Question about Panasonic SCBT330 Theater System
Power light is blinking with an on-unit code "W OPE"
  • 4 Answers
Apparently the firmware installation process was interrupted. Try re-installing it by powering off your SCBT330, the connect an Ethernet cord from your router to the back of the SCBT330 - do not use a wireless dongle for this procedure. Power on your SCBT330 and the firmware installation should pick up where it left off at. Please be patient, this process can take up to 10 minutes to complete.
Posted on May 10, 2011
Tip
Sony Brava Blinking Code and their meaning
Hello,<br /><br />Below are some blinking code interpretations for your Sony Brava TV;<br /><br />ONE Blink--- not used for the self-diagnosis<br /><br />TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.<br /><br />THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.<br /><br />FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505<br /><br />FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.<br /><br />SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.<br /><br />SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.<br /><br />EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.<br /><br />NINE blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).<br /><br />TEN blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.<br /><br />Intermittent problems ?? This is a great feature. You can also bring up these fault codes ON-SCREEN to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, Press the following buttons:<br /><br />Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC. We have repeated them in parentheses in the text for the "Blinks" described above so you can correlate between the diagnostic screen and the blink codes.<br /><br />So, now that you know about these self-diagnostics, how do you use them? Say that you have a set with a black screen. You see that the LED is blinking 4 times....This would tell you that you have no vertical and that is why the video is muted. If it was blinking 6 times, you would know that you have a horizontal fault.<br /><br />I hope I have helped someone.<br /><br />Regards.<br />
on May 17, 2011 | Televison & Video
Was watching TV, heard a slight "pop" noise then TV went dead - no picture or sound. When I hit the power "on" button on remote, the green light blinks for quite a while (around 40...
Count the number of blinks. Now, Google your make and model with the words blink codes added to the end. This will show you links to sites that will tell you what the blink code means and the problem with your set. The blink code is the sets way of telling the service man what is wrong. From the sound of it, you have a bad capacitor.
Sep 11, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
"i have a mitsubishi HDTV
The green blinking light is telling you the error code. count the number of blinks and make note of any sequence. Then google your make and model with blink codes added to the end. This will lead you to sights that will tell you what the error or blink code means.
Aug 20, 2011 | Mitsubishi Televison & Video
I don't have s stanadard TV set (CRT) with pre-digital tuner. I have a Sony PVM-2950 (2950Q) CRT monitor (no TV signal tuner, dumb tube). It accepts external signal feed. Today, the red...
Hello. You might try to re solder the power supply and deflection area, Also the common problems of this TV are the capacitors that lose value. But I think you have loose connections on the card. Good luck, if you have any questions, I'm here to help you with more details. thanks
Aug 14, 2011 | Televison & Video
Fisher Paykel DS605i single dishdrawer with a user-supplied integrate panel. There are three buttons on front. The left-hand button is power button; the center button is start/pause; and the right-hand...
Hello, Thank You for using FixYa. I will be helping you today.Are any of the cycle lights lighting up like rinse and normal and is the light on front blinking and pausing if so how many times is it blinking? Try turning the power off too the unit for five minutes and back on, because if the lid was open some or was stuck it can stop the unit from running.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jun 29, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
I HAVE A 50' PHILIPS MODEL 50PFP5332D/37 FLAT SCREEN TV. I BLEW A BREAKER ON THE TV PLUG IN WITH A PORTABLE HEATER. TURNED BREAKER ON TV CAME ON WORKED FINE. TURNED OFF. 1HR. LATER A RED BLINKING LIGHT WAS...
HI:
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
Mar 10, 2011 | Philips 50PFP5332D 50 in. Plasma...
Upon arriving from work today, I noticed that the "red power light indicator" was flashing periodically in intervals. I tried to turn the set "On" but the TV does not want to turn...
unplug set and plug back, the blinking power light is a error code, watch it carefully, a sequence of three blinks, pause and three blinks is the most common, it is SHORT PROTECTION.
Five blinks and a pause and five blinks is short on 140 volt line.
Let me know what you find and I will offer suggestions for you.
SD TECH I am in California
Feb 11, 2011 | Panasonic PT-53TW53 53" Rear Projection...
Standby light flashes green and red, the pattern is 11 flashes, is this serious
Submit the TV to an authorised SONY workshop for a quote and a full assessment of the actual problems. This repair could prove expensive/uneconomical, but it is up to you. The quote (and their second opinion) should help.
Here is a list of the problems that might have occurred indicated by the number of blinks:
* Unit is dead, No blinks = Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
* Continuous blink once a second, no pausing = No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
* 1 blink = not used for the self-diagnosis
* 2 blinks = B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
* 3 blinks = B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
* 4 blinks = No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
* 5 blinks = AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
* 6 blinks = No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
* 7 blinks = High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
* 8 blinks = Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
* 9 blinks = Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
* 10 blinks = Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
I assume the TV has no picture/sound as a result.
Dec 15, 2010 | Sony KV-36FS12 36" TV
"on" light flashes twice and then "blacks out"
IF power light comes on and a few seconds later goes off, do the self check this model has.
On front of set when this happens, press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then release both buttons.
Watch the power light closely, it should blink a two digit error code like; 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Dec 11, 2010 | Mitsubishi WS-65909 65" Rear Projection...
Panasonic SCBT330 Theater System Logo
64 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
