Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
My carpet shampooer will not **** the water back up. It is a Hoover Steamvac Deluxe 1600.
  • sphelpsxx Jun 18, 2008
    Where are the filters? How do I access them? Sally
    I was told to check the filters. How do I access the filters? Where are they? Sally
    Master:
  • 638 Answers
You may have a clog in the hose. Unhook the hose and see how the suction is there, if ok, then check the dirt inlet by the brush roll. If suction is low at the hose, then there is a clog in it
link for company website n manual for additional help n details about ur product is given below:
http://www.hoover.com/
feel free 4 further assistance n keep sending more question n comments or doubts that arise in ur mind regarding this to me.rate the solution as fixya if it helps u understand n solve ur problem
Posted on Jun 18, 2008
  • 197 Answers
The filters are in side the machine. Are you the sort that likes to get their hands dirty on a project like this one?
    Master:
  • 788 Answers
There is most likely a leak or blockage in the system. A leak will cause low suction a blockage would cause no suction. Depending on what kind of suction you feel if you put your hand if from of the inlet will let you know what to look for.
If the unit is under warranty call Hoover for service and support, otherwise you could attempt to disassemble the machine to give it a good once over and look for the leak/blockage.
    Genius:
  • 3,422 Answers
Check the filters, make sure they aren't clogged. Also if this has the foam filter on the inside of the tank lid, make sure it has at least a 1/4 is gap from the top.
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
My Hoover SteamVac Max Extract 77's dirty water tank won't fill. The water seems to just filter right back to the floor. What do i do???
There are several possibilities for low pick up. The most common problem is that the lid is not correctly seated on the recovery (lower) tank. It is also possible that the rubber seal on the motor standpipe is out of place. The round tube on the bottom of the tank sits against the seal. Remove the tank and look for a large rubber ring on top of a plastic pipe. A less common issue is damage to the rug nozzle because the screws holding it against the carpet have been broken loose by dropping the shampooer on it's nose.
Jan 22, 2011 | Hoover F6055-900 SteamVac Maxextract LS...
I have a Hoover Deep Clean carpet shampooer but can't find the instruction manual
Click on the following link and scroll down the list of Steam Vac models to find your specific one. Then click on the red characters which represent your hoover situated to the left of your specific model:
http://www.hoover.com/CustomerService/Manuals/Default.aspx
Best wishes,
Graemevm
Jul 03, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
The brush won't spin on my hoover shampooer
This machine has an airdriven turbine that drives the brushes. The turbine needs to be replace because it is spinning on a steel bushing which gets rusty from all the water going through it.
Nov 26, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Solution for "hoover steam cleaner keeps
Hoover Carpet Shampooer
You might just need a new gasket. THey are inexpensive and fairly straight forward to replace with the right tools.
Sep 10, 2009 | Hoover F7431-900 SteamVac Vacuum
NOT SUCKING UP THE WATER
The Kirby shampooer isn't designed to be a extractor.What the shampooer does is create the foam,and the brushroll on the shampooer works it into the carpet.After the carpet is dry,(about an hour,)switch to the vacuum,and the vacuum picks up the dry foam.
Dec 15, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac Deluxe
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=624426
Posted by providence51 on May 26, 2008
My cleaner is not dispensing the shampoo solution. Still sucks up the dirty water that I manually applied with a scrub brush. I use this on my tiled screen porch floor and it has worked great many times.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There is a release value in the bottom the holding tank that may be bad and not opening or the trigger assm in the handle may be broken and not connecting to release the water to scrub and clean the carpets. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steamvac won't spray water on carpet.
Check the ank valve to make sure when you push it in that water is coming out. The reservior asm, (the tank bottom sits on this)is bad or the rod in the handle isn't pushing the reservior asm when you squeeze the trigger.
May 15, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover SteamVac
My Hoover Steamvac won't puo=ll out the water when I try to cleean the carpet. What do I need to do?
K758@aol.com
Dec 30, 2007 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
139 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
