Question about JVC Televison & Video
I have a jvc hd56g887aa rear projection tv turned it on and no picture or sound . menu won't even come any ideas , could it be the lamp or more
  • 579 Answers
SOURCE: Philips 46PP9302 46 in. Rear projection -
The power supply section is not working.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- CRT tube has failed overloading the supply
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Posted on Jan 22, 2008
SOURCE: access service menu lg rear projection tv
Hold the menu button on the remote and the menu button on the tv down simultaneously for 5 seconds.
Posted on Aug 10, 2008
mistersony
  • 320 Answers
SOURCE: Hitachi rear projection lcd lp500 series
It is likely the projection lamp is weak, causing the picture to cycle on and off. Take the lamp out and examine the reflector. If it is dull and cloudy, it's time to replace the lamp. A new lamp will have a reflector that is shiny and looks like a mirror. Be sure to rate this solution. Thanks!
Posted on Nov 08, 2008
ladywinn
  • 5138 Answers
SOURCE: How to reset the lamp timer count on a LG rear projection TV
Where you got new lamp, should have information on how to reset timer for New Lamp.If i can find my information on resetting timer i will post it for you.
Posted on Jun 15, 2009
techman007
  • 1112 Answers
SOURCE: 55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
Posted on Oct 01, 2009
N/P N/S . JVC HD55GC86, red lite comes on & it goes off immediately.
test this steps and fix it. God bless you
Lamp Problems
Rear-Projection TVs have a lamp, which picks up the picture and projects it on the TV screen. A burned-out or connected lamps are two of the most common problems for Rear-Projection TVs. First, you will want to confirm the bulb is still good. If the bulb is bad then then replace it immediately. Second consult your user manual and verify the lamp and lamp cover are installed properly. Most Rear-Projection TVs have warning light which notify you when there are lamp problems. Again consult the user's manual to see what each light means.
Overheating
Temperature is a common reason why many Rear-projection TVs do not perform well when they get to hot. You may start to see your TV shutting down automatically when it overheats. Here are a couple of things you can do to prevent overheating. First make certain any TV ventilation ports are free and clear of debris and dust. Second make sure the TV has enough room for airflow. Third, the temperature in the room should be around 72 degrees. Due to the high degree of heat generated by a rear-projection TVs, it is not advisable to watch TV on a hot days when you don't run the air condition. This could cause damage to your TV.
Configuration Problems
Improperly configuring TV setting can cause problems. Verify the TV settings are set correctly. First, brightness and contrast should not be set to high or to low because this can cause poor picture images. Second, adjust the color on the TV when the picture displays colors poorly. Third, if you are having sound issues then check to make sure the volume is not muted or turn down all the way.
Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Jul 30, 2013 | JVC HD-55GC86 OEM TV Lamp
Jvc hd-61Z786 REAR PROJECTION TV . is dark. replaced the lamp. did not help much
all u have to do is to
Reset Picture and Sound Adjustments
1.Press the "Menu" button.
2. Press the "CH+" or "CH-" button to "Reset" listed on the display.
3. Press the "Volume+" or "Volume-" buttons to move left or right to enter your Reset selection. The Reset will reset all of your picture adjustments, including the color, brightness and tint to the default settings. Reset also resets your sound adjustments to the default settings, like the balance, bass and treble.
4. Press the "Menu" button to complete the resetting process
Feb 23, 2011 | JVC HD-61Z786 61" Rear Projection HDTV
My power light and lamp/standby light blinks.... no picture or sound... Grrrrr help pls
The projection lamp on this tv like 1 1/2 or 2 years has not been replaced in this tv and it turn on and watches tv 4 or 5 hours every day?Yes,than the projection lamp life is over.Require replacing a projection lamp.
Oct 18, 2010 | JVC HD-52G786 52" Rear Projection HDTV
JVC HD61Z585 loud pop picture went blank and will not even turn on
sounds as if your lamp cracked, order a new one onlie-fairly inexpensive and install according to the lamp instuctions, check to see if anything was on or in contact with the lamp. sometimes they just pop other times something came into contact with it
Jan 17, 2010 | JVC HD-61Z585 61" Rear Projection...
TV turned off itself
Can you still turn it on?
If so, does it stay on with sound?
If the sound is ok and the picture is blue (even when changing channels, inputs, etc.) the lamp may have gone out.
Can you see the TV menu when you press the menu button on the remote or TV?
Jan 07, 2009 | Sony KP-51HW40 51" Rear Projection...
No sound on JVC AV-48P575 48 inch rear projection TV
Try going into the menu and find something called, "center channel input." If it is on, the sound will not work. Turn it off, and the sound should be restored.
Mar 23, 2008 | JVC AV-48P575 48" Rear Projection...
JVC Rear Projection
If you still can see the DirecTV guide and menu, the problem could be on your satellite receiver and not the TV. Unplug your receiver and plug it back.
If the rebooting did not work, I would suggest to swap the satellites receivers and see if it works.
Good Luck.
Mar 14, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Televison & Video Logo
97 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
