB of memory.
I wish that I had better news for you.
Apr 21, 2013 | Fisher Price Kid Tough Fp3 Song Story...
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
I have a ce-100 futura sewing machine that will not work with windows 7 what do i need to do to fix this problem
The Futura software and the machine drivers exist for Windows 98, NT, 2000, ME, or XP. If you have Win7 32-bit, you may be able to run in the compatibility mode. Load the CD into the optical drive, then right click on the .exe file on the CD. Then choose Properties. Select the Compatibility tab and check Run this program in the compatibility mode. Click Apply and OK. Then right click again and choose Run as Administrator. This isn't guaranteed to work since the changes in the OS are significant.
To check if you have Win7 32-bit or the 64-bit version, click Start > Control Panel > System and Security > System. The title will say Windows 7 (Version) for a 32-bit OS. It will read Windows 7 (Version) x64 for the 64-bit version of the OS.
If you have the 64-bit OS or the compatibility mode doesn't work, you need a computer running an older version of Windows. This can be a second computer, a dual-boot computer (where you select your OS at startup) or a virtual computer (that runs inside the real computer). If you have Win7 Pro or Ultimate or upgrade to one of those versions, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from the above site in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS.
I hope this helps.
(The last person I dealt with with the issue of an embroidery machine not talking to Windows 7 kept their old Windows XP computer just to work with the sewing machine. Fortunately the old computer was still working enough to use for the purpose.)
Jun 28, 2011 | Singer CE-100 Futura Computerized Sewing...
Hi!... I am using window 7 ultimate 64 bit. I am facing the problem of full HD. earlier when me using window Vista that has been ok. If there is any solution plz let me know!.. thanks Moiz Raja
windows 7 os requires atleast 16GB avilable space while windows vista requires atleast 15gb. It could be true that your system requirements are not sufficient for the new os you want to install
If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
  • DVD-ROM drive
If you want to run Windows Vista on your PC, here's what it takes:
  • 1 gigahertz (GHz) 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) of system memory (512 megabytes (MB) for Home Basic)
  • 40 GB hard drive with at least 15 GB of available space (20 GB for Home Basic)
  • Support for DirectX 9 graphics with WDDM and 128 MB of graphics memory (32 MB for Home Basic)
  • DVD-ROM drive
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 17, 2011 | HP w1907 LCD Monitor
Trying to install software for x4270 into new machine with Windows 7. Tells me software not available in English. Was previously installed with XP in old machine with no problems. Any ideas?
Uninstall the existing Lexmark X4270 printer driver from your Windows 7 by going the Start menu ? Programs ? Lexmark 4200 Series ? Tools ? Uninstall. Reboot pc when prompted. When pc turns on, check if your Windows 7 is running on 32-bit or 64-bit operating system by going to the Start menu ? right-click on Computer ? click on Properties. Take note of the system type.
Download and install the X4270 driver for Windows 7 using the links below:
Follow the instructions in the software.
Thanks.
Nov 18, 2010 | Lexmark X4270 All-In-One InkJet Printer
Is it possible to upgrade windows xp professional x64 to windows 7 professional x64
Hello
Yes it is.
Just make sure you download or purchase Win 7 x 64.
If your doing the upgrade you need to have winxp x 64 installed on your pc first.
Jun 10, 2010 | Microsoft Windows XP Professional for PC
When we try upgrading xp to windows 7 the upgrading failed because our cpu is old can i upgrade my xp to windows 7 using a old cpu or use a new cpu
NO you cannot, on that same computer, no matter what OS, because, you MUST change your central Processing Unit, CPU. To allow Windows 7 to work correctly.
Feb 07, 2010 | Microsoft Windows XP Professional
I can upgrade to windows 7 in my n1000
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Personally i would recommend to upgrade ram then install win 7
Regards
Uttam
Windows 7 requirement If you want to run Windows 7 on your PC, here's what it takes:
http://www.microsoft.com/windows/windows-7/get/system-requirements.aspx
Here is you laptop spec
Processor Processor Intel Pentium M 733 / 1.1 GHz
  • Core voltage technology Ultra Low Voltage (ULV)
  • Data bus speed 400.0 MHz
  • Processor features Enhanced SpeedStep technology , Power-optimized processor system bus
  • Chipset type Intel 855GME
Cache Memory Type L2 cache
  • Cache size 2.0 MB
RAM Installed Size 512.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory specification compliance PC2700
Video Graphics Processor / Vendor Intel Extreme Graphics 2
  • Video Memory Dynamic Video Memory Technology 2.0
Operating System / Software
  • OS Provided Microsoft Windows XP Professional
  • Software Drivers & Utilities
Dec 10, 2009 | Averatec 1000 Notebook
Cant load my hp psc 750 onto vist
Hello found on web: Good Luck :0)
Which operating system is used with your product? » Microsoft Windows 7 (32-bit) » Microsoft Windows 7 (64-bit) » Microsoft Windows Vista » Microsoft Windows Vista (64-bit) » Microsoft Windows XP » Microsoft Windows XP x64 » Microsoft Windows 2000 » Microsoft Windows ME » Microsoft Windows 98 » Mac OS X » Mac OS 9 » Linux
Don't see your operating system? If your operating system is not listed, HP does not currently have software or driver downloads available for your product for that operating system, or they are not available in the language you have chosen. To look for a driver in another language, change the software/driver language by clicking the "Change your software/driver language:" link on this page to see what drivers are available for your operating system. Here is link if you need it: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=57769&lc=en&cc=us&dlc=en&lang=en&cc=us
Nov 07, 2009 | HP PSC 750 All-In-One InkJet Printer
Computers & Internet Logo
David Payne
David Payne
