WONT START WASHING FILLS BUT DOESNT SPIN - Washing Machines
    President:
  • 1,654 Answers
I Have no Idea what machine you are talking about. So lets start with the timer mechanism, can you change settings on the machine and does it work then? if so I would suspect a bad timer, which I already think this might be. If it does not wash or spin on any cycle and makes a whirring or grinding noise then I would suspect the motor coupling. If it make no noise at all on any cycle and does not move the tub or agitator I would suspect a bad motor. I still would look at the time rcontrol first. Sometimes these get bad spots on them and they won't advance like they should. I hope this helps but there is no way to diagnose a problem like this without seeing the machine.
Posted on Nov 14, 2010
My washing machine wont spin
Hi if your Beko Wm & Wma Models washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Apr 12, 2014 | Beko Wm & Wma Models Washing Machine Motor...
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
It wont spin out
if it doesnt go into spin brushes in main motor could b stuck or worn check also outlet tube and waste pipe not blocked if it goes into spin but doesnt empty check spin pump not jammed but most common fault brushes in main motorworn
Mar 18, 2012 | Whirlpool Washing Machines
I have FAFW3574k- Fills w/ water. Starts to run cycle but then wont spin. Pump sounds like its running but water doesnt come out. Thanks Jeromy
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 07, 2011 | Frigidaire Washing Machines
Agitator doesnt start
Sounds like the lid switch is acting up on you.
Jul 26, 2009 | Whirlpool LTE6234D Top Load Stacked...
Wont spin and drain
What brand is this? If it a whirlpool or kenmore (or roper, estate) It is you lid switch. A very common problem but is cheap and easy to fix. Get me the model number and i can give you the part number for the switch.
Nov 21, 2008 | Washing Machines
Washer doesnt spin
ck the coupling between motor and gearcase it is probably broke and won't drive the transmission
Nov 08, 2008 | Kenmore 24032\24036 Top Load Washer
Washer on the fritz
ck motor coupling probably broke or cracked not engaging gearcase
Sep 09, 2008 | Kenmore Washing Machines
My kenmore washer fills up but then just stops
it could be several things, something is lodged in pump, so the motor wont run, the motor is bad, or you have a bad transmission.
Start with the pump and see if it has sock or something stuck in it.
Jul 12, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
