Aiwa 5200 3 disk stereo
This unit is about 12 years old but it works great except the cd tray does not line up exactly centered on the pickup unit . the cd sometimes loads off center and won't play. is there an adjustment for the tray alignment somewhere?
  • 4,234 Answers
These units do not have an "adjustment" per se. This can be caused by a bad sensor or a dirty sensor. The tray have slots in the bottom that are sensed to determine position. A loose belt, bad sensor or noisy power supply that causes noise on the sensor line all can cause this. DO NOT dis-assemble the tray assemble as the loading timing of these is not the most intuitive and is difficult to return to the correct position without a complete rebuild. This should not be an expensive repair. The sensor for this will be around $5. Add in the local labor rate for the complete repair cost.
I have done 100s of these over the years. Have the lens cleaned while the unit is open as well.
Posted on Jun 19, 2008
I have an old Aiwa NSX-V150M Compact Disc Stereo System. I cannot load CD's into the unit. Pressing the "Load" button causes the internal mechanism to cycle up and down 5 or 6 spaces and then a "CHECK"...
Hi! I also have an (old) NSX-V150M that does nearly the same, I suggest two problems on mine: 1) maybe the laser assy has to be changed because it doesn't detect the actual CD anymore and skips to the next one. 2) there is a tiny limiting switch on the moving platform that seems defective, or the rubber belt (?) is too stretched, so that it doesn't detect when the CD is in place from the changer. Then the unit starts again "CHECK"ing, as when the memorized list of CDs doesn't match the detected list of CDs. For the first one, maybe the Sony KSS210 or KSS213 spare part could be used, not sure of it. For the limiting switch, I have glued a match to keep it in place to keep the CD part quiet. Result: no more CD playing for now, but the unit doesn't "CHECK" anymore, and tuner and amplifier still work great. Need to look inside one of these days.
Jan 09, 2013 | Aiwa Audio Players & Recorders
I have had the CMT-NE5 system for four years now. Great little stereo. Recently anytime I try to play a disc I get the message "No Disc". I am using compatible disks, and have tried several...
Replace the flat strip wire that connects laser pickup unit to main board. If it does not help you, replace laser pickup unit with same typa and number. OK.
Dec 21, 2010 | Sony CMT-NE5 CD Shelf System
I have AIWA NSX-880 purchased in '99. During transportation it had got damaged. The CD part got damaged, the circuit got cracked. Recently gave it for repair, but I was told the CD tray cannot be repared....
This says Sony has taken it over, so Sony are unlikely to be interested.
AIWA Global Home
you might have more luck here
Aiwa Service Center in Hyderabad 040 24077328 Aiwa Repair Center in...
Or find someone like this
Aiwa CX NA555 Volume Repair
Basically you have an old and obsolete unit where no spares are available. This type of unit is deemed as a consumable unit, they break, you replace.
Nov 07, 2017 | Aiwa Audio Players & Recorders
I have two aiwa nsx-d737 stereos with basically the same problem. On the one, the CD tray will not oepen and the display shows that it is playing a CD when it's not. On the second one, the CD tray will...
Hallo! Mayby you can sell my one of your aiwa nsx-d737 stereos? I've been dreaming to get it for a long time, but I can't find it nowere in Russia. I ready to pay all transportation costs and expances. May I also ask you to write me back on e-mail even if you can"t or do not want to sell it?
