Question about Goodman B1859005 Induced Draft Blower Motor
I bought a new inducer motor and wondered if it matters which way you hook up the two wires on the motor because they are not labeled
    President:
  • 1,378 Answers
Sorry this took so long...I just came across this post today...
No, it does not matter. Wire one line wire to one motor lead pairing either lead to either wire.
John
Posted on Dec 11, 2010
My Honeywell smartvalve stop opening the gas valve, inducer motor started, glow and pilot happen, just no fire...I replaced said smartvalve and upon installation, the inducer motor wouldnt run, no glo
Double check the wiring connections, maybe you have the pilot valve and the main valve wiring reversed. I had a call one time where the homeowner installed the gas valve backwards, so no flow and of course and the wiring on the three terminals was reversed.
The inducer should start whether or not the gas valve is wired wrong, unless it is wired in parallel with the pilot valve.
Jan 21, 2015 | Honeywell Heating & Cooling
My Honeywell smartvalve stop opening the gas valve, inducer motor started, glow and pilot happen, just no fire...I replaced said smartvalve and upon installation, the inducer motor wouldnt run, no glow or...
Smartvalves are tricky and a certain sequence must happen. Without going into this in depth, try this:
Install new smartvalve
Set thermostat to the off position
Kill the power to the unit
Restore power to the unit
Turn the heat on with the thermostat
In this order!
Aug 29, 2017 | Honeywell Heating & Cooling
How do I wire a induce fan motor
Induced fan motors on older units are wired through the high limit safety on the stack - in series. When the furnace calls for heat, the induced fan motor comes on and after a time the furnace will light.
Older units have a temp switch in the stack that rotates to bring on the burners and blower motor. . When there is a call for heat, the induced draft fan motor comes on and then the burners will light.
After the heat exchanger is warmed up the limit switch will bring the blower motor on. That's basically how it works - there are two circuits - one for the induced draft motor and the burners and the other for the blower and high limit.
New units have a plug on the board you just plug in.
A
Oct 04, 2014 | Heating & Cooling
Changed inducer motor, now furnace will not ignite and gives code 31
since there is no model number to go by, let's go generic. Most inducer motors have some way of "proving" it is running to the control board. It may have a centrifugal switch in it or it may have use some type of air pressure switch. The centrifugal switch will usually have 2 wires other than the power wires and most of the time, go to the rear of the motor. The air switch usually has a small rubber hose that pushes onto it and is connected to the fan housing.
Aug 06, 2017 | Carrier Heating & Cooling
Janitrol furnace, Model # GMT090-3, built in February of '02. The induced draft motor runs for a half second, then quits. Indicator light blinks rapidly and continuously, indicating 'incorrect twinning'...
I ran into a simalar problem and it was a short in the control wiring of the furnace. When there is a call for heat a relay closes to start the inducer the movement of air causes by the inducer closes the air pressure switch. This is where the problem starts.some where in the control wiring there is a dead short this causes the secondary (24volts ) to drop causing the inducer relay to open shutiing off the inducer which in turn opens the pressure switch removing the short and the cycle starts over again. The culprit in my case was the high limit switch which was shorting against the metal furnace housing. You can easily ccheck this by removing the two wires from the fan limit switch and powering up the unit to see if the inducer runs normally . If it does remove limit and replace if necessary.
hope this helps
Oct 10, 2013 | Goodman Heating & Cooling
How to wire motor sta rite p2ra5e 181L
The green wire is the ground and bolts onto the motor frame on the top part,(should see a green screw). the other two wires go to the two posts with screws to clamp down on the wires. It does not matter which way these two are hooked up, one on each post.
Most motors are pre-wired for 220v from the factory. If you have 220v you're good to go. If you happen to have a 115v setup the motor will run at half speed. The motor can be converted to 115v by moving a brown wire and a white wire in the motor. The diagram is on the motor label.Best to verify your voltage first.
Mar 21, 2013 | Sta Rite Sta - Rite 1hp Dura - Glas...
FASCO A173 draft inducer motor wires to capacitor
on most capacitors there are terminals that bare set as parallel dashes or t bars. A wire to either line of bars or one to t and one to bar. --as long as they are on different lines is all that matters
Feb 17, 2013 | Tools & Hardware - Others
A couple of weeks ago my Goodman furnace went out. It happened to be a big snow storm here in Chicago. So I called my furnance repair co. that i usually use. They charged me $189.00 to come out to check...
If the inducer fan is out of balance that badly, then you will need to replace the inducer anyway....it will shake its self apart....
Me I would have fixed the wire and then ordered a new inducer right a way and then installed it in a few days when it arrived...in is trouble waiting to happen...
Put the wire back on and get a new inducer coming...
heatman101
Here is a tip that wrote about how to buy heating and air conditioning parts online.
How to find Air Conditioning, Heating and Furnace parts online.
Feb 20, 2011 | Goodman CACF048B2A Air Conditioner
Need to know how the wires go on a kobalt 230 volt air copressor
When looking at the switch it self, There will be 4 contacts. On the switch 2 will be labeled Line (Power in) and 2 will be labeled Motor (power out to motor) . Hook the black and white wires from the power cord to the line side (Either contact, it does not matter). Hook the 2 black and white wires from the motor to the contacts labeled Motor on the switch. The remaining 2 green wires (one from the motor and one from the cord) are to be grounded to the case on the switch.
Oct 01, 2009 | Coleman Powermate 60 Gallon Air Compressor
Goodman B1859005 Induced Draft Blower Motor Logo
207 people viewed this question
Top Goodman Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Goodman Garden Expert? Answer questions, earn points and help others
