Question about Sharp Audio Players & Recorders
We have a Sharp Micro Component Stereo System XL-DK257N and it's been working fine for a year but suddenly it stop working. The stereo just keeps shutting off when you try to power it on. You would see the "POWER ON" and then it would just shut off by itself and would not stay on even for a minute. I've tried another outlet, tried resetting it using the manual that came with it but to no avail. I really love this system and I hate to just throw it in the garbage. Please help. Thanks!
SOURCE: CD problem in Sharp Micro Component Shelf system XL-HP515
Compra un disco limpiador de lentes laser y puede que esto solucione tu problema ya que puede ser solo suciedad en el lente.
Posted on Apr 09, 2008
SOURCE: XL-MP60 Micro Component System
Email answer I got from Sharp:
I do apologize for the problems you are having with your audio unit. The protect mode
indicator will appear when the unit detects abnormal resistance in your speaker setup. I
recommend removing any additional speaker wire that may be added to the unit to extend the
factory speaker lengths. Also, make sure you have all the factory speakers attached, and all
non-factory speakers removed. Finally, please unplug you unit from he wall for 1 hour after
checking all of the above suggestions to completely reset your unit.
If you are still having issues after doing all of the steps mentioned above, the unit may need
to be evaluated by a Sharp Authorized repair center.
Posted on Nov 02, 2008
Davidguitar
SOURCE: Harman Kardon Go + Play Portable Speaker Keeps Shutting Off
I just had this exact problem. I'm using an ipod mini. I solved it by docking the ipod firmly at the angle
the dock is at and have the ipod at an angle, not flat. I put the plastic and rubber adapter for the mini as instructed and also placed the rubber adapter for the nano upside down to keep
the ipod propped at an angle. (Also can use something similar to keep ipod propped up at an angle)
Took a while when I first used to figure out how the dock worked. The dock is a little weird how it is hinged to go from an angle to flat. Nothing in the instructions about this. By putting the ipod flat it would still have a connection to charge and play but the power shuts off every 10 minutes. I spent a whole night having it shut off every 10 minutes. This drives me crazy when systems have features like that which always seems to cause more problems (just my humble opinion)
By having the ipod at an angle I'm currently just now having it run an hour and 20 minutes and counting with no shut offs,(fingers crossed) but so far so good.
Saw on the internet that if the ipod is not connected firmly the system has an auto shut down. I think the ipod's weight propped at an angle keeps the connection firm. Also some said they want to see the ipod display, there you go!!!! This seems to be working so far for me, may be worth a try...I was about to return mine but I love the sound so I'm keeping mine now!!!! Works fine. Happy camper again.
Please reply if this works for anyone it worked for me.
Posted on Apr 27, 2009
SOURCE: Finding an Instruction Manual for Sony stereo system
How do I remove the protect mode from my Sony LBT-LX5 Stereo?
Posted on Mar 08, 2010
toolkits
  • 1099 Answers
SOURCE: XL-MP60 Shelf System: stereo shuts down and reads protect...
Hello, the problem of you stereo appliances been shut down was as result of a mechanism jam of the system.
The way you could do this is to open the back cover of the appliances and check for the rubber attached to the motor of the appliances, also check and see if you can adjust the mechanism if it is a disorder manner, it require a careful approach.
This will require a skilled personnel to handle this
Posted on May 19, 2010
Discs in my Sharp XL-Mp130 stop playing I have used a cd lens cleaner...still not working properly
Are you using a dry lens cleaner or one you put fluid on the brushes ? Place a small amount of isophrofyl alcohol on the small brushes of the lens cleaner and run this through 2-3 times. If problem still exists it's probably the laser,your options are to check online (google it) or drop into a stereo repair shop for a replacement. May turn out getting a new system is the cheaper and better idea as labor costs can be expensive.
Jan 30, 2017 | Sharp XL-MP130 CD Shelf System
Stereo turns on shuts off after few seconds
This is a bad power supply. You have to do some serious work at the component level of the unit to fix it.
Jan 22, 2014 | Sharp Electronics - Xldk257n - Xl-Dk257n...
I want to connect my XL-DK255 to my TV (Sanyo DP26671). Please help!!!!
http://www.manualowl.com/m/Sanyo/DP26671/Manual/211922
the only way to connect them is audio ...and you can either connect the Tv to the system ..(for better sound ) ..and in this case use the rca (left /right ) to rca (left right ) on the sharp ..if it supports..or ..use a double rca stereo cable ..with a jack 3.5 end ..and insert it in the audio input of teh sharp system ..
The signal from the Tv it will have to be taken from the audio out like in th epage 13 of the manual ..(it has a mono exit ..on rca probably ) and a left and right stereo one ..
If the sharp supports rca stereo in ...use it ..or ...just use the jack (3,5 stereo ) in ...and do not forget to select the proper channel ..
if the sharp system has a TV input channel for sound..on the receiver..use it ..and select the TV to playback the sound ..if it do not ..use the aux.. and selct the aux for control it ..
I do not believe you need to connect it in the other way cause it is not make any sense ..but the procedure is the same ..get audio signal from the system and insert into the audio in of the TV ..it is in the same place and also available mono and stereo ..You will have to select the input in the tv menu..
The cable you need for a stereo connection I think will look like thi s..
http://www.alibaba.com/product-gs/369945799/Factory_direct_supply_Adapter_Cable_jack.html
Jul 20, 2011 | Sharp XL-DK225 Shelf System
May 17, 2010 | Sharp XL-MP60 Shelf System
HX-D7 DVD Compact Stereo Audio / Video System with 5 DVD Changer Shelf System: my jvc was working fine but all of a sudden it sto...
Hello
this could be a power fault, but first check the power plug if it is in contact with the power socket and if it is then you have to open the back cover of the system to check the fuses if blown resistor,capacitor and transistor with the use of a multimeter to check for back component and if bad replace faulty ones.
Then power on to confirm, if not on then take it to the manufacturer or a skilled personnel to handle it
May 17, 2010 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Car Stereo in 1999 Accord stopped working
take it to a pro dont waste your time
Jan 27, 2010 | 1999 Honda Accord
Sharp Micro Component System XL-ES50 won't turn on
my copies sharp mx 2700n how to go SP mode and i get eroor code h5.01
Dec 22, 2008 | Sharp XL-ES50 CD Shelf System
Sharp XL-HP505 Not playing CDs
Hi try this.....
Put the system in standby (ie off but plugged in) then whilst pressing down the record button and the X-BASS/DEMO button, press the PRESET DOWN (i.e.left hand one) button until "CLEAR ALL" appears, then power on your system.
This gave me some functionality back i.e. i can play normal wave CD's but not mp3 ones....
Hope this helps
Sep 07, 2008 | Sharp XL-HP505 CD Shelf System
Apr 09, 2008 | Sharp XL-HP515 CD Shelf System
313 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
