Question about Dishwashers
Kenmore BuiltIn Dishwasher Stock 17512 Model 17512200 Type 575-0 Serail FM3309375 Probelm: Water sprays out of lower arm weakly, and not out of upper arm at all. Action taken: Unscrewed the 4 screws holding down the item underneath the lower spray arm, and then the small item under that. Found major refuse from years gone by, removed, cleaned. Reassembled, same issue. I suspect I have to get 1 more level down, to the intake for the pump? found 2 screws to remove, but was not successful. Is there a trick before I bust something?
catriver
  • 878 Answers
SOURCE: small plastic top and mid spray arm do not turn, bottom does
decrete, you want to get down to the chopper and screen. If the screen is plugged up with gunk there won't be enough pressure to reach the top spray arms. Check out the posted pics. Remove the lower spray arm. Rotate the rear feed arm to the right until it unsnaps from the tube going up the back. See the 4 torq screws holding the filter on. Remove them. Lift the filter up. Now you will see the chopper inlet cover. 1 torq screw holding it in. Lift it up and there's the chopper and screen. Catriver..post back
Posted on Apr 09, 2007
SOURCE: Dishes not cleaning particularly on top rack
Thank you, so much, for the update!
Lita
Posted on Jun 18, 2008
SOURCE: Dishwasher upper arm does not spray
possible ball valve problem
Posted on Jan 03, 2009
SOURCE: Can't remove lower spray arm
the nut screws off counter clock wise.
Posted on Mar 18, 2009
  • 423 Answers
SOURCE: LG LDS5811WW Low pressure out of spray arms
On the LG LDF xxxx dishwasher family, the Vario feature uses a motor/check valve to switch between "full power" cleaning from _either_ the lower or the upper spray arms, never at the same time. So, not seeing the upper arm spin during the lower arm spinning is standard operating procedure.
But back to your problem. Step one would be to remove the filter assembly again and make certain that there is nothing (debris, broken glass) blocking the white areas where the check valve rotates to switch between upper/lower spray arms. A blockage there ~could~ cause impotent spraying/cleaning.
If there is no blockage and the impeller remains in good shape, suspect a failing wash pump motor. Try to isolate the noise to that motor.
Watch for error codes on the display and report back what you find, OK?
Good Luck!
Posted on May 14, 2009
Kenmore ultra wash III portable dishwasher. Model #1765991. Lower wash arm came off. How do I re-attach?
Hello. The lower spray arm screws down onto the center, round, plastic part (spinner) that has threads on the center portion. It's very loose and spins easily because it uses the water spray to drive it. At the top of the threads, there will be a flat piece of plastic. Set the spray arm down onto the threads. Hold the flat plastic area that sticks out above the arm with pliers. Spin the spray arm counter-clockwise while holding the spinner. It will thread itself down about a turn or so. Snug firmly--DON'T OVER-TIGHTEN the spray arm onto the spinner. Remember, it only uses water pressure to spin so it doesn't have to be "gorilla tight"! I hope this helps you!
Oct 14, 2015 | Kenmore Dishwashers
Dishwasher spray arms don't spin & spray water
Check that the water pumped on arms has enough pressure.
Aug 15, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
LG dishwasher model LDS4821- 16 months old- getting E1 error. Water leaking on floor. This happened before 3 months ago but then had no other problems with it until now. No other problems with this machine...
Hi ferrojennife,
The E1 you are seeing means Water Level in Drum lowering, this means there is a leak on one of the pipes. More likely it is the Circulation Pump, which is responsible for pushing the water to the Spray arms.
It will have to be replaced, as it is a common spare that has to be replaced on L.G Dishwashers (lifetime expectancy: 12 - 18 Months) - Not very expensive.
Usually is about 20%-25% the price of a new Dishwasher. The Circulation pump is fitted to the sump. Part Number: 5859DD9001A or 5859ED1001A (Depending which one is in stock)
See below a image of what a Circulation Pump looks like:
Good Luck :-) - J.Q
* If you found this solution helpful, please vote for it
Jun 09, 2011 | LG LDS4821BB 24 in Builtin Dishwasher
Hello, I have a Kenmore Ultra Dishwasher, model # 665.16533200. Lately the top rack dishes have not been getting clean. Also the glasses with indented bottoms, that are normally full of water at the end of...
might wanna check the connections on the back of it and make sure nothing has broken behind it....also may wanna get a mop and some towels something tells me its throwing water out the back side of itself while its running
Apr 16, 2017 | Kenmore Elite Stainless Steel 24" BuiltIn...
Model: Whirlpool DU1055XTVQ Problem: dishes come out dirty, especially in top rack. Water does not seem to be coming out of holes in either upper or lower arms with any force whatsoever. What do I do?
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Dec 20, 2010 | Whirlpool DU1055XTV 24 in Builtin...
Lower spray arm not working, no water or spinning during wash. Any ideas?
Arm is rotated by the water flow. Unplug the dishwasher and check that the pump input is not blocked by food particles etc
May 01, 2010 | Kenwood KDW243A Builtin Dishwasher
Our dishwasher is type no:575-0, model:665.17369301.dishes r not getting clean properly.
This may help you.
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 22, 2009 | Dishwashers
Kenmore dishwasher model # 665.15522000 leaking badly
Hi, Make sure the jets in the spray arm ore not plugged at all. Check the black bellows on top the lower spray arm and see if it has a split in it. Let me know if these help or if I can assist you further.
Vic
May 21, 2009 | Dishwashers
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Lower spray arm is not rotating
call sears help line thewy have mech that can help
Mar 14, 2009 | Kenmore 15899 Built-in Dishwasher
Dishwashers Logo
197 people viewed this question
Top Dishwashers Experts
Owen Barnes
