Question about Universal Remote Control DIRECTV Universal Remote Control
Need remote control code for ESA TV model PDP4294LV1
Remote code for dish network for esa 42" plasma tv
Hey there, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. In order to program your remote to your TV you will need to first locate the model number of the remote. The model number of the remote will be located on the back of the remote at the top, usually a two to three digit number with a decimal point. I will list here for you the best remote codes for our more popular models of remotes. I hope you find this information useful and if you have any further questions or concerns feel free to email directly at Cheri.Torres@Dishnetwork.com.
Remote Model Remote codes
3.0, 3.1, 3.2, 3.4 IR remotes - codes 569, 632, 505, 516, 669, 636, 627.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 632, 667, 666, 233, 846, 733.
4.0 and 4.4 IR/UHF remotes - codes 733, 632, 569, 516, 537, 627.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 632, 569, 738, 537, 764, 733.
20.0 IR and 21.0 IR/UHF remotes - codes 672, 632, 654, 516, 777, 846, 738.
Instructions for addressing remote to TV
  1. Turn the Television On.
  2. Press and hold the TV mode button until all the mode lights light up.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button once. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Sep 15, 2011 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
I HAVE A ESA FLAT SCREEN TV AND I NEED THE MOST CURRENT CODES SO I CAN PROGRAM MY DISH NETWORK REMOTE , CAN YOU HELP ME PLEASE TV MODEL # IS PDP4294LV1
We currently have no codes listed for this brand try the steps below this is a process called a Power Scan it should resolve this for you.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
May 30, 2011 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Need a stand
I could not locate a stand for purchase on http://www.partstore.com/Model/Samsung/Samsung/PDP4294LV1.aspx
By the way, your tv is a rebranded Samsung model.
Without the stand, you only option would be to wall mount the tv.
You can purchase a wall mount for your tv from your local Wal-Mart or something to that effect for around $30.
Mar 13, 2011 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
My fan is not working picture fades out when over esa plasma tv
need to bring to your tv service center before it blows out and becames more expensive to fix only a tv tech will be able to fix it,,
Dec 16, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Esa 42 in plasma.....out of range?
i have a plasma tv (china brand) when i start the TV the remote control for other devices are not working, only working if the remote is too close to the sevices or by reducing the brightness to its minimum level (zero level..no brightnesss)
i need help strange fault
May 05, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
I need a dish network remote control code for an ESA television.
try some of the akai tv codes in dish network directory, firstone worked for me, hope it works for you
chris
Apr 28, 2009 | ESA ET432E TV
I have a esa plasma tv model # pdp4294lv1. I have hd service and channels, what do I need for this tv to view hdtv? Do I need some sort of convertor?
first step you can do is connect your coax cable to the tv and go to the menu. go to auto-program and run it. if your tv can hold those channels then the channels are going to be available just search them with your remote control.
second: it doesn't work. pretty much you need a converter box.
Apr 15, 2009 | Televison & Video
Need to find parts for my 42 inch plasma tv. #pdp4294lv1 model year:2004
The pdp4294lv1 is a re-branded Samsung monitor, here parts available online: PDP4294LV1.
To find all parts you need to look for part number on service manual, and then purchase same parts from different manufacturers. Alternatively call the seller to get parts.
Here the service manual.
SM-PDP4294LV1X
Mar 11, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Remote control code for ESA ET427E 27" television
0053 worked for me on this exact model.
Oct 11, 2008 | ESA ET427E 27" TV
Televison & Video Logo
191 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
