I have a coleman evcon furnace a/c unit i have water in my floor which i think is a overflow from the cindensation line. i went uner my trailer and unhooked the rigid plastic line from the flexabile hose and blew out the rigid line. tryed to put a metal clotheshanger up the rubber hose line but only got so far. how do i get to the line from inside the house there are only 2 lines in the front 1 is the gas line and the other is the line from the a/c unit outside. unit inside is surrounded on 3 sides by walls is there anyway to get to drainage hose and pan without tearing out a wall?
    Scholar:
  • 104 Answers
The front of the unit should lift up and off or pull straight out at the top (some are one way, some are the other) However, it sound like you can get to the outlet where the water should be coming out. May I suggest using a shop vac. I am a HVAC tech and have to deal with this problem at least a couple of times a week in the summer and I have yet for a good shop vac to not do the trick. If you take the front off of the furnace, turn it off at the thermostat first. Also you have a typical installation, only one side of the furnace opens for service anyway.
Posted on Jun 19, 2008
I have a Coleman Evcon Elec Furnace with the added AC Unit. The blower works great with the AC but only on & off with the heat, what could this be?
Replace the sequencer...which is just a series of snap disc relays that are staged. The first snap disc should kick on the first element & low speed of blower. Depending on how many elements you have, determines how many snap discs are on the sequencer. It could be a 2,3,4, or 5 stack. Generally the coil is 24 volts.
Dec 01, 2012 | Coleman Evcon Furnace Control Circuit...
I have a coleman evcon gas furnace in a 95 trailer the draft fan stays on until you tap on furnace
Most Coleman units in a trailer dont have a draft fan. Are you talking about the fan that blows air through the floor registers? If yes, then you will probably need a new fan/limit control. If you do have a draft motor, you would probably need a new circuit board or draft fan relay.
Jan 02, 2010 | Coleman Propane Forced Air Heater...
Dripping water from pan or coils
If the a-coil is on the suction side of the blower, the drain line needs to be trapped. take enough hose to make a circle below the drain fitting and then into the drain. The blower causes a suction up the drain line if it is not trapped and will not let the water go out the hose.
Aug 03, 2009 | Coleman Heating & Cooling
Coleman Evcon Heater drain tube backup
has to be clogged or frozen must get drain open or will shut down furnace
Dec 13, 2008 | Coleman Propane Forced Air Heater...
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
101 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
