Question about Cross Infoguard Shredder SX102M
I have an Infoguard Paper Shredder model sq70b. I need a replacement plastic gear. It got damaged when I tried to shred too many papers at once. It is the one that comes off the helical drive shaft (combo larger and smaller gear). Where can I obtain a replacement gear? Cost? Thanks for your help.
4 Suggested Answers
fellowesrep
  • 102 Answers
SOURCE: Shredder won't shred any more.
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Posted on Mar 02, 2008
You might have broken the actual mechanism enabling it to move forward. To be honest, your easiest solution would be to buy another shredder rather than attempt repair if this is the case, they're so cheap now.
Posted on Mar 27, 2008
venexcsd
  • 1185 Answers
SOURCE: Infoguard sq70b shredder is jammed. How do I clean it?
Press the reverse switch if the reverse switch does not work it is a case of removing the power then getting a small hook such as the ones used for needlework and picking out the jam
If it still wont run then it is a complete strip down job.
Depending on the cost of the shredder it is cheaper to replace the small home ones than it is to repair them.
Posted on Jun 01, 2009
I dont have the original bin for an Infoguard SX100M. It runs if I hold it and push in the red button with a screwdriver. When I try to load the paper, the shredder doesnt grab it. Any fixes?
I can't imagine holding the red bin interlock button depressed with a screwdriver every time I wanted to shred something but hey, whatever works!
Your shredder does not grab the paper because an internal "page in" sensor is damaged, defective, or blocked by shredded residue.
Aug 10, 2016 | Shredder Office Equipment & Supplies
My Shredder W11C stopped working suddenly both forward and backwar. The power source is O K.
if you can hear the motor working but the paper won't pull in and shred then you broke a tooth on the plastic gear. This happens when you try to shred too much at one time. It happened to me but I couldn't find a plastic gear or the company to replace the gear. I liked the machine so I made my own tooth with DEVCON home plastic welder. With a little ingenuity and some tools you could try to fix it. Or like someone said buy a new shredder
May 07, 2014 | Fellowes Office Equipment & Supplies
Spins and will not shred
Not real familiar with your particular shredder but most shredders have plastic gears that will break teeth so that you do not destroy the motor when a jam happens. My guess is that is what happened to yours. You can usually contact the manufacturer or a dealer to see if new gears are available. You will need your model and maybe your serial number when you call.
Aug 15, 2012 | HSM 225.2 Shredder
Infoguard-10 sx100m motor runs, sounds like gears are turning , goes both forward and reverse. i cleaned all of the teeth, looks clean, but won't accept paper. i am handicapped and am having a hard time...
When motor is running, look to see if the cutters are turning. The cutters can be seen by looking into the throat of the shredder. If the cutters aren't moving, the gears may have been stripped and shredder needs to be repaired or replaced.
Good luck...
Apr 15, 2011 | Cross Infoguard Shredder SX102M
Infoguard SX 120D Does not power up. No lights
There is a switch on the right side of the shredder itself which has to engage with a tab welded near the top of the basket. Make sure the tab is enagaging the switch. Also check the paper path switch right above the shredder bars.
If you cannot figure this out, please do not pitch the shredder. There a few people here (myself included) that need gears and such from this model. We would gladly pay shipping for such.
Thanks,
John
Feb 03, 2010 | Cross Infoguard Shredder SX102M
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
Infoguard SX100M unit will not shred. Green light comes on.
I have the Infoguard SX100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, red side switch, the gears and fuse were all ok, I think something on the circuit board was fried.
Anyways, I switched the BLACK and WHITE wires with each other going to the shredder motor, thus when I switched it to reverse, it would go foward and shred. Its working now, only in reverse.
Jan 10, 2009 | Cross Infoguard Shredder SX102M
Paper Shredder blades do not turn, even though motor is running
yes, it's the plastic gear that's shredded in this shredder. the drive gear on the motor is metal, as are the gears attached to blades. between is a single plastic gear which is chewed up the instant resistance is great enough. fabulous engineering. not a difficult fix, but where does one find the replacement part?
Jun 08, 2008 | Office Equipment & Supplies
Tech Solutions shredder
It sounds like you may have a gear with a broken tooth you should contact the manufacturer to get more info. Usually when this is the case it will shred good for only a few revolutions and then reversing backs the gear up to a position that allows it to turn the cutters until it once again reaches the area where tooth is missing.
Mar 11, 2008 | Winsource Tech Solutions TS-4500 Cross-Cut...
Sx-102M
I have the Infoguard SX-100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, the gears and fuse was ok, I think something on the circuit board was fried.
Dec 21, 2007 | Cross Infoguard Shredder SX102M
Cross Infoguard Shredder SX102M Logo
75 people viewed this question
Top Cross Office Equipment & Supplies Experts
Computer Links
Ivan
Ivan
Level 1 Expert
k24674
Are you a Cross Office Equipment and Supply Expert? Answer questions, earn points and help others
