Question about Toshiba Satellite L500 Series Notebook
My Toshiba with Windows 7 goes to sleep (or some sort of power saver) after 1 minute if my hands aren't on the touch pad. I have checked and changed all the power options I can find,
Disable waiting time in screen saver
Posted on Nov 19, 2010
  • manim6 Nov 19, 2010
Hp pavilion all in one AMD goes to sleep after 1 minute idle then asks for password to open up.. how to extend idle time to 2 hours
What you are experiencing isn't "sleep" mode, it is the screen saver. If you have WINXP, right click on a clear area of the desktop, and select "Properties". When the DISPLAY PROPERTIES window appears, select the "screen saver" tab. Change the "WAIT" time to the time you wish the scrren saver to delay. If you don't want to have to login after a screen time out, uncheck the "On resume, display Welcome Screen" box.
Nov 27, 2013 | HP Black Pavilion 20-b013w All-in-One...
Tip
PC sleep mode problem?
Follow this instructions to disable sleep mode
In windows XP
1)Right-click the desktop, and select "Properties."
2)Click the "Screen Saver" tab, and click the "Power"
button at the bottom.
3)Change the option next to "System Standby" to
"Never" for either "Plugged in" or "Running on
batteries" or both if that is what you want. Click
"Apply," "Okay" and "Okay" once again to close the
Display Properties dialog.
In windows vista
1)Click the "Start" menu, and then click the Control
Panel.
2)Click "System and Maintenance," and then select
"Power Options."
3)Select "High Performance" to disable the overall sleep
mode. The monitor will still go into sleep mode unless
you click "Change Plan Settings" and disable all sleep
options.
In windows 7
1)Click "Start," and then select "Control Panel."
2)Double-click "Power Options."
3)Select "High Performance" under "Additional Plans,"
and then click "Change Plan Settings." Change all of the
options to say "Never."
on Dec 17, 2010 | Computers & Internet
Instead of screen saver coming on it goes black i have a hp persario cq2 and windows 7 i am running mozilla fire fox
1. right click desktop and go to personalization
2. click screen saver
3. change your screen saver to "none"
4. click on power management
5. click on adjust settings
6. change both options to "never"
7. click save and okay
Aug 27, 2013 | Microsoft Windows Vista Home Premium with...
Created a 300 picture slide show on my pc. the screen will go blank after 30 minutes and i have to hit the return key or touch the pad. Is this a sleep setting issue or kodak?
I suspect you have a screen saver set up that blanks the computer screen after 30 minutes.
If you are running Window XP, right-click your mouse on the desktop, choose Properties, from the Display Properties dialog, click the Screen Saver tab, then in the Wait box, increase the amount of time before the screen saver activates. Click the OK button when you are through.
Good luck,
-- SalParadise
Feb 28, 2011 | Cameras
How can I disable my monitor's sleep mode? I don't want the screen to go black, I want to be able to see the screen saver as it cycles. Thank you.
You can do this in the Power Savings options with Windows. For Windows 7, rght click on the display (anywhere with no icons or running programs) and choose Personalize. Click on Screen Saver in the lower right hand corner. Adjust the Wait time for the screen saver if desired and click Apply. Then click on Change Power Settings. This brings up the Control Panel > Hardware and Sound > Power Settings. Then click on Edit Power Settings for the active power plan. (For desktops it is usually the balanced power). Then change the setting for Turn off monitor to Never when plugged in. Also change the Sleep time for the computer to Never. You can do the same for when on battery but it will shorten the length of time that the computer will be able to run on the battery for laptops. Then Save Changes and close the windows.
For older versions of Windows, these advanced power settings are also available from the Screen Saver settings page but details may differ.
I hope this helps.
(for most monitors, as long as the computer is sending a signal the monitor will stay on)
Dec 23, 2010 | Dell 22" SP2208WFP Widescreen Flat Panel...
Monitor on PC goes off after 2 seconds. Power and PC still on.
your operating system setting are possibly in the "sleep" mode and the display is set for 2 minutes.
1. check the "power options" in the Hardware and sound" located in the control panel for Windows 7. click the link that says " change when the computer sleeps"
2. windows XP check the helps or the power management in control panel.
Oct 17, 2010 | HP Compaq Presario SR2050NX PC Desktop
I HAV A TOSHIBA A-135 LAPTOP, THE SCREEN WENT DARK, AND WOULD ONLY LIGHT UP ON BOOT UP ( FOR 2 MINUTES) AND THEN GO DARK. IT WOULD LIGHT UP OUT OF SLEEP MODE FOR THE SAME (2 MINUTES). I HAVE REPLACED THE...
There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop", click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors' graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Click, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. Restart "Computer". *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click,"Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “I hope this Fix it!”
Jan 18, 2010 | Toshiba Satellite A135-S2386 Notebook
My monitor goes to sleep and I would like it to stop. I can't figure out how to accimplish this. Karen
That's probably a Windows setting. For Windows XP:
1. Right-click the desktop.
2. select properties
3. go to the screen saver tab in the window that opened
4. check wether the screen saver is set to "None" If not, do so.
5. Click the "Power" button
6. In the window that opened, set Turn off monitor to never.
7. You're done!
For Vista and Windows Seven:
1. Right-click the desktop,
2. In the windos that opened, click personalize,
3. Click screen saver (bottom right)
4. In the window that opened, set the screen saver to "None"
5. Click "Change power settings"
6. In the window that opened, click "Choose when to turn off the display"
7 Set "Turn of the display" to Never.
You're done!
Dec 07, 2009 | ViewSonic VG2230WM LCD Monitor
If i try to bring back from screen saver using touch pad the screen goes dark and i can only just see faintly the desktop. i have to switch off and restart machine to get it back
u must remove screen saver and go in screen saver property than go on the power there are some setting u must disable the power option and hdd sleep mode too be disable good luck enjoy vote for my comment
Aug 06, 2009 | Computers & Internet
My hp goes to sleep alot???
CHECK YOUR POWER SETTINGS
1. Right Click your desktop and click properties
2. On properties window click the screen saver tab. Beneath it, click the power button.
3. On the Power Schemes, you can either select the Home/Office Desk or Always On option
4. For the other options below, select NEVER for all of them and click apply.
5. go to the Hibernate Tab and take off hibernate and also click the apply button
Restart your PC and watch out if the problem still persists.
if it dos then you need to download a new Power Management driver or ACPI from HP's website.
If it comes to this pls let us know so we can assist.
May 22, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Toshiba Satellite L500 Series Notebook Logo
116 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
