Question about Philips 107E61 17" CRT Monitor
DEAR SIR I HAVE ONE PHILIPS CRTMONITOR 107E61 MODEL PROBLEM IS POWERING ON BUT NODISPLY ALL SECONDARY Vg are ok pls help thanks and regards jayesh sn
    President:
  • 556 Answers
Cause:
This issue can be caused by any of the below possibilities.
  1. Monitor is not on
  2. Computer is asleep
  3. Connections not connected properly.
  4. Monitor settings are not correct.
  5. No Post.
  6. Hardware issue.
Solution:The following is monitor troubleshooting. If your monitor receives a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please refer to document CH000192.
Monitor is not on
Make sure the monitor is on. If no power light (green or orange light) is seen on the monitor display try pressing the power button until it comes on. If no light comes on after several attempts continue to below connections not connected properly.
Computer is asleep
If your computer monitor was on and you stepped away from the computer and upon returning it was black it's likely that the computer is asleep. Try moving your mouse, clicking the mouse buttons, and/or pressing any key (space bar) on the keyboard to wake it up.
DEAR SIR - vga.jpgMake sure that you are connecting the monitor to the back of the computer in the 15-pin connector as shown to the right or older computer 9-pin connection.
If the computer is properly plugged in, make sure it's getting getting power.
If you are not receiving power from a known working wall outlet and if the power cord is removable, replace it with the one connected to the computer and attempt to power on the monitor again. If the monitor still does not get power or it is not removable, it is recommended that the monitor be replaced or serviced at a local TV / Computer repair shop.
If the monitor is receiving power, check the status light.
If the light is orange or flashing ensure that the monitor is not in a suspend mode by moving the mouse or pressing a key on the keyboard. If the computer does not get a display by moving the mouse or touching the keyboard, turn off the computer and monitor and reconnect the data cable from the back of the computer, and if removable, the back of the monitor. Turn the computer back on; if you still encounter the same issue, continue reading through the other possibilities.
Ensure that the brightness and contrast is turned up or attempt to adjust the brightness and contrast. If adjusting the brightness or contrast has no affect on the monitor continue reading through the other possibilities.
No Post
Does the computer beep when it is powered on and/or does it appear that the computer has activity? If the computer does not beep or beeps abnormally it is possible that the computer itself is experiencing a hardware issue or is exhibiting a No Post.
Steps on troubleshooting an irregular POST or no beeps can be found on document CH000607.
Hardware Issue
If you have followed the above recommendations and are still encountering the same issue, it is likely that the computer may have either a bad video card or monitor. The best method of determining this is to do one or both of the following:
  • Disconnect your monitor and attempt to connect it to another computer. This can be a friend or family's computer and/or it can be taken to a service center.
  • Borrow a computer monitor and connect it to your computer. This will not harm the other computer monitor in any way.
If your monitor works on another computer it is safe to assume that the video card or potentially the motherboard within the computer is bad. Steps in troubleshooting a video card can be found on document CH001028.
If another monitor works on your computer it is safe to assume that your monitor is bad.
Posted on Nov 14, 2010
Philips pc monitore no display
Check its back-light inverter board. For more details, check this site.http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 10, 2013 | Philips 107E61 17" CRT Monitor
Control menu is locked how to open
Press the Menu/ Ok button for 15 seconds and it will get unlocked. If it is a power lockout, then press the power button for 15 seconds and it will get unlocked.
Regards,
Shrey
Jun 09, 2011 | Philips 107E61 17" CRT Monitor
Please show me value for resistance location no are 3133 and 3407
hi,
The resistor 3407 is 1ohm 2W resistor
I have searched in the circuit for 3133, but i didn't find it . can you tell me in which section you have seen that resistor.
if you send me your email id through fixya will sent you the schematic diagram.
ok
Feb 09, 2011 | Philips 107E61 17" CRT Monitor
How to unlock 107E6 philips monitor
Press and hold the (OK) button for 20 seconds until the menu appears.
Oct 08, 2010 | Philips 107E61 17" CRT Monitor
My philips 104E 15" monitor is not displaying red colour at all.other two colours are perfectly OK.What could be the cause? is the red gun gone?
Yes, or the RED driver circuits is bad, check soldering joints on the CRT PCB. Simple thing to do is to check the VGA cable connection first, check the video card (reseating the card).
Apr 21, 2010 | Philips 107E61 17" CRT Monitor
Display problem
sir,mam you need to check first your cable connection for proper ground,maybe insuficient grounding on your cable and that why your reception signal become snowy.
Aug 29, 2009 | Philips 107E61 17" CRT Monitor
Philips 105E
I have philips monitor 107E there is a supply problem i want to repair it. I need circiut diagram for repair.
May 28, 2009 | Philips 107E61 17" CRT Monitor
21pt2216/94 phillips 21'' audio problem
your speaker maybe busted or check the amplifier IC
Oct 22, 2008 | Televison & Video
No video in my philips dvd622
Check if you have not accidentlychanged to progressive mode which can cause this proble.
Are you connected to TV using Composite video out?Try connecting using S-Video or DVd (component inputs).
Do provide feedback and rate this solution.
Samir
Mar 26, 2008 | Philips DVD622 DVD Player
Circuit diagram
i need circuit diagram of 107e61/94 model.
Feb 19, 2008 | Philips 107E61 17" CRT Monitor
Philips 107E61 17" CRT Monitor Logo
89 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
