Question about Stanley Bostitch N80s Nailer -rebuild Parts O`ring & Seal Kit
My nailer doesn't have the power it used to. - Stanley Bostitch N80s Nailer -rebuild Parts O`ring & Seal Kit
  • joecoolvette
    joecoolvette Nov 17, 2010
    Also a sign of a dirty nail gun, and if it isn't an oil less gun, proper lubrication hasn't been applied regularly. (Air hose unattached, gun air inlet up, apply 7 drops of oil daily, squeeze the trigger in to let the oil circulate through gravity to the working parts)
  • 4,234 Answers
This is usually a sign that there is an air leak. Check the link below for directions to a site with both parts and diagrams. That should be helpful in replacing the O-rings. This is relatively common and a normal wear and tear condition.
Dan
Link: http://www.fixya.com/support/r5812776-bostitch_nailgun_dis_assembly_assembly
Posted on Nov 16, 2010
Porter cable repair
Try a set of Orings from the Oringstore online,,,,lots of times the o rings that seal the cylinder to the nailer body decompose
May 17, 2013 | Porter Cable Air Tools & Compressors
I need stainless nails for Makita AF505 nail gun
Your nailer uses 18 guage straight nails, from 5/8" to 2" long. As long as you meet these requirements it doesn't matter if they are basic bright, galvanized or staniless nails. If you Google or Bing search "18 guage stainless steel nails" you will find several mail order places that carry the nails you need. Not very many places carry stainless steel nails in stock because of their cost. Unless you live in an area where their use is predominant you will have to order them.
Oct 04, 2012 | Makita AF505 2Inch Brad Nailer
Paslode cordless framing nailer doesn't fire
check date on bottom of fuel canister, fuel goes bad
Sep 17, 2012 | SK Paslode Sk312 Framing Nailer O`ring...
Hitachi roofing nailer shoots every other nail & doesn't sink the nails it shoots
i think you have two different problems , replace the feeder spring, and replace the oring on the driver piston. also make sure that the coil of nails is perfectly round if they are dropped or squeezed tool will not work right
Sep 11, 2012 | Hitachi NV45AB2S Coil Roofing Nailer
I bought a Husky HFR 2190 Full head Framing Nailer and I need a owners manual.
Hi David,
I have searched for this this manual and this is what I have come up with.
Campbell Hausfeld own the Husky brand.
This link is for an IFN2190 which may be the HFR2190 rebranded as "Iron Force". The specific HFR2190 manual doesn't appear to be available.
http://powertool.manualsonline.com/manuals/mfg/campbell_hausfeld/ifn2190.html?idRes=1235852
If it doesn't suit your nailer you can cancel the $12 fee
Hope this helps.
Dec 20, 2011 | Tools & Hardware - Others
The nail sets to deep is there an adjustment or is the bumper worn out
Hi dfreerugs,
Welcome to fixya!
Where do you have the pressure set at on your compressor? The range for this nailer is 70 to 90psi. Try lowering the pressure until the nails drive to the depth you want.
If the gun is well-used and lowering the pressure doesn't do it, you might need a new pressure regulator in the gun.
You can download a user manual at Amazon.com at this address: http://www.amazon.com/Bostitch-MIIIFN-2-Inch-Pneumatic-Flooring/dp/B0000302TH
Scroll down to the "Product details" section and click on "Product manual".
Good luck.
Please place a vote when you accept this solution. Thanks,
Handie Andie
Aug 16, 2011 | Stanley Bostitch MIIIFN Flooring Nailers
My nail gun doesn't seem to want to work at all. I followed all dirctions for preparing it and breaking in the compressor but the gun doesn't do anything.
Assuming no air leaks. The headvalve of this nailer tends to stick in the head due to tight fitting orings. Remove the head and press in the headvalve with your thumbs. If stuck, apply air pressure to vent hole on the machined edge of the cap and lube the orings with silicone paste lube (sold at Lowes in the plumbing department). If silicone paste is not available, use nailer oil and re-install valve/head for test.
Aug 02, 2011 | Porter Cable FR350A Factory Reconditioned...
Nail gun will not fire the nail. Compressor works fine. Hammer doesn't retract enough to hit nail? Cause, solution?
could be a jammed nail in the magazine nose area, bent driver blade or problem with the o ring being worn.
Jun 06, 2011 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
My nailer doesn't have the power it used to. the nail needs a tap with a hammer every 3rd blow or so.
If it is a nailing hammer for a roofing project, I have used a degreaser to spray the end. Even on my air nailers that I use 16d nails in I do this. Make sure you keep 3 drops of the (FOR THE NAILER) IN IT'S RECEIVING END EVERY DAY! This will keep the inside good and slick.
Nov 14, 2010 | Stanley Bostitch N80s Nailer -rebuild...
Nailer drives one nail but driver pin doesn,t retract back into nailer head
Remove the air hose and open the nailer head section. Look for a foreign object in this are that could be jamming the drive pin. Also, make sure you are using the right size nails.
Jul 11, 2009 | Craftsman Nailer Kit, Palm Air Driver
Stanley Bostitch N80s Nailer -rebuild Parts O`ring & Seal Kit Logo
57 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
