Question about Car Audio & Video
I have a matsushita car stereo amp. model no. 10289187 ref. no. cy-bg2911zc i need to know what the 20 color coded wires go to such as 12v pos and speakers
pjstanley
  • 185 Answers
SOURCE: 08 ford fusion need to know the colors of both rear doors speakers
well first to decode the wire corlusthe darkest one is all wayz negtive. and a 18, or a 16 gauge wire should would work fine run it to ur amp from the fuse box let me no if that works
Posted on Apr 06, 2008
c17hydro
  • 2984 Answers
SOURCE: we need the colors of the speaker wires
I can email you the diagram...would be easier for you to see...but here it is in writing (we can't post pdf. files).
Right Rear Speaker-- yel/red & grey/red
Left Door Speaker -- wht/blu & blk/blu
Left tweeter -- org/blu & Brn/Blu
Left Rear Speaker -- yel/blu & grey blu
Right Door Speaker -- wht/red & blk/red
Right Tweeter -- org/red & brn/red
Posted on Jun 29, 2009
dnewcombe1
  • 1564 Answers
SOURCE: Pin out diagram for Matsushita Car Stereo model 39100-s9A-A2000
You've got to get that info from a dealer or audio installation specialist.
Posted on Jul 26, 2009
  • 160 Answers
SOURCE: I need a car stereo color coded wiring guide mitsubishi galant ES
They are very easy to find online. Just google wiring diagram for the make and model.
Posted on Aug 09, 2009
  • 436 Answers
SOURCE: need wiring color code for power &speaker
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Posted on Aug 25, 2009
Need to know from top left to bottom right what each wire goes to on power plug on jensen car stereo model vm9311
Hi Jeff, Thanks for the question. When wiring an aftermarket car stereo I always recommend purchasing a wiring harness that will connect into the vehicles existing harness, Then you only have to worry about connecting each wire to it's color coded counterpart. With that being said, if you do not have the stock harness I can explain the wiring colors to the best of my memory
Red = 12v Memory power
Yellow = 12v Constant power
Black = Ground
Blue/white = Power Amplifier
Blue = Power antenna
Grey = RF speaker (+)
Grey/Black = RF speaker (-)
White = LF speaker (+)
White/Black = LF speaker (-)
Purple = RR speaker (+)
Purple/Black RR speaker (-)
Green = LR speaker (+)
Green/Black = LR speaker (-)
Sometimes there is a dimmer wire also, usually orange or pink I believe
I hope this helps, & Thanks again!
Feb 18, 2014 | Car Audio & Video
How can you test a model 15762536 cy-bg8013zc amp. there is no sound in car stereo
What i would do is remove the amp and do a bench test. connecting it to a car stereo outside of the car This way you know it works or not without second guessing the wiring. I leave a Car battery on my bench for this.
Dec 26, 2010 | Panasonic Car Audio & Video
I am putting a CD player in my 95 accord EX and need to find the wire color code for the deck plug so I can convert them to the pioneer deck. The old cassette deck is a Matsushita Model# 39100-SVS-A400 and...
Here you go;
1995 Honda Accord Stereo Wiring Constant 12V+ Blue/White Switched 12V+ Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Trigger Yellow/White Antenna Left Rear Front Speakers 5 1/4" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6 1/2" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White
Nov 18, 2010 | 1995 Honda Accord
Can you tell me what a Matsushita Communications Industrial Corp Serial #353635 - Model #10449235 - Ref # CY-BG22612C - is?
It is an amp that goes to the soy d system of an early 2000s impala or monte carlo
Oct 10, 2010 | GPS
Amp wont turn on and theres power to the amp and the fuses are good
check the ground to the amp. then check the remote wire. make sure u have the sub option on ur stereo turned on. if all is wired up correct an u do not have the subs turned on in ur stereo settings then the stereo will not send power through the remote wire an therfore your amp will not power on.
Apr 04, 2010 | Rockford Fosgate Power T3002 Car Audio...
I don't know how to connect the wires from my JVC car stereo
Radio wire colors:
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
1991 Oldsmobile Cutlass Supreme Car Stereo Wire Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 03, 2009 | JVC KW-XC777 CD / Cassette Player
JUST NEED TO KNOW WHAT PIN RECIEVES THE B +
Ken,
Most common for all car Stereo wire color coding are:
Solid RED wire = +12V
Solid Black wire = negative ( - )
Solid Yellow wire = +12V (power ON /OFF) can add additional toggle switch for switching on and off the car stereo
Solid blue wire = Power antenna
the rest of the wires are for car speaker having positive and negative polarity.
note: for the speaker connection wires, all the solid colored wires are positive side (+) of speaker. those solid colored wire with stripe black line are for negative side (-) of the speaker
cheers,
mark
Dec 30, 2008 | Pioneer 12" Shallow Sealed Enclosure,...
Missing code
i have a 2002 honda accord stereo and i have the serial no,ref.no,and model no but i dont know to reset
Sep 30, 2008 | 2002 Honda Accord
Car Audio & Video Logo
82 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
