Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
My husqy 435 runs but skips and bogs when you give it gas! spark plug is good, air filter is clean. could it be the ignition pack?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 78 Answers
It could be the ignition module, but if since it is firing I would say it is a bad fuel filter. Try replacing it. Also, try using fresh gas. Mix a 50/50 gas to engine oil mixture and put that in.
Posted on Nov 15, 2010
1990 Toyota pickup with a Winnebago camper attached, okay first of all I changed the fuel filter, catalytic conv., did tune-up (spark plugs/ wires, air filter) set timing at top dead, checked basics, oil,...
I WOULD CHECK THE DISTRIBUTOR FOR PLAY ON THE SHAFT, ALSO CHECK THE IGNITION ROTOR AND DISTRIBUTOR CAP INSIDE FOR CORROSION, CHECK THE WIRE , ( SPARK PLUGS ) WIRE, CHECK THE CONNECTION INTO THE CAP. WHEN STARTS TO SKIP IS THERE ANY WAY YOU CAN CHECK THE SPARK, IF IT DOES NOT SKIP, CHECK THE SPARK ANY WAYS, SHOULD BE WITH OUT A DOUBT BLUE, NO YELLOW OR ORANGE IS NO GOOD, BLUE. LET US KNOW.
May 28, 2014 | Cars & Trucks
Spec vin ecu specs
If it turns, then the battery is OK. Either spark plugs are not firing in proper order (wrong firing order), no power to spark plugs, or no fuel because of fuel restrictions (dirty fuel filter). Inspect the air filter to ascertain its not clogged air. If you smell gas, then you saturated the spark plugs, which is why it refuses to run.
Let it sit for half hour to let spark plugs dry. Inspect to ascertain its not dirty spark plugs, which will also prevent engine from running. After ascertaining its proper firing order, spark plugs are clean, and there's power to distributor cap, ascertain there's fuel in fuel lines by squirting half second (short squirt) of starting fluid into air filter. Close the air filter housing to trap flammable starting fluid gas. Turn engine without giving throttle. Let starting fluid be ignited by spark plugs. If it won't start, then spark plugs are not firing to ignite starting fluid gas. If it starts briefly, but won't run when you give throttle, but catches when a 2nd person squirts more starting fluid into air filter just before engine stalls, then its a fuel restriction issue or no fuel in fuel lines.
Nov 29, 2013 | Cars & Trucks
Car idles fine but when you step on the gas it bogs down, and won't accelerate. The car will not go over twenty miles an hour.
what year.
ever tune it up,
no, then the fuel filter i packed, air filter same.
if it is tuned up and newer than 1996 and in USA, (are you)
then you can use any scan tool for $7 and read DTC errors.
to get power from any engine only takes these things.
1: DC power to EFI, a volt meter, proves this is 1min.
2: full compression,. 4 readings.
3: good spark at all spark plugs, 4 tests.
4: good fueling. (tool lean, bog, too rich misfire bog"violent")
there are 4 tests.
the tune up also cleans the EGR valve /
there are other rare failures but the above is the majors.
Oct 09, 2013 | Subaru Outback Cars & Trucks
Air filter on my 435 gets pluged up every 10 or 15 min. why?
It's not likely your air filter would plug every 10-15 min. I suspect you have a bad ignition module/coil. when it heats up running a circuit will open causing it to quit or bog. when it cools down circuit will close and it will run for a while again. It is a common test to use a freezing spray on electrical parts to find a problem.
Jan 09, 2013 | Husqvarna Garden
Ryobi weed eater stalls when giving it gas
check air filter and spark plug if good carb adjustment is needed or carb may be loose. could be bad fuel water in gas will cause this
Aug 26, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
2004 sportsman 600, bogs down bad at half throttle.
Check that your choke is working correctly
Your timing may be way off as well
Mar 08, 2010 | Polaris ATV
My tanaka chain saw wont idle and when i pull the gas trigger it quits or bogs down
clean spark plug and gap, remove air filter and clean, look at the spark plug and tell us what color it is, You may need to adjust the fuel mis to get it to run right or you may need a gas filter. Post here with more information.
Aug 28, 2009 | Tanaka Hedge Trimmers: 20" Dual - Sided...
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
100 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
