Question about Stanley Bostitch N80s Nailer -rebuild Parts O`ring & Seal Kit
My nailer doesn't have the power it used to. the nail needs a tap with a hammer every 3rd blow or so.
    Problem Solver:
  • 3 Answers
If it is a nailing hammer for a roofing project, I have used a degreaser to spray the end. Even on my air nailers that I use 16d nails in I do this. Make sure you keep 3 drops of the (FOR THE NAILER) IN IT'S RECEIVING END EVERY DAY! This will keep the inside good and slick.
Posted on Jan 08, 2013
4 Suggested Answers
  • 1388 Answers
SOURCE: BNA125A Porter and Cable brad nailer
Both of these nailers have a check seal about half way down on the cylinder. This check seal causes the piston to retract if the piston ring is not too worn. The lower bumper should not be cracked and missing pieces, and the driver guide washer must be in place below the bumper. Also check that the driver is not bent causing it to get stuck. The da250b has an upper bumper of sorts and developes cracks that can only be seen by removing and inspecting, If cracked, the upper bumper must be replaced for proper function. The bn125a nailer probably has the discharge port clogged or upper valve parts worn or cracked. The headvalve should be inspected for cracks where the oring fits and the rubber seal should fit snug on the valve. There is a spring that pushes down in the headvalve that pushes from a rubber washer of sorts, check the diagram to be shure that all parts are in order. Both of these guns will not take too much pressure. Try adjusting to about 90 lbs max.
Posted on Nov 25, 2008
smjdragonfly
  • 79 Answers
SOURCE: Stanley Bostitch Coil Framing nailer blows head off of nail?
Make sure that when you run with one gun that your psi is between 90-110. You may need a kit. Is it an RN45 or 46? Go to Stanley Bostitch online and look up parts and schematics. Kits should only be about 15-20 dollars, easy to put in, and come with instructions. Lemme know. Please rate me
Posted on Jun 18, 2009
rowdy45176
  • 2176 Answers
SOURCE: senco roofing nailer 200r not feeding nails
You have a problem with o rings or the firing valve. I would go to Senco.com and they have a parts breakdown with a list of kits that are available for the tool. They also have a toll free tech support number is you need it.
Posted on Sep 20, 2009
MY NAILGUN QUIT FIRING NAILS. I LOADED UP TWICE AND USED NAILS BUT AFTER LOADING THE 3RD SET OF NAILS MY NAILGUN WON'T FIRE THEM INTO WOOD. WHAT I HEAR IS JUST A SMALL AMOUNT OF AIR FROM AROUND THE...
Sounds like you may have a nail jam. You didn't specify what type of nailer you have - most finish guns have a latch to open the nose & clear a jam - if it is a framer most of the time it requires a long punch and a hammer to push the driver back in past the jam to clear it.
Let me know if this does not fix your issue.
Nov 05, 2014 | Air Tools & Compressors
Craftsman take apart
Try spraying with WD40, then try working it loose or using one of the nails from the clip try push it it from the outside and tap it with a hammer to dislodge the stuck one.
Aug 20, 2014 | Tools & Hardware - Others
Hitachi Nr90gc2 nail jam
Use a punch as close to the size of the driver as possible and tap it with a hammer until the blade retracts and clears the jammed nail. Be careful and only hit it as hard as needed to clear the jam. Sometimes it will require a few good "whacks" with a hammer. Much easier then disassembling the tool and I clear jams on customers tools like that all the time here at my shop.
Jun 23, 2012 | Hitachi NR90GC2 Cordless Gas Clipped Head...
How do you remove the front hub to remove the stuck nail
If a nail is stuck between the driver and nose of the gun, you will need to forcefully push the driver back into the gun. Remove the head and cylinder and place the body of the gun on piece of plywood with nose pointing up. Using very sturdy steel rod, hammer the driver down. The steel rod needs to be slightly thinner than the driver to allow for the stuck nail. I use a broken driver ground thinner on the side that will need to bypass the stuck nail. Careful when striking hard steel with hammer, could spinter (I use a heavy brass hammer). Good luck
Nov 01, 2011 | Stanley Bostitch F21PL Nailer
Nail gun will not fire the nail. Compressor works fine. Hammer doesn't retract enough to hit nail? Cause, solution?
could be a jammed nail in the magazine nose area, bent driver blade or problem with the o ring being worn.
Jun 06, 2011 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
Using the BOstitch flooring nailer, good air pressure and using cleats. but when i tap with hammer noting happens. the nailer goes off as if it had gone off but no nail was driven.
1. check to make sure the magazine does not contain a jam.
2. check to make sure the driver retracts fully to allow the cleat to advance
3. Be sure to have at least 90psi and to hit the head hard enough to fully fire the nailer.
Sep 25, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
Plunger want retract
The hammer could just need to be oiled or you could have blown a seal in the gun which is not expensive to fix around 20.00 . A lot of times when my gun jams on a nail it gets stuck so the hammer won't go down. I just use something thin that will fit on the hammer and take a hammer and just tap it back into place.
Aug 12, 2009 | Stanley Factory Reconditioned Bostitch...
Arrow ET200 nail gun only put nails in 1/8 of inch.
This electric nail gun does not have much power. Try shorter nails and softer wood. You need a pneumatic nail or staple gun for medium or heavy work. I have both a nailer and stapler and neither are very good.
Jul 23, 2009 | Arrow ET200 Electric Brad Nail Gun
Nail Gun question
For every nail that a normal human with a hammer could hand drive on his best day, a pneumatic nailer would drive and set twelve! That is no exaggeration. Although there is no need to go this fast, a reasonable speed would allow you to be 400 to 800 percent more productive. Nailing large subfloors and roof decks is a breeze. Hours worth of work becomes minutes.
Aug 27, 2008 | Irwin 12" Bar Clamp Multi Position Jaw
Stanley Bostitch N80s Nailer -rebuild Parts O`ring & Seal Kit Logo
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
