Question about Intermatic Inc. ST01C Digital In-Wall Timer
I did conect my in wall timer item # 0192773 and i did set up for sat 13 /10 and Im wonder if I do have wrong wire betwen white wich is neutral wire and red becouse it is no way to turn the light on at the time i did program
  • 3 Answers
I have wired correctly. When I press on and off the device works correctly but will not program. I have details of what I have tried. I have read through all of the posts on this site. I know about the sun, mon, tues, settings at the top and the DST and the short time frame between each time setting. My question is posted here. Please help http://www.fixya.com/support/t14584806-unable_program_utilitec_0192773_timer
Posted on Oct 08, 2012
I wrote a page and tested Utilitec timers
Wiring and programming is shown on page:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Here's how to tell where problem is:
Press ON-OFF button to see if timer turns on lights
If manual override does NOT work, then wiring is wrong.
If manual override works, and lights turn ON-OFF, then programming is wrong.
Press ON-OFF and then add a comment for more help.
Posted on Nov 14, 2010
Why is Utilitech wall timer making lights flash?
You have connected white and red wires together.
White wire must be connected to neutral or to ground to operate timer mechanism, display and switching.
Copy following links to see correct wiring for Utilitec timers.
http://waterheatertimer.org/How-to-wire-timers.html
Jul 30, 2012 | Hardware & Accessories
Im trying to install a Utilitech 0192773 self adjusting wall timer. It has four wires, black(hot), red(hot), white(neutral) and green(ground). I have a standard three light switch plate(outside light,entry...
Thank you for clear description of wiring, switches, and for including timer model number.
1) Open following link for ez programming and wiring for Utilitec.
2) Your single-pole switch has 2 wires.
0192773 replaces single-pole switch only.
Black wire that connects each of the switches is Hot wire: connect this wire to timer Black wire.
Other black wire that connects to switch goes to load: connect this wire to timer red wire.
Timer white wire connects to white wires that are covered with wire nut.
Timer green connects to bare ground wire.
3) How to connect stranded wire and solid wire
http://waterheatertimer.org/How-to-twist-electric-wire.html#stranded
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Intermatic & Self-Adjusting Wall Switch...
Bought a Utilitech #0192773 to replace an older and non-working Intermatic SS7 series. The Intermatic had a black wire connected to hot, and a blue wire connected to neutral, and a red wire was capped off...
Utilitec 0192773 replaces single-pole switch and will not work for 3-way applications.
Open following link for clear wiring and programming steps for Utilitec 0192773
Utilitec can also be tricky to program if you are setting up astro dawn-dusk function.
For others finding this thread, same wiring applies to in-wall programmable timers by GE, Woods, Swilight, Sylvania, Tork, Hagar, UPM, Leviton, Grasslin, Wattstopper, Westek, and Intermatic analog timers. Intermatic battery-operated, Brinks and Aube timers are wired differently since they also work for 3-way applications.
Jun 05, 2011 | Intermatic Inc. ST01C Digital In-Wall...
GE smart digital timer was installed according to instructions. Timer was set to turn lights on at 5:30, and the lights blink on and off but will not stay on. I tried reprogramming, but same result. ...
It sounds like wiring is wrong.
If you have GE Tork Intermatic UPM Woods Brinks Hagar Pass-n-Seymour Stanley Westek in-wall timer, with red, black, white and green wires, then you probably put red and white wires together.
Add a comment any time.
See instructions along with image at following link:
Heres how to wire timer
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button > with GE timer, door is push-button switch. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Dec 11, 2010 | UPM Programmable Wall Switch Timer
I, too, only have 2 wires in my switch. It is not clear what to do with the 4 wires on the utilitech 0192773. Did not see the answer to the same question.
I wrote a page on the Utilitec 0192773
It shows how to wire the timer and shows the manual larger.
Timer-green wire connects to bare ground wire.
Here's what to do Switch has 2 wires.
1) Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. These are the neutral wires. Connect timer-white to these wires.
3) If electric box does not have white neutral wires described above, then connect timer-white to bare ground.
4) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Nov 14, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Utilitech Wall Timer #0192773 does not switch landscape lights on? Replaced Intermatic that had 3 wires. Black to Black, blue to black and red was capped. Utilitech came with 4 wires - black, white,...
Old timer: Intermatic EJ500 & ST01C timers have a battery. Battery operates the clock motor. Red wire is for 3-way circuit [a hallway with 2 switches is a 3-way circuit].
Utilitec timer, clock runs on 120Volt circuit instead of battery. So clock has to have power.
How to connect wires:
Black timer wire connects to hot wire from breaker box.
Red (or blue) timer wire goes to landscape lights.
White timer wire connects to white neutral wire [or if no neutral is available, connect to bare ground wire].
Green timer wire goes to bare ground wire.
How to find black hot wire and white neutral wire inside box
: Disconnect and separate wires so you can test. Use ordinary tester. Power is on. There is only 1 black hot wire inside each electrical box. Test each black wire to bare ground until tester light comes on > that identifies the black hot wire. Next, test black hot wire to white wires until tester light comes on > that is the neutral wire. Exception: This test does not necessarily work with 3-way switches since they reverse each time switch is thrown.
Sep 14, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Once in wall and operating lights blink and there is clicking noise at the switch
You have timer wired wrong.
If you have ST01C timer, then red wire is connected where blue wire should be.
http://waterheatertimer.org/ST01C-program.html
If you have another brand of timer, then white wire is connected to red wire.
White wire must be connected to Neutral or to bare ground.
If you have different timer, add a comment with in-focus photo of your timer for correct identification and possible assistance.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help
Also take advantage of fixya expert assistance live.
Aug 26, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Intermatic Inc. ST01C Digital In-Wall Timer Logo
154 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
