Question about Mitsubishi WD-62525 62" Rear Projection HDTV
"My 62 inch 5 yr old Mitsubishi DLP TV has
4 Suggested Answers
  • 1153 Answers
SOURCE: Mitsubishi DLP 62" WD-62725- Clear Picture w/ Purple Screen
Sounds like one of your colors are missing. make sure all colors are lit, Blue, Red, Green
Posted on Dec 27, 2007
  • 1894 Answers
SOURCE: Mitsubishi WD-62725 62 in PC input Noise issue
1. Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977020 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977020 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977020 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977020 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB part # 934C148001 From the noise you described it could also be that the color wheel is failing. Fans and the color wheel can cause shutdown. And if any of this sounds too complicated it's time to bite the bullet and take it into the shop. Find a reputable shop and one that will give you a written estimate before proceeding. If you ned help locating one try the NESDA locator: http://www.nesda.com/locator/state_search.php Hope this helps
Posted on Jan 03, 2008
  • 179 Answers
SOURCE: Vertical lines on Mitsubishi 62" DLP
the DM and/or the FMT board are going bad. the chassis needs to be rebuilt. check out www.tv-techs.com
Posted on Jan 02, 2009
2004 mitsubishi DLP 62 "
the timer light part is misleading you Carlos, i think it is probably the internal power supply start up which is failing im afraid you will need a techie visit sorry,George.
Nov 03, 2010 | Televison & Video
Mitsubishi WD-62627 62" DLP TV
Try this:
1) turn on the TV
2) from the remote control press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING
4) when done press the front reset button.
5) should be good to go!
Oct 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Purple-blue haze and line across my Mitsubishi wd62530 screen
hi this fault could be the convergance ic also the resistors and capacitors need to be checked, thanks
shaun
Jun 26, 2017 | Mitsubishi WD62527 62 in. LCD HDTV
Picture getting darker over the years
It could be your Light Engine. However, I would first check a few things:
1. Make sure your Low Power/Lamp settings are adjusted so that they meet your brightness needs.
2. Make sure you used a Mitsubishi original lamp, as generics get chewed through fast and hard.
3. Try another lamp; sometimes you can get a bad one in the bunch.
All those things don't work, consider a Light Engine ($400 + for parts; $300+ for labor)
Mar 11, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
My 3 yr old tv has developed lines in the picture.
remove set back find large transformer with red wire attatched to pix tube find control labeled G2 reduce slightly wit set on with no sgnal on avideo inpt
Mar 11, 2009 | Samsung TX-R3079 Television
Jan 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi rear projection tv color problem
I'm going to guess that this unit is a DLP projection set and that the lamp is not new. Try a new lamp. The heat of the lamp will char over time. If not the lamp, some of the internal filters in the light engine might be getting effected by heat and require replacement.
Keep us posted.
Dan
Sep 12, 2008 | Mitsubishi Televison & Video
Dec 27, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Horiantal line near top of screen
Suspect the Light Engine part # 939P977020.
Mar 08, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
154 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
