Question about ASUS M2A-VM (0610839149438) Motherboard
Boot problem Installed in old eMachine chassis, front panel connectors don't match mobo. Jumpered PWRSR and RESET on mobo and on-board LED lights, CPU fan runs, chassis fan runs. There is no beep code(s), no CD/DVD or HDD activity, no sign of boot on display. Tried different PSU; reset BIOS cmos; disconnecting CD/DVD & HDD; and insulating mobo from contact with chassis other than thru connecting screws. This chassis uses raised "dimples" in place of brass standoffs. Mobo, Athlon 64 x2 4800+ PIB and Kingston RAM KVR667D2N5/1G, are all new. I would really appreciate any suggestions.
  • donvwilson Jun 21, 2008
    Thanks for the "Beep" codes, however, I specifically stated that I do NOT get any. The boot process doesn't go that far and/or the speaker is not functioning. In addition, my system is not a Compaq, it is a custom build based upon an Asus M2A-VM mobo.
    Genius:
  • 2,035 Answers
This could the problem with mother board chipset ics which may be defective take service center and get it fixed ,ask then how will it cost it cost you more than 50$ you can buy mother online for 75$ or check the SMPS connected to the mother board is compatible with mother board ...........
Good luck.......................
Posted on Jun 21, 2008
  • ASUS Master
  • 13,433 Answers
I would recommend geting a 4 digit bios power on self test diagnostic card to report the problem
http://cgi.ebay.co.uk/PC-Analyzer-Diagnostic-error-Card-Tester-Code-Bios-Post_W0QQitemZ280238210212QQcmdZViewItem?IMSfp=TL0806201016a2990
  • Ekse Jun 21, 2008
    If you have any questions I will gladly answer them
    First thing todo is to unplug everything that is not required, to start up, leave only the required parts, motherboard, psu, memory, vga. cpu connected. Then remove the ram and see if you hear the beep codes. put the ram back and try starting again.
    Remember to check all the power cables includeing the 4 pin cpu power connector thats a common mistake, too common.
    Thank you,
    Ekse
    Master:
  • 788 Answers
Only jumper the power switch (PWRSR), if you also jumper the reset then it would be like constantly pressing the reset button. Also, only momentarily short the power switch jumper to mimic pressing the power button, if not it will also be like constantly pressing the power button which will turn the machine off in about 4 seconds.
I good way of knowing if your motherboard is OK is to remove the RAM and listen for the POST beed code that indicates no RAM. If there is multiple sticks of RAM, try them one at a time.
If video is not on-board you can also remove the video card to listen for the no video beep code.
Posted on Jun 18, 2008
  • Dean Joly
    Dean Joly Jun 23, 2008
    Did you try only jumping the power switch connector momentarily and removing the jumper from your reset switch connector altogether?
    If this still doesn't work then you may have gotten a defective motherboard. Asus's site state that you should contact your reseller about warranty issues with your motherboard. (http://support.asus.com/repair/repair.as...)
  • 868 Answers
Have you tried jumping only the pwrsr?You may have a conflict when your jumping both RESET & PWRSR together. Please let me know ,I'll look for your update on this .
  • 796 Answers
Click here
this could help you
Motherboard booting problems...How do I solve?
Hi
Try to boot with 1 stick of ram then swap it with the other and try again. Next unplug the case front connections from the mobo header (pins). Draw a sketch where they all go so you don't forget. I'm talking about the power switch, reset SW, HDD LED etc. Also remove anything connected to the back panel printers etc. Also remove the mouse and keyboard. Carefully, momentarily short the pins that were connected to the power switch and note results.
If it still doesn't boot, remove all parts from the mobo except 1 Stick of RAM, graphics card, PSU, and of course CPU. Leave the mouse and keyboard unplugged. Try to boot by shorting the mobo pins again. If it doesn't boot it is most likely either the PSU or the mobo. It could also be the CPU or RAM but it is less likely.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 04, 2011 | EliteGroup RS482-M754 Motherboard
My emachine won't start the fans come on but no light any clue what i can do
it could be the front connectors...if you can read your mobo it should diagram it out for you...it will also say in the manual, not that anyone keeps them.
The LED is not important in retrospect but the PW switch should be connected right if the fans are coming on, could be a bad MOBO
also check:
RAM-if you have multiple sticks of ram one could've gone bad
CPU-remove the processor and heat sink, replace, being careful to seat it onto the mobo right, apply thermal paste and replace heatsink. the cpu would be my guess as the probable cause
Nov 28, 2009 | E-Machines eMachines Desktop PC
Worked out F_PANEL connectors.
Every motherboard has its connections manual, also case has marks and signs at its connectors, if your case has more then your motherboard it can be front panel audio and usb jack go to your motherboard manufacturer web site and search for manual for your model. Also there will be upgrades of your bios and also CPU types your motherboard supports. If you CPU is correctly inserted and when power on it ons and then automatically offs may caused because you dont have CPU fan installed and it cant cool so automatically powers off.
Jul 28, 2009 | Computers & Internet
Ultra m923 mid-tower case won't stop beeping
The problem is the board on the case's display. It has temp alarms for your components(video card, hdd, cpu), there are temp probes for you to set so you can monitor these temps. However the board that controls these functions, or at least mine and many others I have read about, is defective. It will change display constantly and sometimes have garbage display. It is setting its own limits for what is considered a hi temperature. The limit it has set for one of your components is < room temperature so it thinks you are having an overheating problem. You can manually set the limit for overheat and it will fix it for a while, but it will prob happen again.
Jul 03, 2009 | Ultra Products Ultra M923 Full Tower ATX...
Supermicro X6DAL-TG boot problem
I have 3 of these boards; however, they all have the Nocona Xeon with a Front Side Bus speed of 800MHz. The manual does not say anything about using a 533fsb. A second thought was if your power supply is an ATX with a 24 pin power connector and two +12 connectors one 8 pin and one 4 pin? The manual states all three need to be connected for the Xeon Processor.
Mar 30, 2009 | SuperMicro X6DAT-G Motherboard
Front panel ceonnctor
Intel® Desktop Boards meet the ATX motherboard design guide specification using a 9-pin front chassis header. Special attention is required when attaching the front panel connector from the chassis to the Intel desktop board.
Front Panel Header
Description Pins Hard Drive LED 1 - 3 Power LED 2 - 4 Reset 5 - 7 Power ON (Power Switch) 6 - 8Lou
Aug 25, 2008 | Intel D845GVSR Motherboard
Wiring info
Most Mobo's have printing next to the places that are jumpered or pluged into. The ones you need sould be close to the edge of the mobo, that is close to the front {power button} side.
May 30, 2008 | E-Machines (308714) Motherboard
Problem with installation and no display
Hi alvinkt,
I am using 5450 and it gives me voltage mismatch error and does not boot up, goes straight to BIOS. Is your board revised version with R in the end or pre revision. Could you please help me resolving this error?
Jan 26, 2008 | Intel S5000XVN Motherboard
Motherboard or CPU dead?
The burning smell (if it was a fishy type smell) may have come from the mobo psu 21 pin connector where you plug in the psu. The connection may not work properly because of melted plastic deposits which may be why you are unable to turn it off at the switch. Just check the old psu connector for signs of rusting pins and mis-shaped connector. If you have a fairly recent mobo and processor ensure that the power supply doesnt need the power supply from the psu, unlike some processors where the power is taken from the ZIF mobo socket.
Jan 18, 2007 | EliteGroup KT400 (L7VTA2 V2.0) Motherboard
ASUS M2A-VM (0610839149438) Motherboard Logo
244 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
