Question about Bosch Dishwashers
My bosch dishwasher-soap flakes cake into a block- finish tablets dont fully melt
  • eddis Nov 14, 2010
    classic electronic bosch
    setting 45'
  • Bosch Master
  • 3,247 Answers
It is likely you don't have the correct water temperature.
Please provide the full model number of your bosch dishwasher and details of which wash program do you normally use. Do you know if the wash is completed?
Posted on Nov 14, 2010
  • Sam Nov 14, 2010
    I am assuming you have a classix 45 cm dishwasher.
    It will be more helpful if you provide the actual model number- this should be in the user manual.
    something like SMUxx or SHExxx
    Is this happening in all wash programs? What about the ones with hot water cycles.
I have a bosch dishwasher silence , when it finishs wash i open the door and find the tablet falling on the bottom or hanging on the container of the tablet part, which did not use at all..please advise,...
Check top basket is straight and moves back fully, remove top spray arm and check holes are not blocked. The water pressure from the top arm is deminished if they are blocked and once the dispenser door opens it is the top spray arm water that propels the tab into the tank. Also, check that when your tallest item is in the bottom basket it does not obstruct the rotation of the top one.
Hope this helps to give you a starting point to remedy fault.
Jul 22, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
The soap dispenser only opens sometimes. When the dispenser doesn't open the soap is in a solid cake inside dispenser.
IF DISPENSER IS CLOSED WHEN FINISHED COMPLETE CYCLE .
THERE ARE TWO WAYS THAT D/W'S
OPEN THE DISPENSER ONE IS BY WAY OF TIMER TRIPPING LATCH, OTHER IS BY WAY OF BIMETAL IN THE DOOR. THE SOLID IS BECAUSE OF THE MOISTURE ABSORPTION OF THE SOAP. THIS IS ASSUMING THAT YOU HAVE NOT BLOCKED THE DISPENSER DOOR WITH SOME OBSTRUCTION.
Feb 18, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
The soap tablet is no longer fully dissolving in its compartment, still does so when placed directly in d/w but finish is not as good
Have a look at the top spray arm.
Dishwashers rely on the water coming out of the end to wash the powder (tablet) out of the dispenser. Other problem could be a low water level. This would need adjusting by someone who knows how for whatever brand/model you have. Hope this helps...
Dec 12, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Powdered Soap Dispenser
The soap door doesn't open fully on that model, and usually flips fully open as you open the dishwasher door.
It relies on the top spray arm turning to 'wash' the soap out of the drawer - and that will be the problem.The spray arm isn't turning.
Check the spray arm for blocked jets at the very end - use a pin to clear them out, or replace them - check both spray arms. Make sure the spray arm rotates freely also.
Remember the dishwasher isn't a garbage disposal unit - remove food deposits from plates etc before loading the machine. Run a dishwasher cleaner through the machine now and then. Food like pasta, or fruit pips often get carried to the end of spray arms and block them.
If using a 30 min rapid wash program ONLY and dishwasher tablets, put the tab in the cutlery basket as it wont have time to dissolve fully if you put it in the dispenser.
Feb 02, 2018 | General Electric Profile PDW7980NSS...
Dishwasher detergent "pacs" dont disolve anymore
Try reversing the bottom dish rack, it's likely blocking the dispenser door because it's put in the dishwasher incorrectly. Also check if there is anything in the back of the rack preventing it from going all the way in.
Apr 05, 2009 | KitchenAid KUDU03FT Built-in Dishwasher
Bosch #SHU9955 Integra dishwasher for the last three uses, the soap dispenser door was open with the powder soap caked in the lowest one half of the pocket dispenser. The dispenser door locked and unlocked...
The problem was evident during short cycle (primary cycle used) and changing to regular cycle used and back to short cycle seems to have corrected problem.
Oct 09, 2008 | Bosch Dishwashers
Bosch Exxcel Dishwasher
no not if it getting hot it still sounds like the motor isnt coming on put the spray arms in the same position turn it on then open the door are the arms still in the same position or haved the moved.those cleaners need hot moving water to melt the seal.
Aug 30, 2008 | Dishwashers
Soap tablet not disolving
Its has been my experience that those soap block dont do a very good job. Try using a gel type detergent for wahing your dishes
Nov 08, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Dishwashers Logo
63 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
