Question about Konica Minolta bizhub C450P Laser Printer
Biz hub 450
I am trying to print a double sided brochure and the 2nd page is turned the wrong way.
  • oregonfilm Aug 01, 2008
    I have the same problem. I am printing a double-sided brochure and the back page is upside-down.
  • brian c
    brian c May 11, 2010
    Do you mean it's upside down?
  • 167 Answers
Change binding from auto to either left or top.
Posted on Jun 19, 2008
  • Kevin Hayes
    Kevin Hayes Aug 29, 2008
    The orientation of double sided print is controlled by the "Binding direction" option.
    Experiment with this and it will work.
    You may need to also specify this option in the page setup of your software, depending on what it is.
Trying to print a newsletter in which each A4 sheet has 2 pages on each side, and by turning pages upside down it has made a mess of the end product... all over the place!!! Upside-down, back-to-front... grrr!
Our It manager has suggested the following, but still doesn't work for what I want to do. hope it works for you...
"When printing double sided on the KonicaMinolta printer to ensure that all pages appear the correct way up ensure binding is set to "top binding" - this can be found in printer preferences/ setup tab"
Posted on Aug 27, 2008
Double sided printing
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Jul 14, 2012 | HP Photosmart Plus All In One Printer b210
How to duplex print with 895cxi
This model printer does not have a duplex unit and cannot print double sided documents automatically.
Jul 08, 2012 | HP DeskJet 895cxi InkJet Printer
Need help to print brochures
Yes, I think it's best to print brochures from some online printing companies out there, especially now that you're running out of time. You don't have to go all through the trouble. Just specify what you want to do with your brochures and they will take care of everything. You can go and check this site: http://www.printrunner.com/brochure-printing.html Other than the gate fold option, they also offer other types of folding like half-fold, tri-fold, Z-fold, double-gate fold, double-parallel fold- and roll-fold.
Mar 12, 2012 | Office Equipment & Supplies
I am printing a brochure that i created on microsoft publisher, but i can't get it to print double sided the right side up for both pages
Hello:
The Brother DCP-7030 supports manual duplex only. When choosing duplex (2-sided) printing, it will print the even-numbered pages first and prompts you to reinsert the pages in a different orientation.
To correctly print the second side of your brochure, you could do one of two things:
  1. Reverse the orientation of the paper when you reinsert if for the second side of printing.
  2. Reverse the direction of the second page in Publisher.
The first option is simple enough. When the Brother driver directs you to insert the paper for the second side, insert it in a rotated position. It should be on the same side, but rotated 180 degrees.
The second option is also easy, but if you want to edit the document in the future, it will involve in some work before being able to edit it.
  1. In Publisher, select all of the objects on the page (pressing "Ctrl" and "A" on your keyboard at the same time will accomplish this).
  2. Right-click on an object on the page.
  3. Choose "Group"
  4. Your objects are now grouped into one item.
  5. There should be a green dot at the halfway point at the top of the group. You can click and drag this dot until the object is rotated 180 degrees. Alternatively, you could go to the menu and choose "Arrange>Rotate or Flip>Rotate Left 90 degrees" twice.
  6. Now when you print, you should follow the Brother driver directions when flipping the paper.
Jan 14, 2011 | Brother DCP-7030 Digital All-in-One Laser...
I have a Konica Minolta C451 bizhub printer and I am trying to make a double sided copy brochure from my printer. The problem is that it prints the 2nd side upside down and I don't know what to do to get...
When selecting duplex printing on the print setup screen change the box labeled binding position from auto, to top binding. If it already set to top then change it to left. This is usually the setting that will cause the duplex pages to print properly when duplexing on the C451. If it does not work you can try left or right binding but top binding I am sure will fix this for you. I have run print jobs in the last week or so where I had to make the same change to my C450.
Good Luck and Thank You for using Fixya.
Jul 20, 2010 | Office Equipment & Supplies
Using as a printer on 3-fold brochure
From your print menu properties change it from short 2 sided to long 2 sided or visa versa
Apr 30, 2010 | Canon imageRUNNER 5000 Copier
How do i copy two pages onto one double sided page?
there is n option on the disply panel.refers to original-with 4 option 1-1 .2-1 .1-2. 2-2 try and experament with 2-1 or 1-2 option 2-2 is for 2sided
Jun 05, 2009 | Konica Minolta DiALTA Di200 Copier
Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Jan 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Printing a two sided brochure on HP Color LaserJet 1600 and brochure is getting spotty. Do rollers need to be cleaned? If so how is this done? Printer is one year old. Thank you.
the hp1600 is a rubbish printer. The fuser is inefficient and the toner doesn't stick correctly to the page, for double sided jobs, print all of side 1 first, allow the pages t cool completely and then print side 2, alternately buy a HP3600d or HP3505d, its chalk and cheese
May 09, 2008 | Office Equipment & Supplies
Konica Minolta bizhub C450P Laser Printer Logo
811 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
