Question about ASUS Striker Extreme Motherboard
I had what I thought was a power issue, blue screen, powered off by itself, then did it again about 2 hours later. Ran a chkdsk on restart which took about 2 hours to run. At 99%, crash,auto shutdown, and now it wont even post. No video from either card. Disk drives just sound like they are looping, not initializing... any ideas?
  • 656 Answers
First remove all the addon card power to hard disk and cd drive even the ide cable or sata cable and restart your computer if you see post then shut down the computer remove your hard disk from the computer and coneect it to a working computer and connect the hard disk as slave to the other computer now restart the computer you will see 2 hardisk in the post boot it with the orginal hard disk when windows come right click my computer and click manage in the computer management click disk management you will see the 2 drives now click the disk 1and scan the drive in windows by richt clicking on the partion of drive 1 this will help you to scan the system easily also che the id or sata cable
Posted on Nov 14, 2010
How do I fix a DigiLand tablet?
The reset process can take some time, but usually no longer then an hour MAX.
Sounds like this device may be defective with all the issues you have been having. Contact the number and ask for a replacement or refund.
Jan 20, 2015 | Tablets & eReaders
I am running on limited diagnostic ability with no recovery disc. when iran chkdsk /f /r from c prompt it has stayed atuck at12% complete for laat 14 hours
I have run chkdsk /f (which is check disk fix) and I have run chkdsk /r (check disk repair) but I have never heard of trying both switches at the same time. I suggest powering off the machine (hold down power button) than restarting and running chkdsk /f first and if you still have issues run chkdsk /r which is a more in depth scan which can take a couple of hours depending on the size of the drive but never 15 hours in my experience.
Mar 01, 2013 | Computers & Internet
Frigidaire FDB126RBS2
Be very careful, it sounds like an electrical failure, were the machine has cut out to protect you and itself. You need an expert there and quickly. Water and electric are a bad mix and more house fires are caused by washers than most other appliances.
Sep 23, 2012 | Dishwashers
Hp pavilion slimline s3600t desktop pc - Wont boot up, flashes to blue screen after hp blue screen and restarts. no option for safe mode either
A Blue Screen is more time than not indicative of a driver issue or some hardware issue. First of all when it boots to the screen that shows Safe Mode and the other options, scroll down and see if there is an option to Stop or Disable Automatic Restart on Boot. This will stop the screen from restarting itself when the blue screen appears and give you a chance to read and see what the error is. Afterwards it is ok to run Startup Repair. Startup Repair does not delete any of your personal files. Let startup repair run and then see if it boots. Once again, startup repair does not delete any of your music, documents, pictures, videos or programs. System Restore does not delete any of you documents, music, pictures, videos or programs. System Recovery WILL DELETE all of your music, pictures, videos, documents & any programs you've added since you brought the computer home from the store. System Recovery sets your computer back to the very first time you turned it on after you purchased it. I would run the startup repair, if that does not fix your problem, see if you can run a System Restore. A lot of time the Restore Points are damaged or missing when this happens, but give it a try and restore to a point before you started having the blue screen issue. If all fails you're going to need a system disc so that you can get into the Recovery Console so that you can enter a dos command in the little black box that opens up with white letters. You want to type: chkdsk /r
Let it run. It will run well over an hour and you will notice the percentage of completion going from high to low, but that's ok. Let it run to completion then try rebooting. If this doesn't work, you're going to need to take it to a repair shop or reload the operating system yourself.
Mar 19, 2012 | HP Pavilion Slimline s3600t Desktop PC
Few minutes after Windows starts the computer screen shows this blue screen with lots of white text and then it shuts itself off, then it restarts itself and then again, the blue screen and it shuts itself...
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jun 21, 2011 | Toshiba Tecra M2V-S310 Notebook
Blue screen of death
upon restarting keep pressing the F8 key to get into the repair screen
choose the command line with the c:/ prompt
when that appears type in chkdsk /f /r and press enter
choose Y to perform this task then log off and reboot
chkdsk will run and check for any problems in the registry and repairs them
Aug 02, 2010 | Microsoft Windows Vista Home Premium...
Bush tv frequently turning itself off
make sure you have not accidentaly scheduled a power off and on if yes torn off/disable them if not check that your power cable is secure
Dec 21, 2009 | Televison & Video
Acer Issue ChkDsk
Seems to be bad HDD. Change it.
Sep 15, 2009 | Acer Aspire 1640Z Notebook
Chrysler crossfire engine always stall
I have an excellent mechanic at my dealership.
I ran into the problem your are descrbing. Thought it was a fluke but when It got worse took it to the dealership my mechanic diagnosed it as an intermittant failure of the Crankshaft Sensor.
Feb 02, 2009 | 2004 Chrysler Crossfire
Sparadic power interruptions
try checking the cpu fan and heatsink for dust build up
Dec 31, 2008 | Gigabyte GA-8ST800 Motherboard
ASUS Striker Extreme Motherboard Logo
64 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
