Question about Sewing Machines
I cannot seem to get the top thread of my machine to pull smoothly through the tension disks. The machine was bought as JCPenney 25 years ago, no name brand-- Thank you!
    Genius:
  • 1,788 Answers
Are you trying to pull the thread when the presser foot is up or down. Try this, rethread, then with the presser foot up, pull the thread it should feed smoothly, Now put the presser foot down, now the thread should barely move. Sometimes this seats the thread in the tension discs. Also, check your top tension control, I use 3 and maybe that will help you. Is your bobbin threaded right? Hopefully, this will help
Posted on Nov 14, 2010
Kenmore 148 bobbin thread ends up a snarl under the cloth. Seems like thread is not coming off bobbin smoothly or measured, ending up with tangle and stopping.
Usually it is your top threading or your needle needs to be changed. Rethread paying close attention that the thread is in the tension discs right. Try with presser foot up, pull thread, it should pull smoothly, now put the presser foot down, it should barely move. This usually seats the thread in the tension discs.
Jan 01, 2011 | Kenmore Sewing Machines
The machine won' tsew as if the tension is too tight any ideas?
try rethreading the machine top thread & bobbin
try a tension of 3 or 4
make sure the thread move smoothly around the tension disks
make sure before threading the needle that the thread pulls smoothly
Nov 17, 2010 | Brother XL-5130 Mechanical Sewing Machine
I have this sewing machine and it seems that my tension on the top is too tight because my stitches on top are really tight and then the thread breaks. It feels like something needs to be greased or...
try the tension on 3-5 & see if thats any better,,
you might also check the needle to see if it's damaged or has a burr
it could be a belt going bad
also make sure the top thread is not caught on anything like the spool holder pin or tension disk
check to make sure the thread pulls easily around the tension disk
try rethreading the top thread
sometime the needle & thread are not compatable--try this & see if it works for you
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Oct 21, 2010 | Singer 3116 Simple
Thread breaking problem
The problem is that the nylon thread will actually cut into the race cover and create groove, it should be smooth. The only way to correct this is to replace this cover. I can not stress enough do NOT use nylon thread on your sewing machines, it will do permanent damage and cost you 100s of dollars in repairs.
I have 25 years experience working on these machines and have seen this happen time after time.
Jun 27, 2009 | Bernina Activa 130
I have the Brother ls2125i and LOVE the machine...in the middle of sewing, it started making very big loops on the bottom stitch and they do not catch the thread from the needle. Is it the tension?...
Here are some things to try:
Big loops are actually easier to solve usually. 1st know this: Loops on bottom means the top is too loose or the bottom is too tight. With loops that big its probably the top is too loose. 1st look in tension disks, there is likely a chunk of thread in there. A toothpick is handy to dig it out (the flat kind) 2nd make sure that the thread is getting between the disks when threaded. 3rd Make sure the thread is in the take up lever (the thing that moves up and down in front and not the needle bar or any part of the needle bar.) If neither, then the bobbin case could have a burr on it and the thread is hanging on that burr. Also the bobbin case may be in wrong. I hope this helps
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on top and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no matter how much thread you pull, your thread is good. If that your machine passes that test, we can go to step 2. If not, try different spool of thread, do the same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Kent
Mar 22, 2009 | Brother LS-2125 Mechanical Sewing Machine
My bobbin thread keeps looping up on the bottom, and after adjusting the tensions both ways I can't get it to stop making a mess.
try this:
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on top and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Thread test
Step 2:
Jamming bobbin case:
If it is damaged from turning out of place once, it could have rough spots on it that makes the thread hang on it, and keeps making it turn over and over. Use a finger nail board (fine sanding) and smoothall rough spots. Then reset the bobbin case taking care to put the notch in the bobbin case in alignment with the proper spot in the machine (basically 5 o’clock) when looking at the round area where the bobbin case goes
Mar 20, 2009 | Brother LS-2125 Mechanical Sewing Machine
White 1620 will not maintain thread tension
Sounds like it could be thread, try this: Thread test
Step 2:
Mar 19, 2009 | Sewing Machines
Bottom of stitch is bunched with alot of thread and machine jams
Try these time savers:
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Mar 17, 2009 | Singer 3116 Simple
My basic singer 5932 machine that I've had for about 11yrs is acting up on me....Never had a porblem til today. Probably an easy one for you experienced sewers. The thread underneath is very loose and...
Tension:
Also look at:
Thread test
Step 2:
Jan 19, 2009 | Sewing Machines
Sudden knotting under fabric
I have an Elna 2005 machine and had a similar but opposite problem whereby the tension up top was too tight - thread wouldn't pull smoothly. I found adjusting the feed dog lever slightly helped the stitches a lot, even though the needle tension up top is no better. Hope that helps! :-s
Jul 01, 2007 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
43 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
