Put the dead drive in an external USB drive caddy and check that it really is dead. If the drive controler is actually the problem installing a new drive wont get the laptop going again.
You need this hard drive,
Toshiba p/n, MK2105MAT
simply remove the plastic cover from rear of laptop. a small icon or image of HDD insignia will most likely be on back, near plastic cover. remove the screws, there will be a tab to assit you in pulling out the hard drive from compartment. it may require you to unscrew more screws to release the hard disk drive.
once removed replace with the new one.
