Question about Asrock Computers & Internet
Power starts as soon as pc is plugged in fans start but nothing else
Ihave a as rock motherboard p4165g
    Genius:
  • 1,027 Answers
Enter bios setup utility and select stay off after power comes on after power failure.
Posted on Jun 19, 2008
No sound Dell potiplex GX 150 and can not get into the bios. HELP
Posted on Jan 04, 2009
Emachine EL18252 G-52W won't start when pushing power button
Disconnect the desktop computer from the electrical power.
Plug it in, while looking at the computer, and listening for any noises (spinning fans, or lamps that light up) as soon as it is plugged in. Then, press the ON/OFF switch, and watch any lamps, and listen for any fans. If nothing, then the power-supply is the problem.
Aug 21, 2015 | Computers & Internet
Computer turn on, but when it does it won't POST
It seems like a motherboard issue. It heats up, thus is not able to turn on continuously. You may need to check internal parts embeded on the motherboard llike the fan and processor before you could know what needs replacement.
Jul 18, 2010 | Dell Dimension E521 PC Desktop
We were given a Gateway EL500S computer to use for our kids. We set everything up. We did try to install an ethernet card. When we turned it on, nothing happened. The light comes on the ''on'' button but...
when you say no fan you mean the cpu fan or the case fan. the cpu fan is on top the cpu. make sure that at least this starts. if it does not start then shut down your pc immediately as it can burn the cpu.
it could be lots of reasons, but make sure that you have connected the power supply cables correctly to the motherboard. probably the motherboard may have a small led. check if that lights up. it means that power gets to the motherboard.
i would advice to find someone that has more knowledge.
Jan 24, 2010 | Computers & Internet
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
PC starts with pushing power button??
Go to BIOS and change the power settings. You will see some options such as Power On. Default action will be OFF. Change it to ON.
Jan 12, 2009 | Gateway Computers & Internet
Emachine flashing yellow lights, fans power up when P8 is unplugged
Did some research and found this site which will tell you which pins to test. It is possible also that its not powerful enough for the devices you have. I would try again only giving power to the motherboard pins, of coarse and the hard drive. If works then plug one device at a time.
Good luck
http://articles.techrepublic.com.com/5100-10878_11-1046822.html
Jul 05, 2008 | E-Machines eMachines Desktop PC
Won't boot up, Fans are on non-stop
Open up the pc with power off. After cleaning with a blowing or sucking device, gently press on the connections and plug-in devices. Retry.
If no avail, the power supply or the motherboard may have bit the dust. U can get them repaired or replaced.... or save the HD and buy a another pc and add the old HD as a data disk.
May 11, 2008 | Gateway GT5056 PC Desktop
Asus a8v-vm se fans always run
Hi jderek4, try this. locate the toggle switch on the back of the power supply. Just find it do not flip it.
Plug the PSU's power cord into the PC. Just as you got a good connection & the PC begains to power up move the toggle switch to it's other position. The PC should power off that very second.
If the PC does not shut off than the PSU is bad. If it did shut down wait a few seconds. Press the cases power on button. The PC should start to boot up. Let it finish loading. Click the start button & choose to shut down windows. The PC should shut off.
Yes? If not than your back to (bad power supply). Swap it out.
Mike
Mar 29, 2008 | ASUS A8V-VM Motherboard
Startup trouble
fix another ram and check, otherwise it will be the motherboard problem , one more option is remove the harddisk and check
Mar 14, 2008 | HP Compaq nx5000 Notebook
Asus a8v fail
does the power supply fan run when switched on.
does the hard drive spin up .
Have you reseated the video card.
Jan 26, 2008 | ASUS A8V Deluxe Motherboard
Computers & Internet Logo
443 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
