Question about Refrigerators
My Maytag bought at Sears MSD2756AE startedd getting warm. I found it was frosted / frozen in the freeezer compartment. I defrosted the freezer and things seemed to retrurn to mostly normal but the fridge section of the machine was running warmer even though the setting was above (colder) normal. Now the fridge is getting warmer above 40 degrees and climbing. There are 2 plastic pieces which appear to be long plastic strips which fell out of the fridge portion when I went to take it apart (the machine had been previously serviced a few years ago for not working a part was replaced under warranty at that time. These parts have on the back side symbols and letters first symbol appears to look like an evergreen tree with arrows going up and down in a circular clockwise direction followed by >PS-HI< 78221 this is on the back of these two pieces 4 times. These don't appear to fit in the fridge anywhere. When we went to take the shelving sections in the fridge apart they just all fell into themselves without taking anmore than the top piece out. So I have no idea where (if) these parts go somewhere or not. The frige temp is still climbing and I have concerns as to what could be causing this. The freezer which was running at 0 degrees is now at -10 dgrees. I am questioning the defrost control on the freezer but am also questioning the fan which transfers cool air to the fridge portion as although the "flapper is moving it doesn't appear to be opening and closing fully or regularly. It does appear to be opening but only patially. This fridge was purchased new and from day one made an odd occasional clunking sound which stopped completely after I defrosted the freeer. I can't afford to replace this appliance at the moment and have been looking for a manual for this machine so I can do some effective troubleshooting. Any help would be greatly appreciated as I am now at a loss. complogic1@yahoo.com Ian Fraser
  • 3 more comments
  • complogic1 Nov 14, 2010
    Thank you for the info i will try this tomorrow and see what i find out
    If it does work then I will be happy until the next problem with this Maytag piece of *
    While we work on adding the Maytag MSD2756AEB Refrigerator manual, let's solve your problem
    the site about the manuals does not work i have tried 6 different attempts with different manuals and come up with the same comment. Please wait etc.
    Thanks for the info I will try it tomorrow.
    By the way the link to the manual site does NOT work they just come back saying please wait while we try and find a copy of this manual.
    Brigadier General:
  • 3,917 Answers
Thank you for contacting Fixya.com.
First let me help you with the internet link where you can find the exact manual for your fridge. http://www.manualsonline.com/ex/thread/view/idThread/3667718
The defrost thermostat is the correct part to be questioned in the issue your are facing. It contacts open at approximately +43°F. And close at approximately +15°F.The defrost thermostat has a 240K ohm resistor connected internally across the two terminals.
This resistor permits checking the defrost heater when the evaporator temperature is +15°F. or higher. You should also test the ADC. Before you do the ADC test, turn the Freezer Control all the way COLD, so that the Compressor is running. That way, you'll be able to tell when (and if) the ADC Relay clicks the Compressor off and should switch the Defrost Heater on. Also check the air-return vent behind the centre crisper drawer, there should be"cellophane" "flapper door" that you can see how much air is flowing: The Damper Door 1" x 4" plastic door Sears Parts $ 44 Repair Clinic $ 34.Therefore the three parts that you need to look for are:
Bad defrost timer, Bad defrost heater (in freezer), Bad thermo switch in freezer.
Please get back to us if you have any further query.
Posted on Nov 14, 2010
    President:
  • 1,796 Answers
I'll send you some diagrams by email
Let me know if you need additional assistance after that.
Thank yoiu for using FixYa.
Fridge is warm freezer is cold
Hello Abo Karin,
You are likely experiencing a DEFROST failure
(most commonly a defrost PCB failure)...
part number 67006740 item 5 on your exploded
case view (top center as viewed from the front).
There are typically only three (3) elements to a DEFROST
power control circuit:
- Defrost Printed Circuit Board ( PCB as noted above)
- Heater element to WARM the EVAPORATOR
- DEFROST thermostat... inhibit excess heat
(closed circuit at freezing - Opens at room temperature)
Check your defrost pan...
there should be water there DAILY...
IF not: you are assured that your DEFROST fails.
Per your DESCRIPTION...
You need to look for a SUDDEN REASON (huge air leak)
why FROST would form so quickly...
USUALLY a big pizza box... BUT ANYTHING blocking a
TIGHT DOOR SEAL will cause massive frosting.
It is taking moisture from the WARM ROOM AIR and blocking your evaporator...
a PROPERLY functioning defrost circuit would remove that frost
at least DAILY... and the EVAPORATOR fan would properly chill the refrigerated side blowing cold air from the FREEZER.