A milliomn thanks))) Olga
Jul 13, 2009 | Aiwa Audio Players & Recorders
AIWA CD Problems
Sounds like the lasers need a POT (potentiometer) adjustment. Tools you will need are a multimeter with Ohms (preferably digital) either a #1 or #00 and #2 philips screwdriver. You will need access to the bottom of the laser. On the units I've worked on the POT faces the back of the unit. It will look like a philips head screw in a square metal casing. You should not need to completely remove the CD tray assembly but you can if you wish though I recommend removing the tray bezel Look for two legs on the side of the POT casing that go to the laser PCB. Measure the resistance across the two legs for an initial reading. On mine it was exactly 1kOhm. Now take the #1 or #00 philip screwdriver and adjust the screw to lower the resistance. POT screws are typically EXTREMELY sensitive so 1/16 of a turn can make a big difference. Start by lowering it by about 20-25%. So if the initial reading was 1kOhm aim for 750-800Ohms and test. You should use several disks for testing. If your unit is capable of CD-R/RW playback then have those available as they are generally more difficult to read. If you have playback gradually increase the resistance 5-10% until the disk is no longer readable or struggles to read. Now lower the resistance again 5-10% and retest. If all works well reassemble and enjoy. It is necessary NOT to lower the resistance too much as it will shorten the life of the laser and if too low could damage the disks. If you must go lower than 25-30% the laser is not worth salvaging. Typically 10-15% is all that is required. If you need more detail I recommend doing a search for 'xbox POT adjustment' as the procedure is essentially the same for all lasers and some xbox sites have good pictures so you can see what your doing before you dive in. Total repair time per unit will be 1/2 - 1hr, mostly spent in all the testing. Hope this helps. Good luck
Jan 03, 2009 | Aiwa NSXAJ70 Mini System Dual Cassette...
Aiwa Stereo
Same model, same problem. (CX NA-50) I have one that worked great for two years (at best) and I haven't used it since then. I recently decided to look for a solution via the internet.
I read somewhere else that there was a class action settlement with aiwa (now expired) since many of these units had this problem.
Oct 25, 2008 | Aiwa NSX-DS55 CD Shelf System
I have an aiwa nsx 5200 mini system the cd player broke
Soooooooo many people have complained about this system not reading discs properly, yet the solution is incredibly simple. All you need to do is calibrate the lens, and you can do this without even opening the stereo! Here's how:
With the stereo all unplugged, turn it around so the back is facing you.
Now use a flashlight and, looking through the grating on the back, approximate where you think the cd lens mechanism would be. You should see 2 8-pin connector wires side by side (one red and one white) and to their right a small black circle screw type thing.
Using a screw driver, turn the screw thing about 1/10 of a revolution clockwise.
Plug in, and test with a clean cd. If nothing happened, repeat the procedure turning the screw thing in tiny increments (don't over do it.) Eventually, the cd player should recognise the cd. Keep fine tuning and testing until you've found the "sweet spot" where it recognizes and plays cds optimally.
Overall, you should NOT have to turn any more than a full revolution, and even half a revolution is pushing it. What you are really doing by turning this screw is fine tuning the "data reading point" of the laser. Too close and it will focus on the area between the cd and the lens, causing failure to recognize the disc. Too far and it will focus past the data perhaps recognizing the disc but not being able to read it. I believe the major problem with these players is that as they settle in, the area between the lens and cd changes. This would cause a gradual degrading in performance until the player finally failed to recognise any data at all (which is exactly how mine went personally.) There isnt a problem with the quality of the lens itself, therefore it is very fixable!
I have heard that all 3cd Aiwa Mini-systems share this problem so, as long as the calibration tuning screw is exposed through the grating on the back, this fix should work for any of the Aiwa mini-systems with this particular problem. If the screw isnt exposed, it is still possible to get at by opening and dismantling the player. (Unfortunately, i did not originally notice that the screw was accesible through the grating, so i went about pulling the entire system apart and wasting hours of my life. You can thank me later for saving you this tedious trouble as you're listening to cds on your newly fixed player ;-) )
If this doesn't work, or doesn't fix the problem completely, try cleaning the lens. You can do this by either by using a cd lens cleaner (looks like a cd with a brush built into it) or opening up the stereo and using a soft cloth on the lens. You may also want to try putting the screw back to its starting point and using the same procedure but turning the screw counter-clockwise. (I personally had to turn clockwise but who knows, maybe your player settled in differently.)
As for the mechanism itself, i have no idea. I did notice, however, that the lifting mechanism sometimes picks the cd up off-centered causing failure to play. You can semi-fix this by holding the stereo at an angle while it picks up the cd or placing it off-centered in the tray. Its annoying, but it works :)
Feb 19, 2008 | Audio Players & Recorders
Just a question on specs for Aiwa NSX-5200 system
Hello I have had a look on the internet and found this for you it should let you download the user manual for free, good luck you should find out your specs - 49k -
Feb 18, 2008 | Audio Players & Recorders
142 people viewed this question
