I am wondering if there is a way to hook my linksys router up to another router that will pick up the signal so that an xbox360 can plug an ethernet cord directly into the back of it. We tried two different wireless cards for the xbox, and they do not work, but the port works fine. So, is there a way to link two routers without running wires so that the xbox can run off that signal?
ya do one thing in the linksys router give port forwarding it means that your seconed router ip address give to the first router in the option the port forwarding you get the wireless.
or do one thing use the one router and other use access point then you get better then the best .
can't save changes made to router settings such as ssid, security setting. when i click save it...
(More)
can't save changes made to router settings such as ssid, security setting. when i click save it wont' ever save. When i check my connection it says...the settings you saved to match the system requirments... I just want to secure my connection
I have a 2006 BMW X3. US spec. I want to activate the daytime running lamps. Is there a way to do...
(More)
I have a 2006 BMW X3. US spec. I want to activate the daytime running lamps. Is there a way to do this without taking it to the dealer?
