It is saying that it requires windows 98 to install software?
    President:
  • 556 Answers
SOME SOFTWARE THAT REQUIRE
YOU INSTALL LATEST VERSION OF SOFTWARE
Posted on Nov 14, 2010
I'm trying to install a program but it is telling me it can't run, it requires run as. how do I fix this
This occurs when you are trying to install an older program on modern machines. Old DOS-based software can sometimes be run in a window, but may require much manual setup. Older Windows-based software may be restricted because the programmers, knowing the software would not run on Windows 95, let's say, had the software look for the Windows 98 identification. Unfortunately, while those programs may well run under Windows XP, since the program is only looking for Windows 98, it see this as in incompatible operating system. Therefore Microsoft gives you the ability to run these programs in a "run as" mode. You select which OS you wish the software to "see". So if your setup program won't run because of this issue, try this: Right click on the setup program icon, select the COMPATIBILITY Tab, and try using COMPATIBILITY Mode. Tinker with the setting and retry to load the program. Hopefully you have a good outcome. Of course the better solution is to get a version of the software that is updated and compatible with the current OS, but this is not always possible.
Jan 13, 2012 | E-Machines eMachines Desktop PC
I have windows xp and bought a pc rom at charity shop recently but computer will not play it, it says the sound software is not installed properly or disabled. what can I do?
Look at the system requirements on the CDROM - I've found that bargain CDs are often made for older versions of Windows (like Windows 98, etc...) and may not work on more modern versions of Windows.
If that's the case and you really want to run the software, you could install an older Windows on a separate computer, or else on your main computer but inside a virtual machine (sandbox) using software like VMware or VirtualBox.
Jan 12, 2011 | Computers & Internet
Can not load older software on new pc with windows 7
The software Broderbund 3D Home Architect Deluxe 5.0 might works with the earlier version of Windows and does not work with the latest version. Check out the system requirement for the software and its says its for windows 98, 2000 & Xp hence the updated drivers for the suite are not released hence it would not be able to install it on New windows version.
Jan 07, 2011 | Broderbund 3D Home Architect Deluxe 5.0...
:Error: the vc8 runtime Redistributable package was not installed successfully. Setup cannot continue
The Microsoft Visual C++ 2005 Redistributable Package (x86) installs runtime components of Visual C++ Libraries required to run applications developed with Visual C++ on a computer that does not have Visual C++ 2005 installed.
This package installs runtime components of C Runtime (CRT), Standard C++, ATL, MFC, OpenMP and MSDIA libraries. For libraries that support side-by-side deployment model (CRT, SCL, ATL, MFC, OpenMP) they are installed into the native assembly cache, also called WinSxS folder, on versions of Windows operating system that support side-by-side assemblies.
System Requirements
  • Supported Operating Systems:Windows 2000 Service Pack 3;Windows 98;Windows 98 Second Edition;Windows ME;Windows Server 2003;Windows XP Service Pack 2
  • Required Software:
  • oWindows Installer 3.0 Windows Installer 3.1 or later is recommended.
  • Disk Space Requirements: 6 MB (x86)
File Name: Size: vcredist_x86.exe 2.6MB Download
Jan 05, 2011 | Sony Computers & Internet
Message says that there is insuffient memory when trying to install or run Windoes 98Se on machine with 2MB Ram
FYI,
Minimum hardware requirements for Windows 98:
1. 486DX 66 megahertz (MHz) or faster processor (Pentium central processing unit recommended).
2. 16 megabytes (MB) of memory (24 MB recommended).
3. Hard disk space may range from between 120 MB and 295 MB, depending on your computer configuration and the options that you choose to install.
4. A full install of Windows 98 on a FAT16 drive requires 225 MB of free hard disk space, but may range from between 165 MB and 355 MB, depending on your computer configuration and that options that you choose to install.
5. A full install of Windows 98 on a FAT32 drive requires 175 MB of free hard disk space, but may range from between 140 MB and 255 MB, depending on your computer configuration and the options that you choose to install.
6. One 3.5-inch high-density floppy disk drive.
7. VGA or higher resolution (16-bit or 24-bit color SVGA recommended).
If your PC does not meet the above minimium requirements, you are bound to get errors popup installing or running software.
