Question about Maytag MMV5165 Microwave Oven
E-63 What does this mean and how do I get rid of it
  • Maytag Master
  • 9,098 Answers
E63 ia a "T1 Max Time error".
It may mean you have a bad PCB assembly, but I would suggest a hard reset.
Unplug it from the wall outlet for a minute, then plug it back in and try again.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 23, 2008
My microwave says E-63. What does that mean?
E63 is a "T1 Max Time error".
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Apr 26, 2010 | Samsung SMH7174BC Microwave Oven
My Samsung SMH7178STD gives me an error condition that flashes -SE- and beeps every so often but i can not get rid of the error condition. I have unplugged to perhaps reset it but it still flashes the same...
Hello :
SE error means you have a shorted keypad . If you couldn't find parts , then It will be cheaper to replace the unit or have new one .
good luck .
please rate !
Mar 30, 2010 | Samsung SMH7178STD Microwave Oven
Model # MMV5165BAW Error code - E-63
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Here's the explanation of that code:
E-63 T1 Max Time error. PCB assembly.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Dec 19, 2008 | Maytag Microwave Ovens
Jenn Air Microwave Error Code
Hello Hec1152,
I have found the manufacturer contact information for you, but could not find information about the error code. If everything works fine, but the microwave is not heating your food, then the problem is most likely the magnatron or one of it's components, which sadly to say is the most expensive part to replace. Please feel free to contact the manufacturer via phone or live chat to get more details as to what the error code means.
If you would not mind, could you please rate my help. I would greatly appreciate it.
Nov 29, 2008 | Jenn-Air JMC7000 Microwave Oven
We have a brand new Maytag mmv5165BAS over range microwave oven. When we tried to make microwave popcorn using the 'Popcorn' control, the microwave stopped early and the display read E-63. What does...
E63 is a "T1 Max Time" error. It indicates a problem on the control board.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Keep a close eye on it, and if it fails again, you want to contact Maytag for free warranty repair.
May 24, 2008 | Maytag Microwave Ovens
ERROR CODE E 63 COMES ON AFTER 2 MINUTES ON SAMSUNG MICROWAVE
Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven.  If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
If the message is either ERROR or E-6, it indicates a mechanical fault.
For all error indications, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locater to find your nearest Authorzied Service Center
Oct 21, 2007 | Samsung SMH7174BC Microwave Oven
I'm not finding that error code.
Does it come on 2 minutes after you plug it in?
If so, it may be a failing keypad or door switch / mount.
Of two minutes after you have been cooking?
That may indicate a bad humidity or other sensor.
Please give more detials so we can help further.
Oct 21, 2007 | Microwave Ovens
Maytag MMV5165BA - E-63 on display
Sounds like a problem with a temperature sensor or humidity sensor.
Aug 19, 2007 | Maytag MMV5165 Microwave Oven
Re:tv
Hi Redd, You might have better luck posting this under Sharp TVs: http://www.fixya.com/support/sharp/standard_televisions The black lines at the top of the screen are usually an indication of a problem with the vertical output section. It's often bad electrolytic capacitors, the vertical IC, or both. That's apparently not a US model, so it will be hard to find the values but you could contact Sharp Philippines: SHARP (PHILS.) CORPORATION [Philippines] Km.23 West Service Road, South Superhighway, Alabang, Muntinlupa,Metro Manila, Philippines Tel: 63-2-842-1371 Fax: 63-2-842-0530 Service Center Tel: 63-2-807-4991/4992 Fax: 63-2-807-0388 Home Page: http://www.sharp.ph/ Good luck.
Dec 19, 2006 | Sharp R-930AK Convection/Microwave Oven
Maytag MMV5165 Microwave Oven Logo
223 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
