Question about Pool & Spa
Viron spa heater - won't heat. Spa is 23 degrees but heater showing an F2 fault which says it is over 40 degrees. manual says to turn off and on, but does not remedy it.
  • Anonymous Dec 28, 2016
    same issue. any solution?
  • Dany
    Dany Dec 28, 2016
    heater started doing the exact same thing just in time for Christmas, help???
PartsCenter
  • 125 Answers
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Posted on Feb 26, 2009
PartsCenter
  • 125 Answers
SOURCE: how to solve a ffl fault on r207a spa heater?
FFL ? sounds like a flow error on the control panel. take the filter out and see if it goes away. might just be a dirty filter or the pressure switch is not working.
  • 83 Answers
SOURCE: Sta Rite Sr333na Max E Therm Pool & Spa Heater gauge stuck?
Anytime the heater is reading the water temp to be above what it actually is, especially 126, the problem is the Thermistor, or Temp Sensor, for the heater. This is a very easy part to replace. The Thermistor is located on the manifold, on the left side, between the top two bolts.
Sorry this is a late response! Hope that it helps!
Posted on Jul 10, 2009
  • 990 Answers
SOURCE: E04 message on MiniMax NT 400 DV..Help!!
Your EO4 message tells you you have a fan problem. So ether your fan is diying wich you would hear or you have a bad presure sensor in your exaust. A new fan is a little pricey but the sensor is reasonable for heater parts. I can't be sure but I believe it ether screws onto or into your exaust and it just plugs on to your control board. If your sensor is going bad their is a reason and this should be addressed. It should be in your by-pass or your gas pressure. But as far as a new heater, not untill you have water coming from the cabnit. It is sometimes easer to sell new than keep up with new, Good luck let me know how you do.
Posted on Dec 03, 2009
  • 990 Answers
SOURCE: Water Temprature read 126 on heater and will not Fire
This is a problem with your thermister (heat sensor) You will find this on the left side of the water manifold about half way down. I'm not sure but I think it is a small tube that slides into the manifold and if you follow the wires back to the board it just plugs in. The part is reasonable priced for a heater part and very easy to install. Good luck.
Posted on Dec 21, 2009
Leisure Bay spa will not heat past 86 degrees. Element and sensors are new. Spa has excellent flow and correct voltage at terminals.
if the spa does not heat up to 104 degrees then the temp sensor is what you are going to need.
Are there error codes showing on the screen of the topside?
You will need to know the model number of the control box or the model number of the heater tube in order to get the proper sensor.
Rod
US Parts Center
888-521-6183
Feb 09, 2013 | Pool & Spa
Pool heater won't heat water
How big a pool? You normally will not notice a temperature rise immediately. On average, swimming pools will see a one degree rise in temperature every 45 - 90 minutes.
Jan 22, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
My spa heater is saying the spa is 126 degrees so
Use a thermometer to check the actual temp of the water to see if the units temp probe is accurate. Also what is the max temp allowed by the spas safety program...owners manual.
Thanks,
RSMITH972278
Oct 12, 2009 | Pool & Spa
Spa / hot tub does not heat
Your temperature control is way out of calibration or, it's wired wrong. Remove it and check it in a glass of water. Use an ohm meter across the heater wires. As you add hot wwater, the heater contacts should open.
Aug 11, 2009 | Jacuzzi Home
Spa will not heat more than 85 degrees or so
on the back of the board is the bottom for seting the max temp follow the intruction from the manual or get one at jandy.com
May 26, 2009 | Jandy Laars Lt 400,000 Btu Heater
Pool & Spa Logo
622 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