Yes ... all INTERIOR panels must be in place for the refrigerator to function properly.
Hope this helps
Your part... (see video instructions)
http://www.appliancepartspros.com/whirlpool-board-jazz-wpw10503278-ap6022400.html
Sears... (I don't USUALLY recommend for purchase)
http://www.searspartsdirect.com
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Repair-Maintenance/Questions-Answers/location-of-defrost-timer-on-sears-fridg/Model-59665932402/0582/0161000/338616?modelNumber=59665932402
also see other .com retailers
partsselect,
PartSelect Appliance Parts and Repair Help
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Apr 19, 2017 | Kenmore Refrigerators
Refrigerator doesn t get cold
If your refrigerator is frost free and been running for a year or two then here is the solution.
Why would you need to defrost a frost-free freezer? Because they do sometimes get frosted up! This is especially common if the door gets left open for long periods without being noticed, then shut again, thereby trapping lots of moist air in the freezer, which can only come out as frost. The problem is that if their defrosting cycles don't manage to cure their problems they get frosted up at the back, out of sight. If your freezer seems to be struggling to keep things frozen but is otherwise working normally you should consider defrosting it before concluding it is broken.
I have found the best way to defrost my not quite frost free fridge-freezer is to empty the freezer compartment contents into the fridge and switch it off overnight, leaving the fridge door shut and the freezer door open. By stacking all the frozen food together as tightly as possible, ideally wrapped in something to help insulate them (such as newspapers) they stay cold for a long time. In the morning I get in my scruffy clothes and wipe up the puddles caused by the visible frost in the freezer and any puddles formed underneath the appliance. However this is only half the story. To ensure all the frosting has been removed from the hidden parts of the appliance I get my hair dryer and blast warm air into all appropriate crevices from inside the appliance and from behind it.
Mar 07, 2014 | LG Refrigerators
Refrigerator temp is 66 degrees, way too warm. Freezer seems that all food is frozen and normal. I have opened the refrigerator several times in a fairly short period of time this morning. Set refrigerator...
Yes it does sound like it could be a component of the defrost system thats the problem OR the fan in the freezer that circulates cold air into the fresh food compartment
If ya see frost build up on the back wall of the freezer and do indeed hear the fan running it will be a defrost problem
if ya dont hear the fan in the freezer running thats very possibly the problem
GENE
Aug 29, 2011 | Amana ABB1922FEW (186 cu ft) Bottom...
Maytag mtb2156de freezer leaking through the top of the frig. The freezer is keeping things frozen, but water is running onto the floor.
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Aug 28, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Upright freeezer only gets to 32 degrees
have you checked the door seals on the freezer. sounds like its getting air into the compartment and causing the problem.
Mar 28, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer cold but things not frozen -frosting up. Fridge warm.
most of the time on ge its the defrost heater or defrost sensor in the freezer,that's why its freezing up.you can go to sears .com click on prats put in your modeal number and get yours parts-mike
Nov 30, 2008 | GE GTH18KBR Top Freezer Refrigerator
Refrigerator on the fritz
The defroster is not working. Ice build up prevents cold air from the freezer chest from blowing into the lower part.
The way the defroster works is this: There is a defrost timer, probably found under the refrigerator at the front, that turns on the defroster three times per day or so. That turns on a heater nested among the freezer coils. It keeps heating until the defrost thermostat gets warm; then it quits defrosting.
I think your defrost timer doesn't turn. You can turn it with a screw driver till you hear a click. Now your ice compartment should be defrosting. With ice buildup it may need lots and lots of defrosting. You might not get cooling back into the lower part for awhile, till the ice buildup melts.
By the preceding, you should know if the defrost timer needs replacing.
If you should need to manually defrost the freezer coils, they are, I think, under the floor of the freezer. To defrost them, I'm told, a hair drier works better than boiling water. The defrost thermostat is in there too, a one inch unit with two wires. It should have no continuity warm, closed circuit frozen. If it has open circuit frozen, that would be your problem.
Jun 14, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer works but fresh food seems warm
If you have frost on the back wall of the freezer compartment you have a defrost problem. When the freezer coil does not defrost the refrigerator does not get air for cooling.
May 22, 2008 | Frigidaire Refrigerators
Maytag side by side 23.6 cu. ft.
Warm for the Compresser is ok .. check the back wall of the freezer for a heavy frost build-up you may have a defrost problem.. Also check to see if the fan in the freezer is running..let me know
Feb 18, 2008 | Refrigerators
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
