Question about Canon imageRUNNER 210S Copier
What does the fixing film look like?
I was given this copier, but I am afraid in the moving process, the film was jarred. Please advise what I am looking for.
    Problem Solver:
  • 5 Answers
The fixing film is a thin ribbon of plastic material inside the fixing assembly. the hot area inside the lefthand door. It really cant be jarred during the moving and if it was it would correct its self at power up.unless you are experiancing an E007. perhaps you can provide more info as to why you believe the film was moved then i can be of more help
Posted on Jun 19, 2008
How can I resolve canon photocopy machine with system error E007?
Its the problem related to fixing film assy. The sleeving tube over the heater might be broken. Replacing either fixing film assy.or the sleeving tube may correct the error. In very rare case other like sleeving tube rotation sensor or harnesss or DC CON board fails. Still its very rare.
Jan 29, 2015 | Canon Office Equipment & Supplies
Good evening sir/madam: This is my problem. I can't use my copier, Canon iR2116J because everytime I switch on the machine System Error E007 appears. What shall I do? Please advise. Thanks a lot.
this is related to the teflon(fixing film) in the fuser unit. u have to replace it to get machine working . so better call a tech and get it replaced .u have to do so to make it working ,no other option.i can't explain u how to do so as it is trick and u might damage other parts and sensor's
Sep 22, 2011 | Canon imageRUNNER 2000 Copier
I am facing frequent tearing of fuser film code 00007.The engg. advised n converted 4570 canon to reduced speed approx 30-35 copies per min. but the problem persists after every 18000-20000 copies .Please...
if the fixing film keeps to wear down rapidly, the problem can be few things.
  1. Maybe the pressure between fixing film and silicon roller isn't good ( replace silicon roller, silicon roller bushings, and execute the nip check in service mode )
  2. Maybe that the fixing film isnt Canon and therefore lower quality.
  3. Maybe the fixing heater ( beneath the fixing roller ) has "nose" or place where the fixing film gets stucked or wraped. Change the fixing film assembly ( Canons film + heather in assy )
Hope that helps!
PS for service manual you leave your e-mail...
Aug 01, 2011 | Canon imageRUNNER 4570 Copier
I am getting the error E00007-0000 on the display of my Canon iR3300 printer.please advise how to solve the problem
Aug 29, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
My canon photocopier IR2016J show error code E007. Advise me on how to resolve it or reset it
my canon photocopier IR2016J show error download and stop averthing no any function. Please advise me on how to resolve it or reset it.
Aug 10, 2010 | Office Equipment & Supplies
2 pieces are jammed and I can not find access to remove
Is the paper jam in the fixing unit? The Hot area before the paper comes out? If so, I believe if you are looking at the exit section to the rear of the copier there should be a same Green lever that you can move and it will release the preasure of the fixing unit. The only bad news of jams in the fixing unit is if you have any pieces of Black plastic that have came out of the copier, you may have to change the fixing film.
Mar 19, 2009 | Office Equipment & Supplies
Canon i80 service error 5100
Hi guys,
Service error 5100 indicates that carriage return (CR) operation is not performed successfully. After the printer turned on, printer initialize some operation include CR operation. This error happens when carriage part (carriage unit) has problem when move right and left in initialization process.
This may be caused by:
  • Faulty carriage part so thatit cannot read film encoder properly. As a result, carriagepart move on uncontrolled.
  • Dirty film timing **** strip (Horizontal film encoder;available only ini series and above) so carriage part cannot read film encoder properly.
  • Another material (such as broken paper, etc) present in carriage path, blocking carriage part from moving.
To fix this problem you may try the following tips:
  • Check if any material present in carriage path; remove (clear) it
  • Check if film encoder is dirty; wipe slightly with moistened clothe.
  • At last, if carriage part is faulty you need to replace it.
Hope this will be helpful for you. Please don't forget to rate me.
Inkjet Printer Forum
Dec 24, 2008 | Canon i80 InkJet Printer
Printer is flashing checkprinter 5100
dear bria13,
Code 5100 indicates carriage operation error. The printer performs initialization process (include carriage unit operation) at first time we turn it on. During this process carriage unit will move right and left reading film timing **** strip. If carriage unit can read film timing **** strip successfully then it will move to home position (originally on purge unit part). Otherwise error code 5100 shows.
Here are possibilities and corrective actions:
  1. Film timing **** strip become mist caused by grease or ink; wipe film timing **** strip with moistened cloth.
  2. Carriage unit faulty;replace carriage unit.
Find more article about canon ink jet printer here and please give your rating
Nov 09, 2008 | Office Equipment & Supplies
I have System error E007 problem in my Canon iR-2016 copier machine
System error e007 for canon copier ir2016j copier needs solution
May 23, 2008 | Sharp AR-M350N Copier
Canon iR-2016 System erro E007
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Mar 15, 2008 | Office Equipment & Supplies
Canon imageRUNNER 210S Copier Logo
49 people viewed this question
old marine
old marine