Hope it helps.
Oct 30, 2010 | Microsoft Windows 98 for PC
A printer error has occurred. See your documentation
What are the system requirements for using this printer? A: PC Compatible Requirements
- An IBM (r) compatible PC with at least a 486/66 MHz (for Windows 98) or Pentium (r) 133 MHz (for Windows 2000) processor (Pentium or higher processor recommended)
- Microsoft (r) Windows 98 or Windows 2000
- At least 16MB (for Windows 98) or 32MB (for Windows 2000) of RAM (32MB for Windows 98 or 64MB for Windows 2000 recommended)
- 50MB of free hard disk space (100MB or more recommended)
- VGA or better display adapter and monitor
- CD-ROM or DVD drive for installing the printer software
- USB connection: a computer running Windows 98 or Windows 2000, with a Windows-compliant USB port and a shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction. Apple Macintosh Requirements
- An Apple (r) iMac (tm) series or Power Macintosh (r) G3 or G4 with USB port
- For iMac: Mac (r) OS 8.5 or later (Mac OS 8.5.1 or later recommended)
- For Power Macintosh G3 or later: Mac OS 8.5.1 or later If your iMac is running OS 8.1, you need to upgrade your operating system before installing your printer software. To find out which operating system your iMac is running, select About This Computer from the Apple menu. If you're running OS 8.5 or 8.5.1 on your iMac, Apple recommends that you install iMac Update 1.1. Download the update for your system from Apple at http://asu.info.apple.com. Contact Apple if you have problems installing an update.
- 16MB of available RAM (more recommended)
- 50MB of free hard disk space (100MB recommended)
- VGA display or better
- A shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction.
Oct 27, 2010 | Epson Stylus RX580 InkJet Photo Printer
Windows vista (TM) Build 6000 this copy of windows is not genuine
Is this an error message? I'd say you should go see who installed the operating system on your machine. Otherwise you MUST go to microsoft and buy a new legitamate copy. All new microsoft products require registration. Running with bootleg software is not recommended
Jun 12, 2009 | Microsoft Windows 98 for PC
Can't download Itunes software required to Dell XP400 Windows 2007
If you have Windows 95/98/ME/2000, install Windows Installer 2.0
If you have XP or higher, install Windows Installer 3.1 - you might have had some computer geek friend uninstall Windows Installer 3.1, thinking they were "helping" you, or your computer never came with it in the first place.
Jun 10, 2008 | Apple iPod shuffle 3rd Generation MP3...
Loading software caused hanging on startup
May be your windows 98 is damaged and need to be re-installed. Even if you reinstall windows 98, there are more chances of your getting your documents back. I meant to say that just reinstall and to not format. you may get your windows running again. You should have your windows 98 installed with DirectX 9.0C and internet explorer 6.
Sep 29, 2007 | Ahead Software Nero 6.0 (60045) for PC
What are the system requirements of the DiMAGE 5?
System RequirementsIBM PC/AT compatible computer with preinstalled Windows Me, Windows 2000, Windows 98*, or Windows 98 Second Edition* and with a built-in USB port as a standard interface.Power Mac G4 (includes dual processor G4 and G4 Cube) series, G3 (Blue and White) series, iMac series, iBook, or PowerBook G3 with preinstalled Mac OS 8.6** – 9.1 and with a built-in USB port as a standard interface. • Problems may be encountered depending on what other USB devices are being used in parallel with this product. • Only a built-in USB port is supported. Problems may be encountered when the camera is connected to a USB hub. • Normal operation may not be possible even when all the system requirements are met. * Users of the Windows 98 and Windows 98 Second Edition must install dedicated driver software included in the DiMAGE 5 and DiMAGE 5 package. ** Users of the Mac OS 8.6 must download free dedicated driver software from the Apple Computer web site and install it.System requirements are based on the latest information available at the time of printing and are subject to change without notice.
Sep 15, 2005 | Konica Minolta DiMAGE 5 Digital Camera
Computers & Internet Logo
David Payne
David Payne
