Question about Vacuums
I have an old Janome sewing machine and when I plug it in at the power point and turn it on it sews without putting your foot on the pedal Can you help
I have to same problem as tony
Posted on Nov 17, 2010
Troubleshoot janome 5024 the thread is catching near the bobbin and won't thread through
you might have a timing problem, having the machine serviced would be a good idea
Sep 27, 2014 | SewShop.com Janome Sewing Manual 5024
How to fix sticking sewing machine foot pedal?
A little machine oil on the hinge pins may do it.
Jun 21, 2014 | Singer Sewing Machine Foot Pedal
7467S sewing machine beeps four time and won't let me sew
Hi! Probably too late to help the original asker, but I have this same machine and was having the exact same problem. 4 beep error message, but mine would not sew at all. Found this question through a google search, but no answer. But I figured it out! I had left the buttonhole lever down!! (Facepalm) I hope this is helpful to future googlers with a similar problem.
Feb 05, 2014 | Singer 7467S Confidence Stylist Electric...
Hi I have a Janome 419S or 423S, the problem seems to be my hook race unit keeps getting loose and then the thread jams up. What can be done? Please
A jammed machine is caused by thread being caught in thehook. Remove the upper thread and the bobbin case, turn the hand wheel towardsyou (counterclockwise) by hand and remove any thread in the bobbin case area. Alwaysturn the hand wheel towards you. Turning the hand wheel away from you(clockwise) can cause the machines timing to become unaligned and jam yourmachine. Also, always make sure the presser foot is in the down position beforeyou start sewing. Sewing with the presser foot in the up position will jam yourmachine in the bobbin case. If youhave an older model sewing machine with a shuttle hook, then you can alsofollow these: 1. Disconnect the sewing machine from any power source.Loosen the thumb screw on the left side of the sewing machine body and removethe cover to expose the needle bar. This is the shaft that extends down andthat you attach a needle to for sewing. Open the shuttle race and remove the bobbinand bobbin case. 2. Turn the hand wheel toward you until the needle hasreached the lowest point of the stroke. The hook should be at the top of itsstroke inside the shuttle race. Loosen the set screw for the needle bar on theupper part of the machine, this is located on the needle bar bushing (thecollar that the needle bar slides through when making a stitch). The needle barshould slide easily up and down. 3. Turning the wheel again, adjust the position of the tipof the needle so that the upper part of the needle eye is just below the bottomedge of the hook inside the shuttle race. Once in position, re-tighten the setscrew on the needle bar bushing. Do not allow the needle bar to slip whiledoing this. 4. Replace the bobbin and bobbin case and close the shuttlerace. Thread and plug in your machine. Using a sizable scrap of cloth, sew aseam to check to see if there are any skips in the stitching. If there arestill skips re-adjust the timing again until you can sew without any skipped stitches. 5. When proper timing has been achieved replaces the coveron the needle bar and tighten the thumb screw. Hope this will help you. Good Luck.
Sep 13, 2011 | Vacuums
When you turn the sewing machine on it constantly keeps on going almost like you have your foot on the pedal all the time the machine is a contessa 410 model
the foot pedal controls the voltage to the machine. If it is running to fast then the foot control is bad
Apr 18, 2011 | Vacuums
I have lost my sewing machine bobbin case
Hi, little ducke,
Can't do much sewing without a bobbin case!
I've had a difficult time finding information on your particular model. The best website I could find has pictures of the few different styles of bobbin case in Janome machines. I think if you look at the pics, you'ld be able to pick out the one for you.  Here's the website: http://sewingstyle.com/Janome-Sewing-Bobbin-Cases.html
I hope this helps. If it does, please place a vote or comment for me. Thanks,
Handie Andie
Mar 30, 2011 | Vacuums
I have a janome 9000 sewing machine and while moving have lost the presser foot and foot A, how can I replace them? heather
replace it with a new one which is availble in market.
or find out the people who sell the same product in second hand.
Feb 25, 2011 | Vacuums
Hi I'm Sharon .I just dropped the pedal of a Janome sewing machine and now it doesn't work. Can i get a repair close to inner city Sydney? Ta
hi sharon the quickest easiest way for you would be to go to this page and contact jerome australia directly to assist you. http://www.janome.com.au/contact_janome.php
i may add that if you explain what happened and how much you lke their sewing machines they may possible send you one as a goodwill gesture (some companies still do that tho don't ask them directly)
as a side note my aussie wife uses the expression 'ta"... love it
Sep 28, 2010 | Vacuums
Vacuums Logo
46 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
