Question about Olympus FE-360 Digital Camera
FE360. Does not record pictures to SD card. Says memory full, I take that to mean internal memory. Back-up function does not work. What gives?
  • dashley121 Nov 14, 2010
    Have tried new SD card. No change. Records pictures to internal memory fine but not to card.
    Can't even get backup option to work.
  • dashley121 Nov 16, 2010
    Olympus xD Picture Card M+ 2GB.
  • 10,515 Answers
When a card is in the camera, the camera should default to the card for storage. This seems to be an issue with either camera or SD card.
Have you tried to format the card?
If not, try to format the SD card. If you have a spare SD card, compatible with this camera, try to use that and see, if that helps.
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 14, 2010
  • taran_2005
    taran_2005 Nov 14, 2010
    Thanks for your response!!
    Could you please provide, which SD card have you used?
    Thanks and Regards
    taran_2005
Will not accept memory Card
try a new one and if that doesn't work ask for your money back
Mar 21, 2014 | Kodak C195 Digital Camera
DMC-zs10 records on internal memory - not on SD card
Hello bro..
Do you check your SD card? It is work ?
My solution:
1. Off Lumix camera.Until LCD was off. Press center of card to remove it.
2. Use card reader to connect your SD card to pc/netbook/laptop..
3. Check full capacity for SD card, it is empty(zero) or have it their mount.
4. If empty (full,used,free is zero) ,try reinsert card again and don' t touch the terminal.
5. If still empty, that mean, your SD card was corrupted.
6. If not empty, backup all data in SD card.
7. Format the SD card using FAT32.
8. Checking Disk.
9.Insert back to camera, and format SD card using camera menu.
10. Take picture. and see if save on SD card or not. comment back here. if succes or not.
11. Don't use any battery except original from panasonic. It will affected to product.
12. Don't remove battery or card before lcd was off light.
Jul 24, 2011 | Cameras
When I turn on my Vivitar DVR 410,it says:Memory Full! Please insert an SD Memory Card.Then when I insert my card, it still says Memory Full! Please insert an SD Memory Card.It wont let me take a...
Remove the SD memory card from the camera, go into menu and locate "format" follow the prompt to remove all photo's from the internal memory, when completed install the SD card back in the camera to resume normal operation.
May 28, 2011 | Cameras
When I try to take a picture, it says memory full. But, when I try to look at the memory it says no file. I tried using the disk, installing software, formatting it.. Nothing works. The SD memory card is...
Format the SD card make sure the camera is set to place the new files on the SD card and not go to the internal memory. What I fully expect is the camera has defaulted to using the internal memory which is now full of files/pictures and needs to be set back to SD card. To get the pictures from the internal memory to your computer you need to load the pictures one by one from the internal memory to the SD card. Then take them from the SD card ether to a card reader to the computer or download them from the camera to the computer.
Dec 25, 2010 | Vivitar ViviCam 8025 Digital Camera
Takes only 10 pictures then indicates that internal memory is full, has new sd cardbut no pictures will record. everything else works fine
You need to get rid of the pictures in the internal memory. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions. Then, your card should work properly.
Dec 06, 2010 | Emprex DSC5100Z Digital Camera
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    Just put a new memory card in the camera but the screen keeps showing internal memory is full
    How to switch the camera over to saving pictures directly onto the SD card.
      1. Menu
      2. Cam settings
      3. Chose AUTO or SD card option and Press OK
    If you still experience problems:
    The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
      After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    Transfer from camera memory
    there might not be a way of transferring picture within the camera. However the SD card _should_ have resolved the memory full issue. Plug the camera into a computer with its USB cable. Transfer the pictures to the computer and delete them off the internal memory. Assure that your SD memory card is functional by trying it in another camera or in the slot on a computer.
    Nov 30, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
    Memory is full
    You can only use a 2GB SD card. It is in the manual. I'm not sure on dvd.
    Oct 24, 2008 | Mitsuba DV9002 Flash Media Camcorder
    Fe170
    You can add memory to your camera by purchasing an xd memory card.
    Compatible cards
    xD-Picture Card (16MB – 1GB)
    There are two ways to record the pictures you take with this camera.
    Recording pictures to the internal memory
    • Pictures are recorded to the internal memory, and when the number of storable still
    pictures reaches 0, you must connect the camera to a computer to download the
    pictures, and then erase the pictures from the internal memory.
    Using an xD-Picture Card (optional)
    • Pictures are recorded to the card when inserted in the camera. When the card is
    full, you download the pictures to a computer, and then either erase the pictures
    from the card or use a new card.
    • Pictures are not recorded to the internal memory when a card is inserted in the
    camera. Pictures in the internal memory can be copied to the card using the
    [BACKUP] function.
    g“BACKUP Copying pictures in the internal memory to the card” (P.25)
    “The card” (P.60)
    Number of storable still pictures and recording length of movies
    Still pictures
    Movie
    • If you use a non-Olympus card or a card used for another application, such as for
    a computer, the message [CARD ERROR] is displayed. To use this card with this
    camera, use the [FORMAT] function to format the card.
    g“MEMORY FORMAT (FORMAT) Formatting the internal memory/card” (P.24)
    Additional shooting tips and information
    Increasing the number of pictures that can be taken
    IMAGE QUALITY Image size
    Internal memory Card (128 MB)
    SHQ 2816 × 2112 2 25
    HQ 2816 × 2112 6 76
    SQ1 2048 × 1536 8 108
    SQ2 640 × 480 60 726
    Remaining recording time
    HQ 320 × 240 (15 frames/sec.) 32 sec. 6 min. 37 sec.
    SQ 160 × 120 (15 frames/sec.) 2 min. 8 sec. 26 min. 28 sec.
    Dec 15, 2007 | Olympus FE-170 Digital Camera
    Olympus FE-360 Digital Camera Logo
    Top Olympus Cameras Experts
    Willem.
    Willem.
    Steven Wander
    Steven Wander
    Are you an Olympus Camera Expert? Answer questions, earn points and help others
