Question about LG RZ26LZ55 26 in. LCD Television
I have a LG RZ 26LZ55 for repair. After replacing the backlight invertor board from another television ( same type ), everything worked again. Now i would like to repair the faulty invertor board. The faulty one seems to start for a sec and then cuts off... Anybody has experience, repairing this invertor type:19.26006.062 ? No driver transistors seem to bee damaged. TNX!!!
SOURCE: LCD LG RZ-20LA70 20 stopped working
Same problem with our LG LCD. Just thrown away, never a LG again.
Posted on Mar 04, 2008
Mark_Webber
  • 472 Answers
SOURCE: LG RZ-26LZ50 LCD Television-Solid Black line down the right had side of the screen
It's the driver tabs that operate that section of the panel. To have them repaired/replaced can be very expensive and is normally just replaced completely as a whole panel (at least while under warranty). If it is out of warranty, then get a few quotes over the phone. This will help dramatically when you explain to your wife that you are about ot go shopping to buy a new TV.
I find things like "Have I told you how good you look today" help when this process is taking place.
Sorry for the bad news.
Posted on Apr 12, 2008
  • 92 Answers
SOURCE: LG 47LC7DF LCD TV Remote Sensor not working
IR senor may not be bad. Try using a different remote (universal) and program to TV. If universal remote works and your doesn't, you may need to purchase a remote instead of IR board. If you confirmed that the IR board is bad then replacing the IR board will fix the remote issue. IR board is an easy fix. Just open the back cover out and it's located right in the middle toward the bottom of the TV.
Posted on Jun 22, 2009
tvtek
  • 1284 Answers
SOURCE: LG 32LC7D will not display digital channels.
Most likely if the digital channels are dropping off then you might just have to replace the tuner. The tuner on this TV is available separately as part number EBL32758001. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
  • 12 Answers
SOURCE: damage of my LG RZ-37LZ55
may be ur voltage fluctuate or over voltage
Posted on Feb 04, 2011
How do we tune in an LG RZ32LZ50 tv in with no remote?
There are buttons on the right side of the TV, or you can get a compatible remote. Remote Control Fit For LG RZ 26LZ55 RZ 32LZ50 RZ 32LZ55 RZ 37LZ55 LCD TV
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Mar 08, 2016 | LG Televison & Video
I have a LG model RZ 42PX11 and the picture quality isn't very good quite dark picture what part would I need to get this sorted
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
May 24, 2015 | LG Televison & Video
Lg 42lg50 LCD tv has audio but no picture
The backlight is out most likely caused by either the T conn or the Invertor. The invertor is most likely you can get replacement boards from www.tvcircuitboards.com leave a email if your not sure what you need.
Jan 02, 2012 | LG 42LC2D 42 in. LCD HDTV
TOSHIBA TV NO PICTURE
Sounds like blown invertor board that powers the backlights (if it is LCD or PLASMA). If your lucky and its just the invertor board blown it could cost anywhere between £50-£150 for new board (without labour).. if you are UN-Lucky, then the backlights themselfs may have blown which is *usually* an un-economic repair.
Apr 05, 2010 | Toshiba 46H83 46" Rear Projection...
Lg lcd
This will be a problem with the inverter board to control the backlights, this causes the screen to try & light up & then blank out. If the backlights are faulty, then a new replacement screen is required. Look for any sign of any component stress on the inverter board & also check for any related capacitors on the power board side that may look swollen & replace them.
Sep 03, 2009 | LG 42LC2D 42 in. LCD HDTV
Screen goes dim on one side then the other, sometimes works fine
I suspect the invertor for the backlight lamps.  If the failure mode is one that is all too common today, there are some cheap parts (electrolytic capacitors) that should have cost a few pennies more. This is probably not in the category of DIY repairs but you may be able to locate and replace the power supply board or boards yourself since everything is plugged together if you can find someone to repair them or has them in stock.
Nov 28, 2008 | Olevia LT42HVi 42 in. LCD Television
LG RZ32LZ55
There could be two possible failures:
1. The backlights are defective (not a common failure for a 14 months old LCD) or the backlights driver/inverter is defective.
2. Power supply failure(very common failure on LCDs) will cause the symptoms you described.
May 22, 2008 | LG RZ-20LA70 20 in. LCD Television
Lcd tv backlight prob
You need to replace the inverter board if you can find the spare part. Otherwise you need to replace the whole lcd panel.
Jan 01, 2008 | LG RZ-17LZ40 17 in. LCD Television
LG RZ26LZ55 26 in. LCD Television Logo
331 people viewed this question
